- 积分
- 311
- 金钱
- 280
- 威望
- 0
- 贡献
- 0
- HASS币
- 0
- 积分
- 311
- 金钱
- 280
- HASS币
- 0
发表于 2023-10-30 20:40:28
显示全部楼层
2023-10-30 12:24:46.804 ERROR (MainThread) [aiohttp.server] Error handling request
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_app.py", line 504, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.11/site-packages/aiohttp/web_middlewares.py", line 117, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 85, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
response = await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 148, in handle
result = await handler(request, **request.match_info)
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 177, in post
return await super().post(request, flow_id)
File "/usr/src/homeassistant/homeassistant/components/http/data_validator.py", line 72, in wrapper
result = await method(view, request, data, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 110, in post
result = await self._flow_mgr.async_configure(flow_id, data)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 293, in async_configure
result = await self._async_handle_step(
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 394, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File "/config/custom_components/sunlogin/config_flow.py", line 137, in async_step_user
cloud_api, res = await attempt_cloud_connection(self.hass, user_input)
File "/config/custom_components/sunlogin/config_flow.py", line 108, in attempt_cloud_connection
res = await cloud_api.async_get_devices_list()
File "/config/custom_components/sunlogin/sunlogin.py", line 149, in async_get_devices_list
self.device_list = {dev["sn"]: dev for dev in r_json["devices"]}
KeyError: 'devices'
