『瀚思彼岸』» 智能家居技术论坛
楼主: helloworld
[教程系列] 精装修全屋KNX设备接入homekit简明教程(一)
帖子
538
Rank: 4
发表于 2023-1-11 18:32:57 | 显示全部楼层
你有KNX的IP接口,可以直接在配置-集成里面把KNX设备添加进来,然后再到HomeKit,毕竟noderedred里那么多的节点,还是很多人不会写的(包括我
帖子
46
Rank: 1
发表于 2023-1-15 05:41:24 | 显示全部楼层
帖子
515
Rank: 4
 楼主| 发表于 2023-1-16 16:18:34 | 显示全部楼层
liy517 发表于 2023-1-11 18:32
你有KNX的IP接口,可以直接在配置-集成里面把KNX设备添加进来,然后再到HomeKit,毕竟noderedred里那么多的 ...
主要是我喜欢nodede的操作风格,图文感觉更清晰点。
然后,节点直接复制,修改设备对应的knx地址,就行了。按道理还是比较简单。
ha里面导入节点,应该也要配置knx的地址嘛。看自己喜欢吧。只是分享下,怎么接入的
帖子
1309
Rank: 6Rank: 6
发表于 2023-1-16 18:59:50 | 显示全部楼层
感谢分享!学习收藏。
帖子
538
Rank: 4
发表于 2023-1-17 22:22:30 | 显示全部楼层
然后,节点直接复制,修改设备对应的knx地址,就行 ...
嗯,多出点nodered的教程
帖子
749
Rank: 4
发表于 2023-1-18 17:35:42 | 显示全部楼层
楼主能分享下valve的流吗,我配置好InUse从homekit可以正常控制及得到状态反馈,但是从原app操作则会显示正在停止或启动
帖子
515
Rank: 4
 楼主| 发表于 2023-1-21 10:39:58 | 显示全部楼层
lswq 发表于 2023-1-18 17:35
楼主能分享下valve的流吗,我配置好InUse从homekit可以正常控制及得到状态反馈,但是从原app操作则会显示正 ...
[{"id":"55f20542fc81baa0","type":"subflow","name":"active","info":"","category":"","in":[{"x":80,"y":80,"wires":[{"id":"cac081cd3cd1ec5d"}]}],"out":[{"x":300,"y":80,"wires":[{"id":"cac081cd3cd1ec5d","port":0}]}],"env":[],"meta":{},"color":"#DDAA99"},{"id":"cac081cd3cd1ec5d","type":"function","z":"55f20542fc81baa0","name":"","func":"msg.payload = msg.payload.Active\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":190,"y":80,"wires":[[]]},{"id":"62281231543d7ce9","type":"subflow","name":"Vavle","info":"","category":"","in":[{"x":60,"y":80,"wires":[{"id":"43429e7a58770272"}]}],"out":[{"x":320,"y":80,"wires":[{"id":"43429e7a58770272","port":0}]}],"env":[],"meta":{},"color":"#DDAA99"},{"id":"43429e7a58770272","type":"function","z":"62281231543d7ce9","name":"反馈","func":"msg.payload = {\n        \"Active\": msg.payload,\n        \"InUse\": msg.payload\n    }\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":190,"y":80,"wires":[[]]},{"id":"aa8225fa.45a8e8","type":"knxUltimate","z":"d86e8a646cbc6781","server":"1d670c832649ebb6","topic":"0/1/39","outputtopic":"","dpt":"1.001","initialread":"1","notifyreadrequest":false,"notifyresponse":true,"notifywrite":true,"notifyreadrequestalsorespondtobus":false,"notifyreadrequestalsorespondtobusdefaultvalueifnotinitialized":"0","listenallga":false,"name":"主卧主卫地暖反馈","outputtype":"read","outputRBE":false,"inputRBE":false,"formatmultiplyvalue":1,"formatnegativevalue":"leave","formatdecimalsvalue":999,"passthrough":"no","x":470,"y":4600,"wires":[["bcfba739.d00c98"]]},{"id":"bcfba739.d00c98","type":"subflow:62281231543d7ce9","z":"d86e8a646cbc6781","name":"","env":[],"x":680,"y":4600,"wires":[["168438c2.0d1c9f"]]},{"id":"168438c2.0d1c9f","type":"homekit-service","z":"d86e8a646cbc6781","isParent":true,"hostType":"0","bridge":"f29d837f.9839c","accessoryId":"","parentService":"","name":"主卧地暖阀门","serviceName":"Valve","topic":"","filter":false,"manufacturer":"IOT DREAM","model":"1.3.6","serialNo":"Default Serial Number","firmwareRev":"1.3.6","hardwareRev":"1.3.6","softwareRev":"1.3.6","cameraConfigVideoProcessor":"ffmpeg","cameraConfigSource":"","cameraConfigStillImageSource":"","cameraConfigMaxStreams":2,"cameraConfigMaxWidth":1280,"cameraConfigMaxHeight":720,"cameraConfigMaxFPS":10,"cameraConfigMaxBitrate":300,"cameraConfigVideoCodec":"libx264","cameraConfigAudioCodec":"libfdk_aac","cameraConfigAudio":false,"cameraConfigPacketSize":1316,"cameraConfigVerticalFlip":false,"cameraConfigHorizontalFlip":false,"cameraConfigMapVideo":"0:0","cameraConfigMapAudio":"0:1","cameraConfigVideoFilter":"scale=1280:720","cameraConfigAdditionalCommandLine":"-tune zerolatency","cameraConfigDebug":false,"cameraConfigSnapshotOutput":"disabled","cameraConfigInterfaceName":"","characteristicProperties":"{    \"ValveType\":{       \"minValue\":0,       \"maxValue\":0    } }","waitForSetupMsg":false,"outputs":2,"x":970,"y":4600,"wires":[[],["447d3f89.55477"]]},{"id":"447d3f89.55477","type":"subflow:55f20542fc81baa0","z":"d86e8a646cbc6781","name":"Homekit 开关控制","env":[],"x":1200,"y":4600,"wires":[["cdda6b4f.83d1c"]]},{"id":"cdda6b4f.83d1c","type":"knxUltimate","z":"d86e8a646cbc6781","server":"1d670c832649ebb6","topic":"0/0/39","outputtopic":"","dpt":"1.001","initialread":"0","notifyreadrequest":false,"notifyresponse":true,"notifywrite":true,"notifyreadrequestalsorespondtobus":false,"notifyreadrequestalsorespondtobusdefaultvalueifnotinitialized":"0","listenallga":false,"name":"阀门","outputtype":"write","outputRBE":false,"inputRBE":false,"formatmultiplyvalue":1,"formatnegativevalue":"leave","formatdecimalsvalue":999,"passthrough":"no","x":1450,"y":4600,"wires":[[]]},{"id":"1d670c832649ebb6","type":"knxUltimate-config","host":"192.168.2.100","port":"3671","physAddr":"15.15.44","hostProtocol":"TunnelUDP","suppressACKRequest":true,"csv":"","KNXEthInterface":"Auto","KNXEthInterfaceManuallyInput":"","statusDisplayLastUpdate":true,"statusDisplayDeviceNameWhenALL":true,"statusDisplayDataPoint":true,"stopETSImportIfNoDatapoint":"skip","loglevel":"error","name":"KNX Gateway","localEchoInTunneling":true,"delaybetweentelegrams":"50","delaybetweentelegramsfurtherdelayREAD":"1","ignoreTelegramsWithRepeatedFlag":false,"keyringFileXML":"","knxSecureSelected":false,"autoReconnect":"yes"},{"id":"f29d837f.9839c","type":"homekit-bridge","bridgeName":"一号","pinCode":"637-33-325","port":"","advertiser":"bonjour-hap","allowInsecureRequest":false,"manufacturer":"NRCHKB","model":"1.4.3","serialNo":"Default Serial Number","firmwareRev":"1.4.3","hardwareRev":"1.4.3","softwareRev":"1.4.3","customMdnsConfig":false,"mdnsMulticast":true,"mdnsInterface":"","mdnsPort":"","mdnsIp":"","mdnsTtl":"","mdnsLoopback":true,"mdnsReuseAddr":true,"allowMessagePassthrough":false}]
帖子
709
Rank: 4
发表于 2023-1-24 15:30:54 | 显示全部楼层
mark,说不定哪天就能用上
帖子
432
Rank: 3Rank: 3
发表于 2023-1-26 20:23:14 | 显示全部楼层
nodered 里面的KNX 的插件节点下载不下来啊   搞不了啊
帖子
1313
Rank: 6Rank: 6
发表于 2023-1-30 18:26:06 | 显示全部楼层
确实,Node-Red操作起来很方便
Archiver|手机版|小黑屋|Hassbian
GMT+8, 2024-5-20 21:17 , Processed in 0.058268 second(s), 32 queries .
Powered by Discuz! X3.4
