查看: 10684|回复: 3
[求助] 鸿雁IHC8340B wifi排插接入 HomeAssistant 出错
发表于 2017-8-28 21:56:15 | 显示全部楼层 |阅读模式
按照C大的  [插件发布](07/21)Broadlink插排MP1/鸿雁IHC8340B wifi排插 HomeAssistant支持插件  但是没有成功。
经过查询日志,出现下面的错误提示,请问要如何处理?
2017-08-28 21:05:03 ERROR (MainThread) [homeassistant.loader] Error loading homeassistant.components.switch.broadlink_mp1. Make sure all dependencies are installed
  File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/loader.py", line 142, in get_component
    module = importlib.import_module(path)
  File "/usr/lib/python3.5/importlib/__init__.py", line 126, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 986, in _gcd_import
  File "<frozen importlib._bootstrap>", line 969, in _find_and_load
  File "<frozen importlib._bootstrap>", line 958, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 673, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 673, in exec_module
  File "<frozen importlib._bootstrap>", line 222, in _call_with_frames_removed
  File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/components/switch/broadlink_mp1.py", line 19, in <module>
    from broadlink import mp1 as BroadlinkMP1Device
ImportError: No module named 'broadlink'
2017-08-28 21:05:03 ERROR (MainThread) [homeassistant.loader] Unable to find component switch.broadlink_mp1
 楼主| 发表于 2017-8-29 01:19:05 | 显示全部楼层
删除broadlink_mp1  重新下载把文件拷进去,又出现不同的错误:
2017-08-29 01:16:26 ERROR (MainThread) [homeassistant.components.switch] Error while setting up platform broadlink_mp1
  File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/helpers/entity_component.py", line 164, in _async_setup_platform
    SLOW_SETUP_MAX_WAIT, loop=self.hass.loop)
  File "/usr/lib/python3.5/asyncio/tasks.py", line 393, in wait_for
    return fut.result()
  File "/usr/lib/python3.5/asyncio/futures.py", line 292, in result
    raise self._exception
  File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
  File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/components/switch/broadlink_mp1.py", line 98, in setup_platform
    if (switch_alias in alias_names):
TypeError: argument of type 'NoneType' is not iterable
发表于 2017-8-29 01:29:14 | 显示全部楼层
貌似是博联插件没有装上
发表于 2017-11-25 15:20:59 | 显示全部楼层
请问楼主的问题解决了吗,我也是同样的问题,,请赐教。。
GMT+8, 2025-12-25 13:55 , Processed in 0.113672 second(s), 10 queries , MemCached On.
