查看: 11000|回复: 5
[教程系列] 如何给子流程中的节点传递一个参数?www-request节点的url
发表于 2020-5-12 18:30:03 | 显示全部楼层 |阅读模式
家中多个摄像机用于人体识别。把这个步骤做成了一个子流程。
但是多个摄像机如何选择呢?
配置基本一样。就是IP不同
发表于 2020-5-12 19:31:45 | 显示全部楼层
var ip = `10.0.0.222`;
msg.url = `http://${ip}:11110/picture/1/current/`;
return msg;
改ip变量就行了吧
发表于 2020-5-13 08:37:16 | 显示全部楼层
最简单的摄像头节点,并联多个不就好了
 楼主| 发表于 2020-5-14 16:03:53 | 显示全部楼层
minions123 发表于 2020-5-12 19:31
改ip变量就行了吧
使用这个方法后。提示
"Warning: msg properties can no longer override set node properties. See bit.ly/nr-override-msg-props"
发表于 2020-5-14 22:43:23 | 显示全部楼层
boyyao 发表于 2020-5-14 16:03
使用这个方法后。提示
"Warning: msg properties can no longer override set node properties. See bit. ...
[{"id":"67feb8bf.586aa8","type":"http request","z":"ee7843f9.faf64","name":"","method":"GET","ret":"bin","paytoqs":false,"url":"","tls":"","proxy":"","authType":"","x":660.5000076293945,"y":201.00000381469727,"wires":[["fb85ae96.07e4a"]]},{"id":"fb85ae96.07e4a","type":"image","z":"ee7843f9.faf64","name":"","width":"250","data":"payload","dataType":"msg","thumbnail":false,"active":true,"x":836.5000076293945,"y":203.00000381469727,"wires":[]},{"id":"ffc97c93.b24a6","type":"inject","z":"ee7843f9.faf64","name":"","topic":"","payload":"1","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":116.5,"y":182.00000476837158,"wires":[["223ee519.8b765a"]]},{"id":"caf92a66.5c69a8","type":"function","z":"ee7843f9.faf64","name":"","func":"\nmsg.url = `http://10.0.0.222:11110/picture/${msg.num}/current/`;\nreturn msg;","outputs":1,"noerr":0,"x":521.6000022888184,"y":200.00000381469727,"wires":[["67feb8bf.586aa8"]]},{"id":"223ee519.8b765a","type":"change","z":"ee7843f9.faf64","name":"","rules":[{"t":"move","p":"payload","pt":"msg","to":"num","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":313.6000061035156,"y":205.0000057220459,"wires":[["caf92a66.5c69a8"]]},{"id":"fbd5fef0.a2ddb","type":"inject","z":"ee7843f9.faf64","name":"","topic":"","payload":"2","payloadType":"num","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":118,"y":240.0000057220459,"wires":[["223ee519.8b765a"]]}]
我不知道你输入节点数据类型,我这个流程是输入摄像头序号来拍照的,你看看有没有帮助呢
 楼主| 发表于 2020-5-19 00:55:46 | 显示全部楼层
minions123 发表于 2020-5-14 22:43
我不知道你输入节点数据类型,我这个流程是输入摄像头序号来拍照的,你看看有没有帮助呢 ...
非常感谢。已经搞定了。可能是之前的http request是其他流程导入的关系。不起作用。重新拉了个http request就ok了。。
GMT+8, 2025-12-24 17:25 , Processed in 0.713537 second(s), 11 queries , MemCached On.
