楼主: mac_zhou
[插件集成] 美的空调-局域网协议控制[新协议已支持]
 楼主| 发表于 2021-8-12 10:09:02 | 显示全部楼层
sctale 发表于 2021-8-12 07:24
昨天晚上开始用这个插件的,一开始可以的,到了昨天晚上12点就一直是不可用状态了 ...
给出日志
发表于 2021-8-12 12:19:50 | 显示全部楼层
老兄棒棒的,我家的美的电器靠你了。
发表于 2021-8-12 13:23:04 | 显示全部楼层
先mark, 准备搞个华凌的神机试试
发表于 2021-8-12 16:07:39 | 显示全部楼层
能说下适配非空调的设备需要收集哪些东西吗?
发表于 2021-8-12 18:38:10 来自手机 | 显示全部楼层
此错误来自自定义集成。  Logger: homeassistant.helpers.entity Source: custom_components/midea_ac/climate.py:133 Integration: midea_ac (documentation) First occurred: 06:46:47 (2843 occurrences) Last logged: 18:37:20  Update for climate.midea_ac_63771674493145 fails Traceback (most recent call last):   File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 350, in async_update_ha_state     await self.async_device_update()   File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 558, in async_device_update     raise exc   File "/config/custom_components/midea_ac/climate.py", line 133, in async_update     await self.hass.async_add_executor_job(self._device.refresh)   File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run     result = self.fn(*self.args, **self.kwargs)   File "/usr/local/lib/python3.8/site-packages/msmart/device.py", line 195, in refresh     self._send_cmd(cmd)   File "/usr/local/lib/python3.8/site-packages/msmart/device.py", line 204, in _send_cmd     responses = self._lan_service.appliance_transparent_send(data)   File "/usr/local/lib/python3.8/site-packages/msmart/lan.py", line 102, in appliance_transparent_send     response = self.request(data)   File "/usr/local/lib/python3.8/site-packages/msmart/lan.py", line 42, in request     self._connect()   File "/usr/local/lib/python3.8/site-packages/msmart/lan.py", line 33, in _connect     raise error   File "/usr/local/lib/python3.8/site-packages/msmart/lan.py", line 30, in _connect     self._socket.connect((self.device_ip, self.device_port)) socket.timeout: timed out
发表于 2021-8-12 18:50:36 | 显示全部楼层
升级了下,有问题又用备份覆盖回来了,日志没仔细看
发表于 2021-8-12 22:12:29 | 显示全部楼层
感谢大佬解决V3局域网控制问题~
不知能否增加防直吹功能?支持设置具体百分比风速
发表于 2021-8-13 12:33:23 来自手机 | 显示全部楼层
感谢大佬   厉害厉害
发表于 2021-8-14 01:12:09 | 显示全部楼层
大佬.检查配置文件提示 Platform error climate.midea_ac - Requirements for midea_ac not found: ['midea'].
222222.png 这个是配置
发表于 2021-8-15 11:28:56 | 显示全部楼层
v3协议已经用上了,很稳定,楼主太牛了,想问下有没有考虑过分享一下分析过程,想学习一下
另外,v3协议好像无法显示室外机温度
GMT+8, 2025-12-12 19:37 , Processed in 0.250320 second(s), 11 queries , MemCached On.
