楼主: 27hh
[进阶教程] 闲置安卓手机安装HA变身智能家居中枢,及网关接入教程
发表于 2020-9-19 16:13:48 | 显示全部楼层
effective uid is not 0, is /usr/bin/sudo on a file system with the 'nosuid' option set or an NFS file system without root privileges?    总是出现这个
发表于 2020-10-4 13:13:30 | 显示全部楼层
66666666666
发表于 2021-4-22 14:11:07 | 显示全部楼层
学习下,谢谢分享
发表于 2021-7-26 15:10:53 | 显示全部楼层
您好!在输入pip3 install -U homeassistant 之后 出现了这个是什么问题呢?
(homeassistant) homeassistant@localhost:/home/android$ pip3 install -U homeassistant
WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0xb5d210f0>: Failed to establish a new connection: [Errno -2] Name or service not known',)': /simple/homeassistant/
WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0xb5d21610>: Failed to establish a new connection: [Errno -2] Name or service not known',)': /simple/homeassistant/
WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0xb5d216f0>: Failed to establish a new connection: [Errno -2] Name or service not known',)': /simple/homeassistant/
WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0xb5d217d0>: Failed to establish a new connection: [Errno -2] Name or service not known',)': /simple/homeassistant/
WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.HTTPSConnection object at 0xb5d218b0>: Failed to establish a new connection: [Errno -2] Name or service not known',)': /simple/homeassistant/
ERROR: Could not find a version that satisfies the requirement homeassistant (from versions: none)
ERROR: No matching distribution found for homeassistant
感谢回复!
发表于 2022-1-17 14:18:18 | 显示全部楼层
淘宝500多的Android平板可以么?
又想当HA的服务,又想触控屏,树莓派+触控显示器代价有点高,平板能装的话最理想了。
发表于 2022-4-18 23:02:23 | 显示全部楼层
输入网址打不开怎么回事
启动成功输入网址打不开
启动成功输入网址打不开
发表于 2022-4-19 09:52:28 | 显示全部楼层
利用老手机做home assistant服务器不错,请大师们多推出一点这样的资料学习
发表于 2022-6-10 17:00:12 | 显示全部楼层
不错,这样就可以把旧手机利用起来
发表于 2022-12-17 00:49:36 | 显示全部楼层
android@localhost:~$ sudo pip3 install virtualenv
  File "/usr/local/bin/pip3", line 7, in <module>
    from pip._internal.cli.main import main
  File "/usr/local/lib/python3.5/dist-packages/pip/_internal/cli/main.py", line 57
    sys.stderr.write(f"ERROR: {exc}")
SyntaxError: invalid syntax
到这里好像就走不通了
发表于 2023-3-2 13:46:27 | 显示全部楼层
多谢分享
GMT+8, 2025-12-20 02:22 , Processed in 0.069619 second(s), 19 queries , MemCached On.
