楼主: 27hh
[进阶教程] 闲置安卓手机安装HA变身智能家居中枢,及网关接入教程
发表于 2018-4-10 18:56:10 来自手机 | 显示全部楼层
小白新来学习一下
发表于 2018-4-11 10:44:02 | 显示全部楼层
都是大神,小白膜拜
发表于 2018-4-11 14:43:38 | 显示全部楼层
哈哈哈哈,支持作者,我以为只有树莓派这些可以实现呢,你救了我
我就是六神
活跃会员教程狂人灌水之王
发表于 2018-4-11 14:58:40 | 显示全部楼层
ahsyon 发表于 2017-8-28 13:20
不错,这样就可以把旧手机利用起来了,最想拿旧手机做个魔镜出来
咋弄???
发表于 2018-4-11 15:53:28 | 显示全部楼层
楼主,我安装HA的时候到最后一步,提示出错了,这个怎么破
  The repository located at mirrors.ustc.edu.cn is not a trusted or secure host and is being ignored. If this repository is available via HTTPS it is recommended to use HTTPS instead, otherwise you may silence this warning and allow it anyways with '--trusted-host mirrors.ustc.edu.cn'.
  Could not find a version that satisfies the requirement homeassistant (from versions: )
No matching distribution found for homeassistant
27hh
教程狂人论坛风云人物
 楼主| 发表于 2018-4-11 16:11:00 来自手机 | 显示全部楼层
换源的里面http改成https
27hh
教程狂人论坛风云人物
 楼主| 发表于 2018-4-11 16:11:01 来自手机 | 显示全部楼层
换源的里面http改成https
发表于 2018-4-11 16:25:17 | 显示全部楼层
27hh 发表于 2018-4-11 16:11
换源的里面http改成https
还是不行。。。
* Documentation:  https://help.ubuntu.com/
Ubuntu 16.04 LTS [running via Linux Deploy]
Last login: Wed Apr 11 16:18:34 2018 from 192.168.2.218
saturday@localhost:~$ sudo mkdir /srv/homeassistant
mkdir: cannot create directory '/srv/homeassistant': File exists
saturday@localhost:~$ sudo chown homeassistant:homeassistant /srv/homeassistant
saturday@localhost:~$ sudo mkdir /home/homeassistant/.pip
mkdir: cannot create directory '/home/homeassistant/.pip': File exists
saturday@localhost:~$ sudo sh -c "echo '[global]\nindex-url = https://mirrors.ustc.edu.cn/pypi/web/simple/' > /home/homeassistant/.pip/pip.conf"
saturday@localhost:~$ sudo chown -R homeassistant:homeassistant /home/homeassistant/.pip
saturday@localhost:~$ sudo su -s /bin/bash homeassistant
homeassistant@localhost:/home/saturday$ virtualenv -p python3 /srv/homeassistant
Already using interpreter /usr/bin/python3
Using base prefix '/usr'
New python executable in /srv/homeassistant/bin/python3
Not overwriting existing python script /srv/homeassistant/bin/python (you must use /srv/homeassistant/bin/python3)
Installing setuptools, pip, wheel...done.
homeassistant@localhost:/home/saturday$ source /srv/homeassistant/bin/activate
(homeassistant) homeassistant@localhost:/home/saturday$ pip3 install -U homeassistant
Collecting homeassistant
  Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0xf62b06f0>: Failed to establish a new connection: [Errno -2] Name or service not known',)': /pypi/web/simple/homeassistant/
  Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0xf62b0050>: Failed to establish a new connection: [Errno -2] Name or service not known',)': /pypi/web/simple/homeassistant/
  Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0xf62b0450>: Failed to establish a new connection: [Errno -2] Name or service not known',)': /pypi/web/simple/homeassistant/
  Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0xf62b0d90>: Failed to establish a new connection: [Errno -2] Name or service not known',)': /pypi/web/simple/homeassistant/
  Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<pip._vendor.urllib3.connection.VerifiedHTTPSConnection object at 0xf62b06d0>: Failed to establish a new connection: [Errno -2] Name or service not known',)': /pypi/web/simple/homeassistant/
发表于 2018-4-11 16:29:15 | 显示全部楼层
换源的里面http改成https
提示这个
发表于 2018-4-11 16:36:54 | 显示全部楼层
前来学习
GMT+8, 2025-12-20 08:06 , Processed in 0.881066 second(s), 11 queries , MemCached On.
