查看: 3562|回复: 7
[求助] 小白求助 configuration.yaml有问题
发表于 2020-5-1 10:31:25 | 显示全部楼层 |阅读模式
刚装好HA,启动也正常,网页显示正常,但configuration.yaml里几乎没有东西
这是我的日志
Config directory: C:\Users\18801\AppData\Roaming\.homeassistant
2020-05-01 10:28:36 INFO (Thread-3) [homeassistant.loader] Loaded automation from homeassistant.components.automation
2020-05-01 10:28:36 INFO (Thread-5) [homeassistant.loader] Loaded script from homeassistant.components.script
2020-05-01 10:28:36 INFO (Thread-2) [homeassistant.loader] Loaded met from homeassistant.components.met
2020-05-01 10:28:36 INFO (Thread-6) [homeassistant.loader] Loaded group from homeassistant.components.group
2020-05-01 10:28:36 INFO (Thread-4) [homeassistant.loader] Loaded scene from homeassistant.components.scene
2020-05-01 10:28:36 INFO (Thread-7) [homeassistant.loader] Loaded default_config from homeassistant.components.default_config
2020-05-01 10:28:36 INFO (Thread-8) [homeassistant.loader] Loaded tts from homeassistant.components.tts
2020-05-01 10:28:36 INFO (Thread-3) [homeassistant.loader] Loaded persistent_notification from homeassistant.components.persistent_notification
2020-05-01 10:28:36 INFO (Thread-15) [homeassistant.loader] Loaded homeassistant from homeassistant.components.homeassistant
2020-05-01 10:28:36 INFO (Thread-11) [homeassistant.loader] Loaded webhook from homeassistant.components.webhook
2020-05-01 10:28:36 INFO (Thread-8) [homeassistant.loader] Loaded http from homeassistant.components.http
2020-05-01 10:28:36 INFO (MainThread) [homeassistant.setup] Setting up persistent_notification
2020-05-01 10:28:36 INFO (MainThread) [homeassistant.setup] Setup of domain persistent_notification took 0.0 seconds.
2020-05-01 10:28:36 INFO (MainThread) [homeassistant.setup] Setting up homeassistant
2020-05-01 10:28:36 INFO (MainThread) [homeassistant.setup] Setup of domain homeassistant took 0.0 seconds.
2020-05-01 10:28:36 INFO (Thread-13) [homeassistant.loader] Loaded cloud from homeassistant.components.cloud
2020-05-01 10:28:36 INFO (Thread-9) [homeassistant.loader] Loaded config from homeassistant.components.config
2020-05-01 10:28:36 INFO (Thread-14) [homeassistant.loader] Loaded frontend from homeassistant.components.frontend
2020-05-01 10:28:36 INFO (Thread-10) [homeassistant.loader] Loaded api from homeassistant.components.api
2020-05-01 10:28:36 INFO (Thread-5) [homeassistant.loader] Loaded auth from homeassistant.components.auth
2020-05-01 10:28:36 INFO (Thread-2) [homeassistant.loader] Loaded lovelace from homeassistant.components.lovelace
2020-05-01 10:28:36 INFO (Thread-6) [homeassistant.loader] Loaded onboarding from homeassistant.components.onboarding
2020-05-01 10:28:36 INFO (Thread-16) [homeassistant.loader] Loaded system_log from homeassistant.components.system_log
2020-05-01 10:28:36 INFO (Thread-4) [homeassistant.loader] Loaded websocket_api from homeassistant.components.websocket_api
2020-05-01 10:28:36 INFO (Thread-7) [homeassistant.loader] Loaded history from homeassistant.components.history
2020-05-01 10:28:36 INFO (Thread-12) [homeassistant.loader] Loaded recorder from homeassistant.components.recorder
2020-05-01 10:28:36 INFO (Thread-17) [homeassistant.loader] Loaded logbook from homeassistant.components.logbook
2020-05-01 10:28:36 INFO (Thread-3) [homeassistant.loader] Loaded map from homeassistant.components.map
2020-05-01 10:28:36 INFO (Thread-15) [homeassistant.loader] Loaded mobile_app from homeassistant.components.mobile_app
2020-05-01 10:28:36 INFO (Thread-11) [homeassistant.loader] Loaded person from homeassistant.components.person
2020-05-01 10:28:36 INFO (Thread-8) [homeassistant.loader] Loaded ssdp from homeassistant.components.ssdp
2020-05-01 10:28:36 INFO (Thread-18) [homeassistant.loader] Loaded sun from homeassistant.components.sun
2020-05-01 10:28:36 INFO (Thread-13) [homeassistant.loader] Loaded system_health from homeassistant.components.system_health
2020-05-01 10:28:36 INFO (Thread-19) [homeassistant.loader] Loaded updater from homeassistant.components.updater
2020-05-01 10:28:36 INFO (Thread-9) [homeassistant.loader] Loaded zeroconf from homeassistant.components.zeroconf
2020-05-01 10:28:36 INFO (MainThread) [homeassistant.bootstrap] Setting up {'system_log'}
2020-05-01 10:28:36 INFO (MainThread) [homeassistant.setup] Setting up http
2020-05-01 10:28:36 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds.
2020-05-01 10:28:36 INFO (MainThread) [homeassistant.setup] Setting up system_log
2020-05-01 10:28:36 INFO (MainThread) [homeassistant.setup] Setup of domain system_log took 0.0 seconds.
2020-05-01 10:28:36 INFO (MainThread) [homeassistant.setup] Setting up recorder
2020-05-01 10:28:36 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=11 from 2020-05-01 02:00:28.508399)
2020-05-01 10:28:36 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 0.4 seconds.
2020-05-01 10:28:36 INFO (MainThread) [homeassistant.setup] Setting up sun
2020-05-01 10:28:36 INFO (MainThread) [homeassistant.setup] Setup of domain sun took 0.0 seconds.
2020-05-01 10:28:37 INFO (MainThread) [homeassistant.setup] Setting up ssdp
2020-05-01 10:28:37 INFO (MainThread) [homeassistant.setup] Setup of domain ssdp took 0.0 seconds.
2020-05-01 10:28:37 INFO (MainThread) [homeassistant.setup] Setting up person
2020-05-01 10:28:37 INFO (MainThread) [homeassistant.setup] Setting up met
2020-05-01 10:28:37 INFO (MainThread) [homeassistant.setup] Setup of domain met took 0.0 seconds.
2020-05-01 10:28:37 INFO (MainThread) [homeassistant.setup] Setting up lovelace
2020-05-01 10:28:37 INFO (MainThread) [homeassistant.setup] Setup of domain lovelace took 0.0 seconds.
2020-05-01 10:28:37 INFO (MainThread) [homeassistant.setup] Setting up updater
2020-05-01 10:28:37 INFO (MainThread) [homeassistant.setup] Setup of domain updater took 0.0 seconds.
2020-05-01 10:28:37 INFO (MainThread) [homeassistant.setup] Setting up group
2020-05-01 10:28:37 INFO (MainThread) [homeassistant.setup] Setup of domain group took 0.0 seconds.
2020-05-01 10:28:37 INFO (MainThread) [homeassistant.setup] Setting up scene
2020-05-01 10:28:37 INFO (MainThread) [homeassistant.setup] Setup of domain scene took 0.0 seconds.
2020-05-01 10:28:37 INFO (Thread-5) [homeassistant.loader] Loaded weather from homeassistant.components.weather
2020-05-01 10:28:37 INFO (MainThread) [homeassistant.setup] Setting up config
2020-05-01 10:28:37 INFO (MainThread) [homeassistant.setup] Setting up script
2020-05-01 10:28:37 INFO (MainThread) [homeassistant.setup] Setup of domain script took 0.0 seconds.
2020-05-01 10:28:37 INFO (MainThread) [homeassistant.setup] Setting up websocket_api
2020-05-01 10:28:37 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds.
2020-05-01 10:28:37 INFO (MainThread) [homeassistant.setup] Setting up history
2020-05-01 10:28:37 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds.
2020-05-01 10:28:37 INFO (MainThread) [homeassistant.setup] Setting up api
2020-05-01 10:28:38 INFO (Thread-24) [homeassistant.loader] Loaded google_translate from homeassistant.components.google_translate
2020-05-01 10:28:38 INFO (MainThread) [homeassistant.setup] Setting up webhook
2020-05-01 10:28:38 INFO (MainThread) [homeassistant.setup] Setup of domain webhook took 0.0 seconds.
2020-05-01 10:28:38 INFO (MainThread) [homeassistant.setup] Setting up auth
2020-05-01 10:28:38 INFO (MainThread) [homeassistant.setup] Setup of domain auth took 0.0 seconds.
2020-05-01 10:28:38 INFO (MainThread) [homeassistant.setup] Setting up system_health
2020-05-01 10:28:38 INFO (MainThread) [homeassistant.setup] Setup of domain system_health took 0.0 seconds.
2020-05-01 10:28:38 INFO (MainThread) [homeassistant.setup] Setting up weather
2020-05-01 10:28:38 INFO (MainThread) [homeassistant.setup] Setup of domain weather took 0.0 seconds.
2020-05-01 10:28:38 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.1 seconds.
2020-05-01 10:28:38 INFO (MainThread) [homeassistant.setup] Setting up tts
2020-05-01 10:28:38 INFO (MainThread) [homeassistant.components.weather] Setting up weather.met
2020-05-01 10:28:38 INFO (MainThread) [homeassistant.setup] Setup of domain config took 0.2 seconds.
2020-05-01 10:28:38 INFO (MainThread) [homeassistant.setup] Setting up mobile_app
2020-05-01 10:28:38 INFO (MainThread) [homeassistant.setup] Setting up cloud
2020-05-01 10:28:39 INFO (MainThread) [homeassistant.setup] Setting up automation
2020-05-01 10:28:39 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 0.0 seconds.
2020-05-01 10:28:39 INFO (MainThread) [homeassistant.setup] Setting up onboarding
2020-05-01 10:28:39 INFO (MainThread) [homeassistant.setup] Setting up zeroconf
2020-05-01 10:28:40 INFO (MainThread) [homeassistant.setup] Setup of domain mobile_app took 2.2 seconds.
2020-05-01 10:28:40 INFO (MainThread) [homeassistant.setup] Setup of domain onboarding took 1.1 seconds.
2020-05-01 10:28:40 INFO (MainThread) [homeassistant.setup] Setup of domain zeroconf took 1.1 seconds.
2020-05-01 10:28:40 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 2.7 seconds.
2020-05-01 10:28:40 INFO (Thread-12) [homeassistant.loader] Loaded notify from homeassistant.components.notify
2020-05-01 10:28:40 INFO (MainThread) [homeassistant.setup] Setting up frontend
2020-05-01 10:28:40 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.0 seconds.
2020-05-01 10:28:40 INFO (MainThread) [homeassistant.setup] Setting up notify
2020-05-01 10:28:40 INFO (MainThread) [homeassistant.setup] Setup of domain notify took 0.0 seconds.
2020-05-01 10:28:40 INFO (MainThread) [homeassistant.setup] Setting up map
2020-05-01 10:28:40 INFO (MainThread) [homeassistant.setup] Setup of domain map took 0.0 seconds.
2020-05-01 10:28:40 INFO (MainThread) [homeassistant.setup] Setting up logbook
2020-05-01 10:28:40 INFO (MainThread) [homeassistant.setup] Setup of domain logbook took 0.0 seconds.
2020-05-01 10:28:40 INFO (MainThread) [homeassistant.setup] Setup of domain person took 3.7 seconds.
2020-05-01 10:28:40 INFO (MainThread) [homeassistant.setup] Setup of domain cloud took 2.3 seconds.
2020-05-01 10:28:40 INFO (MainThread) [homeassistant.components.notify] Setting up notify.mobile_app
2020-05-01 10:28:40 INFO (MainThread) [homeassistant.setup] Setting up default_config
2020-05-01 10:28:40 INFO (MainThread) [homeassistant.setup] Setup of domain default_config took 0.0 seconds.
2020-05-01 10:28:44 ERROR (MainThread) [homeassistant.core] Error doing job: Exception in callback _ProactorReadPipeTransport._loop_reading(<_OverlappedF...op_reading()]>)
  File "c:\users\18801\appdata\local\programs\python\python35\lib\asyncio\events.py", line 127, in _run
    self._callback(*self._args)
  File "c:\users\18801\appdata\local\programs\python\python35\lib\asyncio\proactor_events.py", line 189, in _loop_reading
    data = fut.result()  # deliver data later in "finally" clause
  File "c:\users\18801\appdata\local\programs\python\python35\lib\asyncio\futures.py", line 288, in result
    raise InvalidStateError('Result is not ready.')
asyncio.futures.InvalidStateError: Result is not ready.
2020-05-01 10:28:44 INFO (MainThread) [homeassistant.bootstrap] Home Assistant initialized in 9.35s
2020-05-01 10:28:44 INFO (MainThread) [homeassistant.core] Starting Home Assistant
2020-05-01 10:28:44 INFO (MainThread) [homeassistant.core] Timer:starting
2020-05-01 10:28:45 INFO (Thread-32) [homeassistant.loader] Loaded esphome from homeassistant.components.esphome
2020-05-01 10:28:45 INFO (Thread-14) [homeassistant.loader] Loaded zha from homeassistant.components.zha
2020-05-01 10:28:45 INFO (Thread-41) [homeassistant.loader] Loaded tradfri from homeassistant.components.tradfri
2020-05-01 10:28:45 INFO (Thread-10) [homeassistant.loader] Loaded smhi from homeassistant.components.smhi
2020-05-01 10:28:45 INFO (Thread-10) [homeassistant.loader] Loaded wemo from homeassistant.components.wemo
2020-05-01 10:28:45 INFO (Thread-5) [homeassistant.loader] Loaded somfy from homeassistant.components.somfy
2020-05-01 10:28:45 INFO (Thread-2) [homeassistant.loader] Loaded lifx from homeassistant.components.lifx
2020-05-01 10:28:45 INFO (Thread-24) [homeassistant.loader] Loaded smartthings from homeassistant.components.smartthings
2020-05-01 10:28:45 INFO (Thread-24) [homeassistant.loader] Loaded cast from homeassistant.components.cast
2020-05-01 10:28:45 INFO (Thread-25) [homeassistant.loader] Loaded ps4 from homeassistant.components.ps4
2020-05-01 10:28:45 INFO (Thread-26) [homeassistant.loader] Loaded sonos from homeassistant.components.sonos
2020-05-01 10:28:45 INFO (Thread-16) [homeassistant.loader] Loaded unifi from homeassistant.components.unifi
2020-05-01 10:28:45 INFO (Thread-4) [homeassistant.loader] Loaded plaato from homeassistant.components.plaato
2020-05-01 10:28:45 INFO (Thread-22) [homeassistant.loader] Loaded rainmachine from homeassistant.components.rainmachine
2020-05-01 10:28:45 INFO (Thread-27) [homeassistant.loader] Loaded homekit_controller from homeassistant.components.homekit_controller
2020-05-01 10:28:45 INFO (Thread-27) [homeassistant.loader] Loaded hangouts from homeassistant.components.hangouts
2020-05-01 10:28:45 INFO (Thread-27) [homeassistant.loader] Loaded ambient_station from homeassistant.components.ambient_station
2020-05-01 10:28:45 INFO (Thread-27) [homeassistant.loader] Loaded nest from homeassistant.components.nest
2020-05-01 10:28:45 INFO (Thread-28) [homeassistant.loader] Loaded homematicip_cloud from homeassistant.components.homematicip_cloud
2020-05-01 10:28:45 INFO (Thread-30) [homeassistant.loader] Loaded tellduslive from homeassistant.components.tellduslive
2020-05-01 10:28:45 INFO (Thread-30) [homeassistant.loader] Loaded hue from homeassistant.components.hue
2020-05-01 10:28:45 INFO (Thread-3) [homeassistant.loader] Loaded tplink from homeassistant.components.tplink
2020-05-01 10:28:45 INFO (Thread-15) [homeassistant.loader] Loaded locative from homeassistant.components.locative
2020-05-01 10:28:45 INFO (Thread-31) [homeassistant.loader] Loaded simplisafe from homeassistant.components.simplisafe
2020-05-01 10:28:45 INFO (Thread-31) [homeassistant.loader] Loaded heos from homeassistant.components.heos
2020-05-01 10:28:45 INFO (Thread-38) [homeassistant.loader] Loaded zwave from homeassistant.components.zwave
2020-05-01 10:28:45 INFO (Thread-21) [homeassistant.loader] Loaded mailgun from homeassistant.components.mailgun
2020-05-01 10:28:45 INFO (Thread-35) [homeassistant.loader] Loaded emulated_roku from homeassistant.components.emulated_roku
2020-05-01 10:28:45 INFO (Thread-35) [homeassistant.loader] Loaded mqtt from homeassistant.components.mqtt
2020-05-01 10:28:45 INFO (Thread-35) [homeassistant.loader] Loaded axis from homeassistant.components.axis
2020-05-01 10:28:45 INFO (Thread-36) [homeassistant.loader] Loaded logi_circle from homeassistant.components.logi_circle
2020-05-01 10:28:45 INFO (Thread-39) [homeassistant.loader] Loaded ambiclimate from homeassistant.components.ambiclimate
2020-05-01 10:28:45 INFO (Thread-19) [homeassistant.loader] Loaded deconz from homeassistant.components.deconz
2020-05-01 10:28:45 INFO (Thread-19) [homeassistant.loader] Loaded daikin from homeassistant.components.daikin
2020-05-01 10:28:45 INFO (Thread-19) [homeassistant.loader] Loaded ios from homeassistant.components.ios
2020-05-01 10:28:45 INFO (Thread-11) [homeassistant.loader] Loaded twilio from homeassistant.components.twilio
2020-05-01 10:28:45 INFO (Thread-11) [homeassistant.loader] Loaded gpslogger from homeassistant.components.gpslogger
2020-05-01 10:28:45 INFO (Thread-18) [homeassistant.loader] Loaded life360 from homeassistant.components.life360
2020-05-01 10:28:45 INFO (Thread-33) [homeassistant.loader] Loaded owntracks from homeassistant.components.owntracks
2020-05-01 10:28:45 INFO (Thread-33) [homeassistant.loader] Loaded luftdaten from homeassistant.components.luftdaten
2020-05-01 10:28:45 INFO (Thread-40) [homeassistant.loader] Loaded geofency from homeassistant.components.geofency
2020-05-01 10:28:45 INFO (Thread-40) [homeassistant.loader] Loaded wwlln from homeassistant.components.wwlln
2020-05-01 10:28:45 INFO (Thread-41) [homeassistant.loader] Loaded ifttt from homeassistant.components.ifttt
2020-05-01 10:28:45 INFO (Thread-23) [homeassistant.loader] Loaded ipma from homeassistant.components.ipma
2020-05-01 10:28:45 INFO (Thread-10) [homeassistant.loader] Loaded zone from homeassistant.components.zone
2020-05-01 10:28:45 INFO (Thread-5) [homeassistant.loader] Loaded notion from homeassistant.components.notion
2020-05-01 10:28:45 INFO (Thread-5) [homeassistant.loader] Loaded iqvia from homeassistant.components.iqvia
2020-05-01 10:28:45 INFO (Thread-5) [homeassistant.loader] Loaded upnp from homeassistant.components.upnp
2020-05-01 10:28:45 INFO (Thread-24) [homeassistant.loader] Loaded dialogflow from homeassistant.components.dialogflow
2020-05-01 10:28:45 INFO (Thread-24) [homeassistant.loader] Loaded toon from homeassistant.components.toon
2020-05-01 10:28:45 INFO (Thread-26) [homeassistant.loader] Loaded openuv from homeassistant.components.openuv
2020-05-01 10:28:45 INFO (Thread-16) [homeassistant.loader] Loaded adguard from homeassistant.components.adguard
2020-05-01 10:28:45 INFO (Thread-16) [homeassistant.loader] Loaded point from homeassistant.components.point
2020-05-01 10:28:49 ERROR (MainThread) [homeassistant.core] Error doing job: Exception in callback _ProactorReadPipeTransport._loop_reading(<_OverlappedF...\xd5\x93\xa9'>)
  File "c:\users\18801\appdata\local\programs\python\python35\lib\asyncio\proactor_events.py", line 187, in _loop_reading
    self._closing)
AssertionError
2020-05-01 10:29:11 ERROR (MainThread) [homeassistant.core] Error doing job: Exception in callback _ProactorBaseWritePipeTransport._loop_writing(<_OverlappedF...hed result=31>)
  File "c:\users\18801\appdata\local\programs\python\python35\lib\asyncio\proactor_events.py", line 270, in _loop_writing
    assert f is self._write_fut
AssertionError
发表于 2020-5-1 10:43:32 | 显示全部楼层
配置是要自己根据需求加入对应配置的。
发表于 2020-5-5 20:15:07 来自手机 | 显示全部楼层
正常吧。进去默认是Lovelace页面。它的配置不在configuration.yaml里面
发表于 2020-5-5 20:17:05 来自手机 | 显示全部楼层
了你按教程配置configuration.yaml,别实体加进去。然后在Lovelace里面找到它,配置自己的页面就好。新手先这样玩玩。等以后再看大神的页面定制
 楼主| 发表于 2020-5-9 20:42:13 | 显示全部楼层
平行的默默鱼 发表于 2020-5-5 20:17
了你按教程配置configuration.yaml,别实体加进去。然后在Lovelace里面找到它,配置自己的页面就好。新手先 ...
请问Lovelace是什么阿
发表于 2020-5-9 22:17:27 | 显示全部楼层
就是你看到的hassio的官方界面。我的意思是在configuration里面按照需求添加自己的配置。举个例子,你想把小米的网关接进来,就按论坛教程,在configuration.yaml中添加小米网关部分。然后重启HA,在开发者工具中就能看到接进来的实体。小米网关下面的zigbee设备,诸如传感器之类也会在里面。然后进概览,你看到的就是lovelace界面。里面选择配置UI,然后按需配置实体。比如显示温度曲线,开关状态啥的。就可以弄了。
发表于 2020-5-9 22:20:01 | 显示全部楼层
新手很容易懵逼。多看看就可以了。HA China网站,你也可以看看,很体系化的用中文讲了HA。据论坛里面大神说是墨澜大神做的。他去阿里后就没有更新了。但对于小白,还是很好的入门参考。
 楼主| 发表于 2020-5-9 22:48:54 | 显示全部楼层
平行的默默鱼 发表于 2020-5-9 22:20
新手很容易懵逼。多看看就可以了。HA China网站,你也可以看看,很体系化的用中文讲了HA。据论坛里面大神说 ...
好的好的,谢谢您
GMT+8, 2025-12-25 08:02 , Processed in 0.851640 second(s), 11 queries , MemCached On.
