查看: 14721|回复: 15
[教程系列] 机械开关控制16路继电器w5100+mega2560+mqtt
发表于 2020-4-30 23:53:36 | 显示全部楼层 |阅读模式
arduino w5100+mega2560+mqtt+机械开关控制16路继电器 烧录需要安装Arduino IDE
当断开网络或者断开mqtt连接自动重连的情况下不影响机械开关控制装修房子用来集中控制家里的灯 没用8266一直觉得无线没有线稳定 另外8266接口不够用
nr流
[{"id":"7828866a.710fc8","type":"mqtt out","z":"6a3df88f.1cf448","name":"","topic":"home/devices/onoff/","qos":"","retain":"","broker":"c4d68aad.d3c7b8","x":409.5,"y":411,"wires":[]},{"id":"c4d68aad.d3c7b8","type":"mqtt-broker","z":"","name":"","broker":"10.0.0.196","port":"1883","clientid":"node-red","usetls":false,"compatmode":true,"keepalive":"60","cleansession":true,"birthTopic":"","birthQos":"0","birthPayload":"","closeTopic":"","closePayload":"","willTopic":"","willQos":"0","willPayload":""}]
代码是东拼西凑的,麻烦大神帮忙看下有能简化的地方没
机械开关控制来自:需要的可以参考这个帖子接入点灯平台·可以增加·天猫精灵·小爱·小度·语音控制
https://www.arduino.cn/forum.php?mod=viewthread&tid=95064&highlight=%E5%BC%80%E5%85%B3
MQTT来自
https://www.jianshu.com/p/590f249ecd05
用到的mqtt库.zip (39.38 KB, 下载次数: 13) w5100+mega2560+mqtt+机械开关控制16路继电器.zip (3.53 KB, 下载次数: 23)
发表于 2020-5-1 01:58:22 来自手机 | 显示全部楼层
发表于 2020-5-2 19:39:02 | 显示全部楼层
看看效果好不好
发表于 2020-5-2 21:04:31 | 显示全部楼层
发表于 2020-5-4 20:05:16 | 显示全部楼层
发表于 2020-5-4 20:08:04 | 显示全部楼层
大佬请把连接阵脚也发一发
 楼主| 发表于 2020-5-6 09:09:34 来自手机 | 显示全部楼层
305267382 发表于 2020-5-4 20:08
大佬请把连接阵脚也发一发
代码里面有
发表于 2020-5-10 11:05:20 | 显示全部楼层
看看。。。。
发表于 2020-5-18 14:12:43 | 显示全部楼层
前排就坐,学习
发表于 2020-5-18 22:03:13 | 显示全部楼层
谢谢分享
GMT+8, 2025-11-7 02:09 , Processed in 0.512205 second(s), 13 queries , MemCached On.
