查看: 10902|回复: 6
[求助] esphome编译出错
发表于 2020-4-21 21:00:39 | 显示全部楼层 |阅读模式
---------------我的环境---------------斐讯N1
gcc版本是8.3.0
armbian是5.9
64位操作
esphome版本是1.12.2
--------------------报错截图-----------
我建立一个空的文件,选择的是nodmcu的开发板
只填写了wifi信息,直接编译的
<pre class="log" style="box-sizing: inherit; font-family: SFMono-Regular, Consolas, &quot;Liberation Mono&quot;, Menlo, Courier, monospace; font-size: 12px; max-height: calc(100% - 56px); background-color: rgb(28, 28, 28); padding: 16px; overflow: auto; line-height: 1.45; border-radius: 3px; white-space: pre-wrap; color: rgb(221, 221, 221);"><span class="line" style="box-sizing: inherit;"><span class="log-fg-red" style="box-sizing: inherit; color: rgb(255, 0, 0);">xtensa-lx106-elf-g++: internal compiler error: Segmentation fault (program cc1plus)</span><span style="box-sizing: inherit;">
</span></span><span class="line" style="box-sizing: inherit;"><span class="log-fg-yellow" style="box-sizing: inherit; color: rgb(255, 255, 0);">Please submit a full bug report,</span><span style="box-sizing: inherit;">
</span></span><span class="line" style="box-sizing: inherit;"><span class="log-fg-yellow" style="box-sizing: inherit; color: rgb(255, 255, 0);">with preprocessed source if appropriate.</span><span style="box-sizing: inherit;">
</span></span><span class="line" style="box-sizing: inherit;"><span class="log-fg-yellow" style="box-sizing: inherit; color: rgb(255, 255, 0);">See <http://gcc.gnu.org/bugs.html> for instructions.</span><span style="box-sizing: inherit;">
</span></span><span class="line" style="box-sizing: inherit;"><span style="box-sizing: inherit;">Compiling .pioenvs/esplight/lib4d9/ESP8266WiFi/WiFiClientSecureAxTLS.cpp.o</span><span style="box-sizing: inherit;">
</span></span><span class="line" style="box-sizing: inherit;"><span class="log-fg-red" style="box-sizing: inherit; color: rgb(255, 0, 0);">*** [.pioenvs/esplight/lib4d9/ESP8266WiFi/ESP8266WiFiSTA.cpp.o] Error 4</span></span></pre>
  感谢前辈解答,希望遇到我这样的问题可以一起得到解决,感谢感谢
 楼主| 发表于 2020-4-21 21:03:20 | 显示全部楼层
上面代码有点混乱 ,我重新发一下
发表于 2020-4-21 22:06:34 | 显示全部楼层
yan0422 发表于 2020-4-21 21:03
上面代码有点混乱 ,我重新发一下
xtensa-lx106-elf-g++: internal compiler error: Segmentation fault ( ...
换 X86 编译吧,arm 有坑。
 楼主| 发表于 2020-4-21 22:16:00 | 显示全部楼层
neroxps 发表于 2020-4-21 22:06
换 X86 编译吧,arm 有坑。
感谢解答,
活跃会员教程狂人卓越贡献
发表于 2020-4-21 22:20:34 | 显示全部楼层
个人建议在黑裙上用docker的esphome,无脑配置~
发表于 2020-4-22 15:48:36 | 显示全部楼层
可以用docker 的ESPHOME, 可以编译的
 楼主| 发表于 2020-4-22 19:31:15 | 显示全部楼层
你好我的就是在docker中的,现在使用了pip安装的esphome可以编译
GMT+8, 2025-12-23 12:13 , Processed in 0.196198 second(s), 10 queries , MemCached On.
