查看: 10972|回复: 3
[求助] Customize加载失败
发表于 2020-4-16 22:38:00 | 显示全部楼层 |阅读模式
悬赏10金钱未解决
configureation.yaml配置如下:
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
homeassistant:
  latitude: 32.87336
  longitude: 117.22743
  elevation: 430
  unit_system: metric
  time_zone: America/Los_Angeles
  customize: !include customize.yaml
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
#   base_url: example.duckdns.org:8123
# Text to speech
tts:
  - platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
customize.yaml配置如下:
light.reading_room:
  friendly_name: 书房灯
  tmall_genie: true
运行hass是,控制台提示:
You are using a custom integration for aligenie which has not been tested by Home Assistant.
This component might cause stability problems, be sure to disable it if you do experience issues
with Home Assistant.
天猫精灵绑定hass平台不能发现设备,不知道是什么原因
我的homeassistant版本是0.103.6
发表于 2020-4-17 13:28:42 | 显示全部楼层
在开发者工具-状态里,搜索light.reading_room,看属性里有没有tmall_genie: true这行
控制台提示的那句,只要是第三方插件都这么提示,不影响
你的问题可能不是没加载Customize
 楼主| 发表于 2020-4-18 11:45:42 | 显示全部楼层
控制台提示的那句,只 ...
我自己搭建的天猫精灵技能是正常的,现在用hass的技能平台绑定成功,但是没有发送AliGenie.Iot.Device.Discovery,所以看不到设备
发表于 2020-11-11 22:35:52 | 显示全部楼层
mudlife 发表于 2020-4-18 11:45
我自己搭建的天猫精灵技能是正常的,现在用hass的技能平台绑定成功,但是没有发送AliGenie.Iot.Device.Di ...
同样问题,楼主解决没
GMT+8, 2025-11-7 10:11 , Processed in 1.039523 second(s), 10 queries , MemCached On.
