查看: 10843|回复: 1
[技术探讨] 【解决了】求助帖 cannot import name 'util'
发表于 2020-4-15 21:55:24 | 显示全部楼层 |阅读模式
大家好
今天装一个插件havcs
Error loading custom_components.havcs. Make sure all dependencies are installed
Traceback (most recent call last):  File "/usr/local/lib/python3.7/dist-packages/homeassistant/loader.py", line 391, in _load_file    module = importlib.import_module(path)  File "/usr/lib/python3.7/importlib/__init__.py", line 127, in import_module    return _bootstrap._gcd_import(name[level:], package, level)  File "<frozen importlib._bootstrap>", line 1006, in _gcd_import  File "<frozen importlib._bootstrap>", line 983, in _find_and_load  File "<frozen importlib._bootstrap>", line 967, in _find_and_load_unlocked  File "<frozen importlib._bootstrap>", line 677, in _load_unlocked  File "<frozen importlib._bootstrap_external>", line 728, in exec_module  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed  File "/home/pi/.homeassistant/custom_components/havcs/__init__.py", line 34, in <module>    from . import util as havcs_utilImportError: cannot import name 'util' from 'custom_components.havcs' (/home/pi/.homeassistant/custom_components/havcs/__init__.py)
能看出来 是少了util的关系?这个咋整。。。跪谢
原来是下载的文件里少了...utils.py..我昏倒
 楼主| 发表于 2020-4-16 21:29:38 | 显示全部楼层
求助求助呢,各位大师傅。
GMT+8, 2025-12-15 23:35 , Processed in 1.066963 second(s), 10 queries , MemCached On.
