查看: 19201|回复: 12
[教程系列] Node-red接入小度音箱dlna进行语音播报
发表于 2020-4-14 13:22:06 | 显示全部楼层 |阅读模式
家里好几个小度音箱,一直想接入自动化流程进行语音播报。之前,hass的小度dlna有问题,就搁置了下来。新版hass已经可以正常使用小度dlna了,于是又重新燃起了接入node-red自动化的想法。在网上查了好多dlna相关内容,越来越懵圈。昨天试着论坛教程安装Airplay TTS,可惜没有成功。这个dlna到底是啥东西?小度音箱还能不能接入node-red了?我就想搞个语音播报,也没啥奢求啊。今天下定决心,搞出这个流程。走捷径,直接在Node-red里调用hass服务。
调用方法,参考大神的小爱tts语音播报:https://bbs.hassbian.com/thread-6424-1-2.html
前提:可以在hass下调用tts服务播报到dlna音箱
流程:
上图
流程json
[{"id":"cb734470.d12928","type":"inject","z":"640378a7.2a5608","name":"","topic":"","payload":"哈喽,我是小度","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":270,"y":260,"wires":[["2fdae6ec.fe672a"]]},{"id":"92beaf55.c447c","type":"api-call-service","z":"640378a7.2a5608","name":"语音播报","server":"bab09590.5967f8","version":1,"debugenabled":true,"service_domain":"tts","service":"baidu_say","entityId":"","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":880,"y":260,"wires":[[]]},{"id":"2fdae6ec.fe672a","type":"function","z":"640378a7.2a5608","name":"tts播报数据","func":"// 获取上一个流程的msg信息,构建服务百度tts服务的数据\n\na = msg.payload;\nmsg.payload = {};\nmsg.payload.data = {\n    "entity_id": "media_player.xiao_du_zhi_neng_yin_xiang_2811",\n    "message":a,\n    "cache":"false"}\nreturn msg;","outputs":1,"noerr":0,"x":550,"y":260,"wires":[["92beaf55.c447c","5aca69d0.023328"]]},{"id":"5aca69d0.023328","type":"debug","z":"640378a7.2a5608","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","x":750,"y":220,"wires":[]},{"id":"bab09590.5967f8","type":"server","z":"","name":"Home Assistant","legacy":false,"addon":false,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
应用示例
示例 json
[{"id":"628f2437.a7bd4c","type":"debug","z":"47279dd.c1ef264","name":"显示调试信息","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","x":1680,"y":420,"wires":[]},{"id":"f8d52d6f.f629e","type":"api-call-service","z":"47279dd.c1ef264","name":"语音播报","server":"bab09590.5967f8","version":1,"debugenabled":true,"service_domain":"tts","service":"baidu_say","entityId":"","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":1670,"y":460,"wires":[[]]},{"id":"3203e39a.b2f21c","type":"function","z":"47279dd.c1ef264","name":"tts播报数据","func":"a = "现在播报测试信息。厨房湿度差值是" + msg.payload;\nmsg.payload = {};\nmsg.payload.data = {\n    "entity_id": "media_player.xiao_du_zhi_neng_yin_xiang_2811",\n    "message":a,\n    "cache":"false"}\nreturn msg;","outputs":1,"noerr":0,"x":1490,"y":460,"wires":[["f8d52d6f.f629e","628f2437.a7bd4c"]]},{"id":"a5af4f27.4afce","type":"comment","z":"47279dd.c1ef264","name":"语音提示测试信息","info":"在主卧小度音箱上,收听“可以驱动后续路程”的温度差值\n限定在非睡眠时间范围内\n属于临时性播报","x":1430,"y":420,"wires":[]},{"id":"bab09590.5967f8","type":"server","z":"","name":"Home Assistant","legacy":false,"addon":false,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":true}]
小度音箱终于可以接入Node-red了
太奇怪了,贴在这里的json竟然不可用。补上文件
小度dlna配置-2.txt
1.46 KB, 下载次数: 374
小度dlna配置.txt
1.41 KB, 下载次数: 212
发表于 2020-4-14 20:17:07 | 显示全部楼层
我的最原始版小度在家好像没dlna
 楼主| 发表于 2020-4-14 22:17:20 | 显示全部楼层
nuaawmy 发表于 2020-4-14 20:17
我的最原始版小度在家好像没dlna
这个是基于dlna的。你只能通过蓝牙播放了
 楼主| 发表于 2020-4-17 09:07:00 | 显示全部楼层
我的最原始版小度在家好像没dlna
如果你的音箱有蓝牙,这个蓝牙又可以接入到hass主机。推荐你这个项目,通过蓝牙接入dlna,教程超级详细。
大致的意思,就是在hass主机安装蓝牙一些驱动;hass安装插件。然后hass就可以搜索到这个蓝牙dlna了https://github.com/pkozul/ha-tts-bluetooth-speaker
发表于 2020-4-23 07:04:12 | 显示全部楼层
nr有dlna插件,安装里搜dlna就出来了,设备里写小度的设备描述文件地址,得到这个地址你可以建一个udp in节点,选择监听广播,端口1900,后输出到debug节点输出里应该有小度的ip/xxxx.xml这就是它的设备描述文件地址
East
发表于 2020-6-4 19:04:24 | 显示全部楼层
@姚远  这个数据流导不进,是咋回事呢?
 楼主| 发表于 2020-6-5 10:18:04 | 显示全部楼层
East 发表于 2020-6-4 19:04
@姚远  这个数据流导不进,是咋回事呢?
论坛代码被自动“修订”了。你试试下载附件2
East
发表于 2020-6-5 13:08:31 | 显示全部楼层
可以了
发表于 2020-7-16 09:21:57 | 显示全部楼层
家里大金刚可以试试
发表于 2022-1-4 22:29:30 | 显示全部楼层
感谢感谢,受益匪浅。。。。。。。。。。。。
GMT+8, 2025-12-3 05:58 , Processed in 0.059078 second(s), 14 queries , MemCached On.
