查看: 11300|回复: 4
[基础教程] zA1 hass配置更新, 同时请教fan speed的问题
发表于 2020-4-11 21:18:24 | 显示全部楼层 |阅读模式
对于zA1  之前使用的ha配置是用一个number input作为触发,配合自动化来完成对zA1的风速控制,这样用到3个自动化1个input 1个开关 很麻烦
研究了下hass的mqtt fan 改为此接入,代码如下:
需要将MACMAC 替换为设备的小写mac地址(如1234567890ab)
md格式下代码竟然出现一些符号被替换的问题.所以把配置贴在最后...
能够控制,但是并不完美,:
fan的风扇控制不能像拖动滚动条一样来配置,只能阶梯式配置.使用一个speed的列表来.默认可以配置low medium  high,
同时也可以直接用字符串来表示发送的命令{"mac":"MACMAC","speed":80},但是用字符串时在使用时列表里显示的也是这一串字符,对使用很不友好.
之后我又尝试了{"mac":"MACMAC","speed":30}(此处不用引号括起来),控制也有效,但是列表显示变成了[object Object]
求教大佬,如何使命令有效的情况下,能使列表显示为需要的自定义内容?
fan:
  - platform: mqtt
    state_topic: "device/za1/MACMAC/state"
    command_topic: "device/za1/MACMAC/set"
    state_value_template: >
      {%- if value_json.on == 0 -%}
        {"mac":"MACMAC","on":0}
      {%- else -%}
        {"mac":"MACMAC","on":1}
      {%- endif -%}
    speed_state_topic: "device/za1/MACMAC/state"
    speed_command_topic: "device/za1/MACMAC/set"
    speed_value_template: >
      {%- if value_json.speed < 25 -%}
        {"mac":"MACMAC","speed":10}
      {%- elif value_json.speed < 75  -%}
        {"mac":"MACMAC","speed":50}
      {%- else  -%}
        {"mac":"MACMAC","speed":100}
      {%- endif -%}
    qos: 0
    payload_on: '{"mac":"MACMAC","on":1}'
    payload_off: '{"mac":"MACMAC","on":0}'
    payload_low_speed: '{"mac":"MACMAC","speed":10}'
    payload_medium_speed: '{"mac":"MACMAC","speed":50}'
    payload_high_speed: '{"mac":"MACMAC","speed":100}'
    speeds:
      - low
      - medium
      - high
      - '{"mac":"MACMAC","speed":80}'
      - {"mac":"MACMAC","speed":30}
homeassistant:
  customize:
    fan.za1_MACMAC:
      friendly_name: zA1空气净化器
发表于 2020-4-12 10:48:54 | 显示全部楼层
打破大佬零回复
发表于 2020-4-12 10:59:10 来自手机 | 显示全部楼层
前排支持,感谢大佬!
发表于 2020-4-13 09:31:08 | 显示全部楼层
程序里把speed控制的 command 改为10/20/50这样?  不要"mac":"MACMAC","speed":这些
 楼主| 发表于 2020-4-13 09:36:01 | 显示全部楼层
直接改成10/20  那发送的数据也变成了10/20
是要发送的数据还是"mac":"MACMAC","speed":   显示的 直接是数值
GMT+8, 2025-12-31 00:23 , Processed in 1.595981 second(s), 11 queries , MemCached On.
