查看: 69019|回复: 32
2020年最新HA小米空气净化器2S接入指南
发表于 2020-4-8 18:41:12 | 显示全部楼层 |阅读模式
一、背景最近自己组了j3455黑群晖,所以重新弄了DOCKER版的HA(0.107.7),然后尴尬的是发现自己之前的空气净化器的配置凉凉了。
于是乎,原来是0.107.7的miio生成的服务名不一样了,特此更新给有需要的小伙伴。
二、成品展示
先晒晒成品,让大家有兴趣搞下去~
三、需要做啥
(一)通过HACS商店下载以下插件
card-mod、card-tools、vertical-stack-in-card、layout-card、slider-entity-row、fold-entity-row、secondaryinfo-entity-row
(二)把资源信息加入ui-lovelace文件
resources:
  - url: /local/community/lovelace-card-mod/card-mod.js
    type: module
  - url: /local/community/lovelace-card-tools/card-tools.js
    type: module
  - url: /local/community/vertical-stack-in-card/vertical-stack-in-card.js
    type: module
  - url: /local/community/lovelace-layout-card/layout-card.js
    type: module
  - url: /local/community/lovelace-slider-entity-row/slider-entity-row.js
    type: module
  - url: /local/community/lovelace-fold-entity-row/fold-entity-row.js
    type: module
  - url: /local/community/secondaryinfo-entity-row/secondaryinfo-entity-row.js
    type: module
(三)配置小米空净
在packages里新建一个yaml文件: xiaomi2s.yaml (3.95 KB, 下载次数: 433)
(四)配置ui-lovelace卡片
- type: custom:vertical-stack-in-card
            cards:
              - type: markdown
                title: 空净
                style: |
                  ha-card {
                    --paper-item-icon-color: Gainsboro;
                    --primary-text-color: ##104E8B;
                    --secondary-text-color: #B3E5FC;
                    background:rgba(255,255,255,0);
                  .card-header{
                    background: url(/local/images/card/ha-card-kj1.jpg);
                    color: white;
                content: |
                  <br>
              - type: entities
                show_header_toggle: false
                style: |
                  ha-card {
                    --primary-text-color: black;
                    --secondary-text-color: gray;
                entities:
                  - entity: fan.xiaomi_air_purifier_2s
                    type: 'custom:secondaryinfo-entity-row'
                    secondary_info: >-
                      滤芯已用:[[ fan.xiaomi_air_purifier_2s.attributes.filter_hours_used ]]小时,剩余:[[ fan.xiaomi_air_purifier_2s.attributes.filter_life_remaining ]]%
                  - type: custom:slider-entity-row
                    entity: input_select.xiaomi_ap_mode
                    icon: mdi:air-conditioner
              - type: glance
                show_state: false
                style: |
                  ha-card {
                    --paper-item-icon-color: Black;
                aspect_ratio: 492:232
                entities:
                  - entity: switch.xiaomi_ap_buzzer
                    tap_action:
                      action: toggle
                  - entity: switch.xiaomi_ap_light
                    tap_action:
                      action: toggle
                  - entity: switch.xiaomi_ap_childlock
                    tap_action:
                      action: toggle
              - type: glance
                style: |
                  ha-card {
                entities:
                  - sensor.xiaomi_ap_aqi
                  - sensor.xiaomi_ap_temp
                  - sensor.xiaomi_ap_humid
(五)完事重启运行。
最后2020.7.14更新,前段时间忙着结婚哈哈。忘了给评论里的兄dei们放附件了。把hacs里涉及的插件和顶图都传上来了哦。
顶图.zip
18.04 KB, 下载次数: 182
community.zip
93.33 KB, 下载次数: 246
参与人数 1金钱 +20 HASS币 +20 收起 理由
+ 20 + 20 膜拜大神!
发表于 2020-4-8 21:58:38 | 显示全部楼层
挺漂亮。试试pro能用否
发表于 2020-4-8 22:24:52 | 显示全部楼层
楼主 能否把那几个 插件 发一下。没装hacs
 楼主| 发表于 2020-4-9 11:09:40 | 显示全部楼层
好嘞,今晚回家给你发
参与人数 1金钱 +1 收起 理由
yylwhy + 1 大佬别忘了
发表于 2020-4-10 23:20:22 | 显示全部楼层
卡片很好看!膜拜
发表于 2020-4-11 22:16:48 | 显示全部楼层
如果是小米2 空净可以用这个么 需要修改啥呢大佬
发表于 2020-4-14 17:42:32 | 显示全部楼层
可否补充下详细操作,比如如何设置ui和卡片?
发表于 2020-5-6 12:31:17 | 显示全部楼层
漂亮啊
回来试试
发表于 2020-6-3 21:39:08 | 显示全部楼层
楼主接入过HOMEKIT吗,是不是只能调风速来改变运行模式?
发表于 2020-6-18 18:41:19 | 显示全部楼层
顶部图片分享下
GMT+8, 2026-1-18 06:19 , Processed in 1.087937 second(s), 21 queries , MemCached On.
