楼主: xuyang
[进阶教程] (8266+CC2530+CC2591)zigbee无线网关制作超简单!
发表于 2020-7-10 07:50:05 | 显示全部楼层
来学习一下,内容感觉不错
发表于 2020-7-11 23:31:49 | 显示全部楼层
萌新前来学习
发表于 2020-7-14 15:08:41 | 显示全部楼层
学习大佬
发表于 2020-7-21 15:28:37 | 显示全部楼层
猩猩点灯 发表于 2020-5-12 21:00
大佬知道下面这个报错是什么原因吗?
zigbee2mqtt:info  2020-05-12 20:53:20: Logging to console and dir ...
我安装也遇到这个问题,你解决了没?
发表于 2020-7-31 17:28:22 | 显示全部楼层
学习大佬
发表于 2020-8-2 16:43:55 来自手机 | 显示全部楼层
学习学习
发表于 2020-10-5 17:25:08 | 显示全部楼层
大佬知道下面这个报错是什么原因吗?
2531刷对固件了吗?
发表于 2020-10-5 17:26:28 | 显示全部楼层
wang3356 发表于 2020-7-21 15:28
我安装也遇到这个问题,你解决了没?
2531网关固件没刷好!
发表于 2020-10-5 18:35:24 | 显示全部楼层
我和你一样为啥不行啊还要设置啥吗
发表于 2020-10-16 17:42:05 | 显示全部楼层
我安装教程做的中Z2M(和你一样的东东,但是就是联不上去,你能帮我 看看吗?
ng '/app/data' as data directory
> [email protected] start /app
> node index.js
Zigbee2MQTT:error 2020-10-16 17:39:24: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2020-10-16 17:39:24: Failed to start zigbee
Zigbee2MQTT:error 2020-10-16 17:39:24: Exiting...
Zigbee2MQTT:error 2020-10-16 17:39:24: Error: Failed to connect to the adapter (Error: SRSP - SYS - ping after 6000ms)
    at ZStackAdapter.<anonymous> (/app/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:92:31)
    at Generator.throw (<anonymous>)
    at rejected (/app/node_modules/zigbee-herdsman/dist/adapter/z-stack/adapter/zStackAdapter.js:25:65)
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! [email protected] start: `node index.js`
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the [email protected] start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! A complete log of this run can be found in:
npm ERR!     /root/.npm/_logs/2020-10-16T09_39_24_555Z-debug.log
GMT+8, 2026-1-12 10:37 , Processed in 1.787371 second(s), 11 queries , MemCached On.
