楼主: xuyang
[进阶教程] (8266+CC2530+CC2591)zigbee无线网关制作超简单!
发表于 2020-5-11 02:19:42 | 显示全部楼层
感谢感谢,大佬。
发表于 2020-5-11 11:10:20 | 显示全部楼层
刚好手头有8266,看来再买个2530就行了啊
发表于 2020-5-11 11:12:47 | 显示全部楼层
谢谢楼主分享    看看教程
发表于 2020-5-11 11:18:59 | 显示全部楼层
大神,佩服!
发表于 2020-5-11 12:44:24 | 显示全部楼层
学习一下
发表于 2020-5-11 13:17:39 | 显示全部楼层
先支持再学习
发表于 2020-5-11 15:41:38 | 显示全部楼层
学习大佬
发表于 2020-5-12 21:00:31 | 显示全部楼层
大佬知道下面这个报错是什么原因吗?
zigbee2mqtt:info  2020-05-12 20:53:20: Logging to console and directory: '/share/zigbee2mqtt/log/2020-05-12.20-53-20' filename: log.txt
zigbee2mqtt:info  2020-05-12 20:53:21: Starting zigbee2mqtt version 1.13.0-dev (commit #)
zigbee2mqtt:info  2020-05-12 20:53:21: Starting zigbee-herdsman...
zigbee2mqtt:error 2020-05-12 20:55:31: Error while starting zigbee-herdsman
zigbee2mqtt:error 2020-05-12 20:55:31: Failed to start zigbee
zigbee2mqtt:error 2020-05-12 20:55:31: Exiting...
zigbee2mqtt:error 2020-05-12 20:55:31: Error: Error while opening socket
    at Socket.<anonymous> (/app/node_modules/zigbee-herdsman/dist/adapter/z-stack/znp/znp.js:162:28)
    at Socket.emit (events.js:228:7)
    at emitErrorNT (internal/streams/destroy.js:92:8)
    at emitErrorAndCloseNT (internal/streams/destroy.js:60:3)
    at processTicksAndRejections (internal/process/task_queues.js:81:21)
npm
ERR!
code ELIFECYCLE
npm ERR! errno
npm
ERR! [email protected]-dev start: `node index.js`
npm ERR!
Exit status 1
npm ERR!
npm ERR! Failed at the [email protected]-dev start script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm
ERR! A complete log of this run can be found in:
npm ERR!     /root/.npm/_logs/2020-05-12T12_55_31_241Z-debug.log
2020-05-12T20:55:33: PM2 log: A
发表于 2020-5-12 22:48:28 | 显示全部楼层
学习一下
akon
发表于 2020-5-13 22:12:36 | 显示全部楼层
來學習學習!!`
GMT+8, 2026-1-12 08:48 , Processed in 0.209581 second(s), 11 queries , MemCached On.
