楼主: newspaper
[技术探讨] EIB KNX 空调适合国内
发表于 2020-6-25 09:59:39 | 显示全部楼层
yuyamin 发表于 2020-4-21 12:46
可加微信,直接发给你一个node-red模板进行测试
大佬我也想要,我家开发商把中央空调也连到了KNX总线上,但是KNX climate组件很难用,也测不到准确地址
发表于 2021-4-24 09:31:01 | 显示全部楼层
    climate:
    - name: "客厅地暖"                                # Room name
      temperature_address: '15/0/6'                  # Actual temperture
      temperature_step: 0.5                           # Home Assistant slider setting
      target_temperature_address: '14/0/3'           # Setpoint comfort input
      target_temperature_state_address: '15/0/3'
      setpoint_shift_address: "8/1/1"
      setpoint_shift_state_address: "8/1/1"
      min_temp: 15.0                                  # Min setting slider in Home Assistant
      max_temp: 35.0
      on_off_address: "13/0/1"
      on_off_state_address: "13/0/1"
      controller_modes: 'Heat'
      controller_mode_address: "0/0/0"
      controller_mode_state_address: "0/0/0"
     # controller_status_address: "1/0/1"
     # controller_status_state_address: "1/1/1"
    - name: "客厅空调"                                # Room name
      temperature_address: '15/0/16'                  # Actual temperture
      target_temperature_address: '14/0/13'           # Setpoint comfort input
      target_temperature_state_address: '15/0/13'
      setpoint_shift_address: "8/1/2"
      setpoint_shift_state_address: "8/1/2"
      max_temp: 35.0
      on_off_address: "14/0/11"
      on_off_state_address: "15/0/11"
      controller_modes: [ 'Cool',  'Heat', 'Fan only', 'Dry']
      controller_mode_address: "14/0/12"
      controller_mode_state_address: "15/0/12"
    - name: "主卧空调"                                # Room name
      temperature_address: '15/0/26'                  # Actual temperture
      target_temperature_address: '14/0/23'           # Setpoint comfort input
      target_temperature_state_address: '15/0/23'
      setpoint_shift_address: "8/1/3"
      setpoint_shift_state_address: "8/1/3"
      max_temp: 35.0
      on_off_address: "14/0/21"
      on_off_state_address: "15/0/21"
      controller_modes: [ 'Cool',  'Heat', 'Fan only', 'Dry', 'Auto', 'Off']
      controller_mode_address: "14/0/22"
      controller_mode_state_address: "15/0/22"
发表于 2022-5-14 20:36:02 来自手机 | 显示全部楼层
大佬能发我一份吗
发表于 2022-6-14 11:54:50 | 显示全部楼层
想请问一下您,风速是如何解决的呢?
发表于 2022-6-15 14:41:41 | 显示全部楼层
shenliushuai 发表于 2022-6-14 11:54
想请问一下您,风速是如何解决的呢?
knx:
  fan:
    - name: "空调风速"
      address: "9/0/1"
      state_address: "9/0/2"
发%数据,
knx:
  fan:
    - name: "风速"
      address: "9/0/1"
      max_step: "3"
加上max_step,应该是发0,1,2,3,出去
发表于 2022-6-15 15:55:40 | 显示全部楼层
嗯 谢谢大佬,试了,还要做转换数据类型不一样。
发表于 2022-6-16 10:30:48 | 显示全部楼层
你翻翻资料,用自定义数据格式看看行不行
发表于 2022-6-16 12:00:28 | 显示全部楼层
moocher 发表于 2022-6-16 10:30
你翻翻资料,用自定义数据格式看看行不行
好的  感谢
发表于 2022-6-18 21:58:11 | 显示全部楼层
max_step: "3"
发表于 2022-6-20 09:34:50 | 显示全部楼层
GMT+8, 2025-12-21 21:34 , Processed in 1.571680 second(s), 14 queries , MemCached On.
