查看: 9316|回复: 2
[求助] 论坛那个自动编译DC1排插固件的工具没用了吗??
发表于 2020-4-6 02:22:11 | 显示全部楼层 |阅读模式
我之前按照 https://bbs.hassbian.com/forum.p ... 24&extra=#pid317675 这个教程 成功刷了两个排插,现在想改参数,发现进行不下去了,出现下面的错误!!
Verbose mode can be enabled via `-v, --verbose` option
CONFIGURATION: https://docs.platformio.org/page/boards/espressif8266/csm64f02.html
PLATFORM: Espressif 8266 2.0.4 #96f514c > CHIPSEA CSM64F02
HARDWARE: ESP8266 80MHz, 80KB RAM, 2MB Flash
PACKAGES:
 - framework-arduinoespressif8266 2.20500.190223 (2.5.0)
 - tool-esptool 1.413.0 (4.13)
 - toolchain-xtensa 1.40802.0 (4.8.2)
LDF: Library Dependency Finder -> http://bit.ly/configure-pio-ldf
LDF Modes: Finder ~ chain, Compatibility ~ soft
LibraryManager: Installing esphome-core
git version 2.21.0.windows.1
Cloning into 'E:\esphome-tools-dc1-master\config_yaml\build\phicomm_dc2\.piolibdeps\phicomm_dc2\_tmp_installing-g8tsfm-package'...
Username for 'https://github.com': [email protected]
Password for 'https://[email protected]@github.com':
输了账号密码后  会出现
remote: Repository not found.
fatal: repository 'https://github.com/Samuel-0-0/esphome-core.git/' not found
PlatformioException: VCS: Could not process command ['git', 'clone', '--recursive', '--depth', '1', '--branch', 'dc1', 'https://github.com/Samuel-0-0/esphome-core.git', 'E:\\esphome-tools-dc1-master\\config_yaml\\build\\phicomm_dc2\\.piolibdeps\\phicomm_dc2\\_tmp_installing-g8tsfm-package']:
  File "E:\esphome-tools-dc1-master\Python27\lib\site-packages\platformio-4.3.1-py2.7.egg\platformio\builder\main.py", line 156:
    env.SConscript("$BUILD_SCRIPT")
  File "E:\esphome-tools-dc1-master\config_yaml\.platformio\packages\tool-scons\script\..\engine\SCons\Script\SConscript.py", line 541:
    return _SConscript(self.fs, *files, **subst_kw)
  File "E:\esphome-tools-dc1-master\config_yaml\.platformio\packages\tool-scons\script\..\engine\SCons\Script\SConscript.py", line 250:
    exec _file_ in call_stack[-1].globals
  File "E:\esphome-tools-dc1-master\config_yaml\.platformio\platforms\espressif8266\builder\main.py", line 267:
    target_elf = env.BuildProgram()
  File "E:\esphome-tools-dc1-master\config_yaml\.platformio\packages\tool-scons\script\..\engine\SCons\Environment.py", line 224:
mitu 手机认证
发表于 2020-4-6 11:19:28 | 显示全部楼层
发表于 2020-4-6 14:49:30 | 显示全部楼层
三木大神得 最新版需要esp编译。
GMT+8, 2025-11-7 22:59 , Processed in 0.513603 second(s), 5 queries , MemCached On.
