查看: 30590|回复: 27
[插件集成] HA插件从入门到入坑 - sensor入门编 1
教程狂人论坛风云人物突出贡献
发表于 2017-8-24 12:43:00 | 显示全部楼层 |阅读模式
下面这个是官方的sensor demo,实现了最简单的sensor。,在custom_components\sensor 路径下新建一个demo.py 将下面的代码复制、粘贴进去。
[pre]"""
Demo platform that has a couple of fake sensors.
For more details about this platform, please refer to the documentation
https://home-assistant.io/components/demo/
from homeassistant.const import ATTR_BATTERY_LEVEL, TEMP_CELSIUS
from homeassistant.helpers.entity import Entity
# pylint: disable=unused-argument
def setup_platform(hass, config, add_devices, discovery_info=None):
    """Set up the Demo sensors."""
    add_devices([
        DemoSensor('Outside Temperature', 15.6, TEMP_CELSIUS, 12),
        DemoSensor('Outside Humidity', 54, '%', None),
class DemoSensor(Entity):
    """Representation of a Demo sensor."""
    def __init__(self, name, state, unit_of_measurement, battery):
        """Initialize the sensor."""
        self._name = name
        self._state = state
        self._unit_of_measurement = unit_of_measurement
        self._battery = battery
    @property
    def should_poll(self):
        """No polling needed for a demo sensor."""
        return False
    @property
    def name(self):
        """Return the name of the sensor."""
        return self._name
    @property
    def state(self):
        """Return the state of the sensor."""
        return self._state
    @property
    def unit_of_measurement(self):
        """Return the unit this state is expressed in."""
        return self._unit_of_measurement
    @property
    def device_state_attributes(self):
        """Return the state attributes."""
        if self._battery:
            return {
                ATTR_BATTERY_LEVEL: self._battery,
            }[/pre]
在你的package文件夹里面新建一个 demo.yaml 并输入以下代码
[pre]sensor:
  platform: demo
这里的demo是与你新建的demo.py的文件名一致的。可根据自己的sensor改需要的名称。
重启HA,激动时刻。终于可以看见自己写的sensor了
然而并没什么卵用,这两个sensor都是固定数值,没有任何作用。
先熟悉一下插件的结构框架。
本期结束,下期将介绍如何将这个没什么卵用的demo sensor 改造成股票价格监控sensor。
下期链接
https://bbs.hassbian.com/thread-966-1-1.html
参与人数 2金钱 +24 收起 理由
Roger + 12 谢谢大神分享!
+ 12 谢谢大神分享!
发表于 2017-8-24 12:48:20 | 显示全部楼层
难得的好教程,谢谢lidicn大大的分享
发表于 2017-8-24 13:19:15 来自手机 | 显示全部楼层
适合小白的教程,谢谢
发表于 2017-8-24 14:05:48 | 显示全部楼层
学习一下!!!
发表于 2017-8-24 18:02:07 | 显示全部楼层
学习了!!!
amos
发表于 2017-8-24 19:48:41 来自手机 | 显示全部楼层
学习了,谢谢分享
发表于 2017-8-24 21:12:23 | 显示全部楼层
绝对大神养成级教程,学习了,期待下一期
发表于 2017-8-25 00:28:13 来自手机 | 显示全部楼层
进来学习的,谢谢分享!
发表于 2017-8-25 22:01:26 | 显示全部楼层
学习一下!!!
发表于 2017-8-26 07:47:32 来自手机 | 显示全部楼层
谢谢分享
GMT+8, 2025-12-17 13:51 , Processed in 0.060972 second(s), 13 queries , MemCached On.
