查看: 9392|回复: 1
[已解决] 关于service_template的使用问题
发表于 2020-3-29 20:41:50 | 显示全部楼层 |阅读模式
写了一个脚本,调用的时候总是提示域和名称不匹配
Error executing script script.fan_oscillating. Invalid data for call_service at pos 1: Service  does not match format <domain>.<name>
代码如下:
  fan_oscillating:
    alias: shufang fan osc
    sequence:
      - service_template: >
          {% if oscillating == True %}
            script.turn_on_study_fan_osc
          {% elif oscillating == False %}
            script.shufang_fan_speed
            data_template:
              speed: "{{ speed }}"
          {% endif %}
      - service: input_select.select_option
        data_template:
          entity_id: input_select.shufang_fan_osc
          option: "{{ oscillating }}"
怀疑还是service_template的使用方法不太对,另外一个类似脚本就没这个问题,对比了很长时间,也没法先什么区别,看不出是哪里的问题,向大神求教
  shufang_fan_speed:
    alias: shufang fan speed
    sequence:
          {% if speed == '1' %}
            script.turn_on_study_fan1
          {% elif speed == '2' %}
            script.turn_on_study_fan2
          {% elif speed == '3' %}
            script.turn_on_study_fan3
          {% elif speed == '4' %}
            script.turn_on_study_fan4
          {% elif speed == '5' %}
            script.turn_on_study_fan5
          {% elif speed == '6' %}
            script.turn_on_study_fan6
          {% else %}
            script.turn_off_study_fan
          {% endif %}
        data_template:
          entity_id: input_select.shufang_fan_speed
          option: "{{ speed }}"
 楼主| 发表于 2020-3-29 23:36:46 | 显示全部楼层
解决了,是少了一个else分支,没想到yaml对判断分支语句控制的这么严格
GMT+8, 2025-11-7 23:01 , Processed in 0.058906 second(s), 6 queries , MemCached On.
