查看: 4357|回复: 3
请高手指教
发表于 2020-3-25 18:03:24 | 显示全部楼层 |阅读模式
参照:https://bbs.hassbian.com/thread-8158-1-1.html
错误信息如下,请高手指教。谢谢。
root@ha:~# pip3 install --upgrade pip
  File "/usr/bin/pip3", line 6, in <module>
    from pip._internal import main
  File "/usr/lib/python3.7/site-packages/pip/_internal/__init__.py", line 40, in <module>
    from pip._internal.cli.autocompletion import autocomplete
  File "/usr/lib/python3.7/site-packages/pip/_internal/cli/autocompletion.py", line 8, in <module>
    from pip._internal.cli.main_parser import create_main_parser
  File "/usr/lib/python3.7/site-packages/pip/_internal/cli/main_parser.py", line 11, in <module>
    from pip._internal.commands import (
  File "/usr/lib/python3.7/site-packages/pip/_internal/commands/__init__.py", line 6, in <module>
    from pip._internal.commands.completion import CompletionCommand
  File "/usr/lib/python3.7/site-packages/pip/_internal/commands/completion.py", line 6, in <module>
    from pip._internal.cli.base_command import Command
  File "/usr/lib/python3.7/site-packages/pip/_internal/cli/base_command.py", line 26, in <module>
    from pip._internal.index import PackageFinder
ImportError: cannot import name 'PackageFinder' from 'pip._internal.index' (/usr/lib/python3.7/site-packages/pip/_internal/index/__init__.py)
发表于 2020-3-26 10:00:56 | 显示全部楼层
 楼主| 发表于 2020-3-26 11:46:48 | 显示全部楼层
neroxps 发表于 2020-3-26 10:00
https://lmgtfy.com/?q=cannot+import+name+%27PackageFinder%27+from+%27pip._internal.index%27+&s=b
链接出错。
 楼主| 发表于 2020-3-27 12:14:12 | 显示全部楼层
现在又出现了问题,baidu和Bing找了一天,就是不知道问题出在哪里。
GMT+8, 2025-12-25 01:07 , Processed in 0.053951 second(s), 15 queries , MemCached On.
