查看: 13307|回复: 7
[基础教程] 米家空调伴侣问题
发表于 2020-3-23 21:31:49 | 显示全部楼层 |阅读模式
请教下0.107.5是不是不持米家空调伴侣一代圆外型那种?试了好多方法也没成功。感谢。
发表于 2020-3-23 21:39:06 | 显示全部楼层
Unsupported Devices
Xiaomi Aqara Gateway (lumi.gateway.aqhm01), as it is not possible to activate dev mode in the Mi Home App.
Gateway Radio
Gateway Button
Xiaomi Mi Air Conditioning Companion (lumi.acpartner.v2)
Aqara Intelligent Air Conditioner Controller Hub (lumi.acpartner.v1)
Decoupled mode of the Aqara Wall Switches (Single & Double)
Additional alarm events of the Gas and Smoke Detector: Analog alarm, battery fault alarm (smoke detector only), sensitivity fault alarm, I2C communication failure
https://www.home-assistant.io/integrations/xiaomi_aqara/
 楼主| 发表于 2020-3-23 21:40:58 | 显示全部楼层
ooowuyaooo 发表于 2020-3-23 21:39
Unsupported Devices
Xiaomi Aqara Gateway (lumi.gateway.aqhm01), as it is not possible to activate de ...
??什么意思 ?
发表于 2020-3-23 21:41:59 | 显示全部楼层
不支持的设备 第一代空调伴侣acpartnetv1
 楼主| 发表于 2020-3-23 21:47:14 | 显示全部楼层
哦。好的,谢谢。
活跃会员
发表于 2020-3-23 22:52:48 | 显示全部楼层
 楼主| 发表于 2020-3-24 11:22:38 | 显示全部楼层
aktifin 发表于 2020-3-23 22:52
syssi大神有开发插件
https://github.com/syssi/xiaomi_airconditioningcompanion
能吗?网上有讲好象新版不支持,不知道是不是
 楼主| 发表于 2020-3-24 11:48:37 | 显示全部楼层
syssi大神有开发插件
的确支持,成功了,感谢。
GMT+8, 2025-12-15 23:59 , Processed in 1.279607 second(s), 11 queries , MemCached On.
