查看: 7873|回复: 0
大佬们看看这是什么情况
发表于 2020-3-22 12:03:51 | 显示全部楼层 |阅读模式
黑群晖装的hassio套件,log是这样:
2020-03-22 11:22:54 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=11 from 2020-03-22 02:45:37.857471)
然后上面一行没了出现:
2020-03-22 11:35:06 ERROR (SyncWorker_12) [concurrent.futures] exception calling callback for <Future at 0x7fea7303db50 state=finished returned Integration>
  File "/usr/local/lib/python3.7/concurrent/futures/_base.py", line 324, in _invoke_callbacks
    callback(self)
  File "/usr/local/lib/python3.7/asyncio/futures.py", line 365, in _call_set_state
    dest_loop.call_soon_threadsafe(_set_state, destination, source)
  File "/usr/local/lib/python3.7/asyncio/base_events.py", line 732, in call_soon_threadsafe
    self._check_closed()
  File "/usr/local/lib/python3.7/asyncio/base_events.py", line 479, in _check_closed
    raise RuntimeError('Event loop is closed')
RuntimeError: Event loop is closed
刘晶怎么个啥情况呀
GMT+8, 2025-11-7 02:19 , Processed in 0.283615 second(s), 4 queries , MemCached On.
