查看: 2415|回复: 1
[求助] 求助群辉套件中心安装Hassio的问题
发表于 2020-3-21 11:45:14 | 显示全部楼层 |阅读模式
按照论坛南柯醉一梦丶[HASS.IO] 群晖DSM安装Hassio(非虚拟机) [color=rgb(153, 153, 153) !important] https://bbs.hassbian.com/thread-7546-1-1.html  这篇帖子安装成功,但是运行不成功。麻烦大神给看看因为什么原因,在此感谢
[color=rgb(153, 153, 153) !important]日志
[color=rgb(153, 153, 153) !important]hassio_supervisor
datestreamcontent
2020-03-21 03:41:12stderr20-03-21 03:41:12 WARNING (MainThread) [supervisor.audio] Error on install Audio plugin. Retry in 30sec
2020-03-21 03:41:12stderr20-03-21 03:41:12 WARNING (MainThread) [supervisor.dns] Error on install CoreDNS plugin. Retry in 30sec
2020-03-21 03:41:12stderr20-03-21 03:41:12 WARNING (MainThread) [supervisor.updater] Can't fetch versions from https://version.home-assistant.io/stable.json:
2020-03-21 03:41:01stderr20-03-21 03:41:01 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
2020-03-21 03:40:31stderr20-03-21 03:40:31 WARNING (MainThread) [supervisor.audio] Error on install Audio plugin. Retry in 30sec
2020-03-21 03:40:31stderr20-03-21 03:40:31 WARNING (MainThread) [supervisor.dns] Error on install CoreDNS plugin. Retry in 30sec
2020-03-21 03:40:31stderr20-03-21 03:40:31 WARNING (MainThread) [supervisor.updater] Can't fetch versions from https://version.home-assistant.io/stable.json:
2020-03-21 03:40:20stderr20-03-21 03:40:20 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
2020-03-21 03:39:50stderr20-03-21 03:39:50 WARNING (MainThread) [supervisor.audio] Error on install Audio plugin. Retry in 30sec
2020-03-21 03:39:50stderr20-03-21 03:39:50 WARNING (MainThread) [supervisor.dns] Error on install CoreDNS plugin. Retry in 30sec
2020-03-21 03:39:50stderr20-03-21 03:39:50 WARNING (MainThread) [supervisor.updater] Can't fetch versions from https://version.home-assistant.io/stable.json:
2020-03-21 03:39:39stderr20-03-21 03:39:39 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
2020-03-21 03:39:09stderr20-03-21 03:39:09 WARNING (MainThread) [supervisor.audio] Error on install Audio plugin. Retry in 30sec
2020-03-21 03:39:09stderr20-03-21 03:39:09 WARNING (MainThread) [supervisor.dns] Error on install CoreDNS plugin. Retry in 30sec
2020-03-21 03:39:09stderr20-03-21 03:39:09 WARNING (MainThread) [supervisor.updater] Can't fetch versions from https://version.home-assistant.io/stable.json:
2020-03-21 03:38:58stderr20-03-21 03:38:58 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
2020-03-21 03:38:28stderr20-03-21 03:38:28 WARNING (MainThread) [supervisor.audio] Error on install Audio plugin. Retry in 30sec
2020-03-21 03:38:28stderr20-03-21 03:38:28 WARNING (MainThread) [supervisor.dns] Error on install CoreDNS plugin. Retry in 30sec
2020-03-21 03:38:28stderr20-03-21 03:38:28 WARNING (MainThread) [supervisor.updater] Can't fetch versions from https://version.home-assistant.io/stable.json:
2020-03-21 03:38:17stderr20-03-21 03:38:17 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
2020-03-21 03:37:47stderr20-03-21 03:37:47 WARNING (MainThread) [supervisor.audio] Error on install Audio plugin. Retry in 30sec
2020-03-21 03:37:47stderr20-03-21 03:37:47 WARNING (MainThread) [supervisor.dns] Error on install CoreDNS plugin. Retry in 30sec
2020-03-21 03:37:47stderr20-03-21 03:37:47 WARNING (MainThread) [supervisor.updater] Can't fetch versions from https://version.home-assistant.io/stable.json:
2020-03-21 03:37:36stderr20-03-21 03:37:36 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
2020-03-21 03:37:06stderr20-03-21 03:37:06 WARNING (MainThread) [supervisor.audio] Error on install Audio plugin. Retry in 30sec
2020-03-21 03:37:06stderr20-03-21 03:37:06 WARNING (MainThread) [supervisor.dns] Error on install CoreDNS plugin. Retry in 30sec
2020-03-21 03:37:06stderr20-03-21 03:37:06 WARNING (MainThread) [supervisor.updater] Can't fetch versions from https://version.home-assistant.io/stable.json:
2020-03-21 03:36:55stderr20-03-21 03:36:55 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
2020-03-21 03:36:25stderr20-03-21 03:36:25 WARNING (MainThread) [supervisor.audio] Error on install Audio plugin. Retry in 30sec
2020-03-21 03:36:25stderr20-03-21 03:36:25 WARNING (MainThread) [supervisor.dns] Error on install CoreDNS plugin. Retry in 30sec
2020-03-21 03:36:25stderr20-03-21 03:36:25 WARNING (MainThread) [supervisor.updater] Can't fetch versions from https://version.home-assistant.io/stable.json:
2020-03-21 03:36:14stderr20-03-21 03:36:14 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
2020-03-21 03:35:44stderr20-03-21 03:35:44 WARNING (MainThread) [supervisor.audio] Error on install Audio plugin. Retry in 30sec
2020-03-21 03:35:44stderr20-03-21 03:35:44 WARNING (MainThread) [supervisor.dns] Error on install CoreDNS plugin. Retry in 30sec
2020-03-21 03:35:44stderr20-03-21 03:35:44 WARNING (MainThread) [supervisor.updater] Can't fetch versions from https://version.home-assistant.io/stable.json:
2020-03-21 03:35:34stderr20-03-21 03:35:34 INFO (MainThread) [supervisor.audio] Setup Audio plugin
2020-03-21 03:35:34stderr20-03-21 03:35:34 INFO (MainThread) [supervisor.audio] No Audio plugin Docker image homeassistant/amd64-hassio-audio found.
2020-03-21 03:35:33stderr20-03-21 03:35:33 INFO (MainThread) [supervisor.updater] Fetch update data from https://version.home-assistant.io/stable.json
2020-03-21 03:35:33stderr20-03-21 03:35:33 INFO (MainThread) [supervisor.dns] Setup CoreDNS plugin
2020-03-21 03:35:33stderr20-03-21 03:35:33 INFO (MainThread) [supervisor.dns] No CoreDNS plugin Docker image homeassistant/amd64-hassio-dns found.
2020-03-21 03:35:33stderr20-03-21 03:35:33 INFO (MainThread) [supervisor.host.apparmor] AppArmor is not enabled on host
2020-03-21 03:35:33stderr20-03-21 03:35:33 INFO (MainThread) [supervisor.host.apparmor] Load AppArmor Profiles: set()
2020-03-21 03:35:33stderr20-03-21 03:35:33 INFO (MainThread) [supervisor.host.sound] Update PulseAudio information
2020-03-21 03:35:33stderr20-03-21 03:35:33 WARNING (MainThread) [supervisor.dbus.nmi_dns] No DnsManager support on the host. Local DNS functions have been disabled.
2020-03-21 03:35:33stderr20-03-21 03:35:33 WARNING (MainThread) [supervisor.dbus.rauc] Host has no rauc support. OTA updates have been disabled.
2020-03-21 03:35:33stderr20-03-21 03:35:33 WARNING (MainThread) [supervisor.dbus.hostname] No hostname support on the host. Hostname functions have been disabled.
2020-03-21 03:35:33stderr20-03-21 03:35:33 WARNING (MainThread) [supervisor.dbus.systemd] No systemd support on the host. Host control has been disabled.
2020-03-21 03:35:33stderr20-03-21 03:35:33 INFO (MainThread) [__main__] Setup Supervisor
2020-03-21 03:35:32stderr20-03-21 03:35:32 INFO (SyncWorker_0) [supervisor.docker.supervisor] Connect Supervisor to hassio Network
2020-03-21 03:35:32stderr20-03-21 03:35:32 INFO (SyncWorker_0) [supervisor.docker.supervisor] Attach to Supervisor homeassistant/amd64-hassio-supervisor with version 209
2020-03-21 03:35:24stderr20-03-21 03:35:24 INFO (MainThread) [supervisor.docker.network] Can't find Supervisor network, create new network
2020-03-21 03:35:24stderr20-03-21 03:35:24 INFO (MainThread) [__main__] Initialize Supervisor setup
2020-03-21 03:35:18stdout[services.d] done.
2020-03-21 03:35:18stdout[services.d] starting services
2020-03-21 03:35:18stdout[cont-init.d] done.
2020-03-21 03:35:18stdout[cont-init.d] udev.sh: exited 0.
2020-03-21 03:35:16stderr[03:35:16] INFO: Update udev informations
2020-03-21 03:35:15stdout[cont-init.d] udev.sh: executing...
2020-03-21 03:35:15stdout[cont-init.d] executing container initialization scripts...
2020-03-21 03:35:15stdout[fix-attrs.d] done.
2020-03-21 03:35:15stdout[fix-attrs.d] applying ownership & permissions fixes...
2020-03-21 03:35:15stdout[s6-init] ensuring user provided files have correct perms...exited 0.
2020-03-21 03:35:15stdout[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
发表于 2020-3-21 16:19:37 | 显示全部楼层
群晖就是虚拟机目前是比较好弄的,其他什么套件,都是很久很久的了。
GMT+8, 2025-12-23 14:10 , Processed in 1.275597 second(s), 9 queries , MemCached On.
