楼主: sony804
[技术探讨] 想玩玩ESPHOME,搞了整整一天,坑太大了
活跃会员教程狂人卓越贡献
发表于 2020-3-7 23:23:25 | 显示全部楼层
neroxps 发表于 2020-3-7 19:19
那是你刚好没用到某些依赖。
请教一下,那我在x86上用docker安装esphome的话是不是能够直接避坑,谢谢您的回复~
发表于 2020-3-9 08:37:12 | 显示全部楼层
TwoOne 发表于 2020-3-7 23:23
请教一下,那我在x86上用docker安装esphome的话是不是能够直接避坑,谢谢您的回复~ ...
YES
Tam 手机认证
发表于 2020-4-14 14:35:41 | 显示全部楼层
发表于 2020-5-12 22:44:47 | 显示全部楼层
WIN10里装好,在网页中无法编译和UPLOAD, 但在命令行中 是可以运行的,注意路径和文件名,再加上命令就行了。我一直是在WIN10 中用 网页编辑yaml文件,然后在命令行中使用:run/compile/upload 很方便的。
发表于 2021-5-9 13:43:25 | 显示全部楼层
peter5858 发表于 2020-3-7 10:00
用群晖的docker装esphome分分钟钟就可以装好,没你说的那样麻烦,倒是装hassio.io我搞了两天,死活主程序启 ...
现在我还在坑里面,重新安装了几十次了,死活不行,现在插件中心都看不见了,什么问题。Logger: aiohttp.server
Source: helpers/system_info.py:49
First occurred: 上午11:40:28 (5 occurrences)
Last logged: 上午11:48:45
Error handling request
  File "/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py", line 422, in _handle_request
    resp = await self._request_handler(request)
  File "/usr/local/lib/python3.8/site-packages/aiohttp/web_app.py", line 499, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.8/site-packages/aiohttp/web_middlewares.py", line 119, in impl
    return await handler(request)
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 56, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 18, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 74, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 135, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 131, in handle
    result = await result
  File "/usr/src/homeassistant/homeassistant/components/api/__init__.py", line 186, in get
    system_info = await async_get_system_info(hass)
  File "/usr/src/homeassistant/homeassistant/helpers/system_info.py", line 49, in async_get_system_info
    info_object["supervisor"] = info.get("supervisor")
AttributeError: 'NoneType' object has no attribute 'get'
发表于 2021-5-9 16:38:57 | 显示全部楼层
zhouhui920 发表于 2021-5-9 13:43
现在我还在坑里面,重新安装了几十次了,死活不行,现在插件中心都看不见了,什么问题。Logger: aiohttp. ...
拉取這个镜像 https://registry.hub.docker.com/r/esphome/esphome/
homeesp版本是1.15.3群晖里安装ha可能用虚拟机比较好,我是没用群晖安装ha觉得费电,噪声大,还是在N1上安装的hassio(增容了的现在是64G)很稳定。
发表于 2021-5-9 16:49:47 | 显示全部楼层
homeesp版本是1.15.3群晖里安装ha可 ...
感谢终于解决了,不用一键安装,太多问题了,直接docker里面搜索下载直接使用,才一个容器运行,原来有7个容器运行还老进不去界面,密码弄好,第二部死活进不去。现在直接使用新安装在集成添加。
发表于 2021-5-9 17:57:08 | 显示全部楼层
docker秒空气。哈哈
GMT+8, 2025-12-29 00:16 , Processed in 0.632068 second(s), 11 queries , MemCached On.
