查看: 7267|回复: 6
求助各位大神,HACS装不了
theo
发表于 2020-3-2 20:01:30 | 显示全部楼层 |阅读模式
我用的是armbian+docker
错误日志:
2020-03-02 19:17:56 ERROR (MainThread) [homeassistant.components.hassio] Component error: hacs - No module named 'aiogithubapi'
#configuration.yaml配置
hacs:
  token: c85dc07ace58f562fa8ad83807036fbffe123123
  appdaemon: true
python_script:
frontend:
  themes: !include_dir_merge_named themes
#hacs的__init__.py
Custom element manager for community created elements.
For more details about this integration, please refer to the documentation at
https://hacs.xyz/
import voluptuous as vol
from aiogithubapi import AIOGitHub
from homeassistant import config_entries
from homeassistant.const import EVENT_HOMEASSISTANT_START
from homeassistant.const import __version__ as HAVERSION
from homeassistant.components.lovelace import system_health_info
from homeassistant.exceptions import ConfigEntryNotReady, ServiceNotFound
from homeassistant.helpers.aiohttp_client import async_create_clientsession
from homeassistant.helpers.event import async_call_later
from custom_components.hacs.configuration_schema import (
    hacs_base_config_schema,
    hacs_config_option_schema,
from custom_components.hacs.const import DOMAIN, ELEMENT_TYPES, STARTUP, VERSION
from custom_components.hacs.constrains import check_constans, check_requirements
from custom_components.hacs.hacsbase.configuration import Configuration
from custom_components.hacs.hacsbase.data import HacsData
from custom_components.hacs.setup import (
    add_sensor,
    load_hacs_repository,
    setup_frontend,
from custom_components.hacs.globals import get_hacs
# from custom_components.hacs.helpers.network import internet_connectivity_check
SCHEMA = hacs_base_config_schema()
SCHEMA[vol.Optional("options")] = hacs_config_option_schema()
CONFIG_SCHEMA = vol.Schema({DOMAIN: SCHEMA}, extra=vol.ALLOW_EXTRA)
async def async_setup(hass, config):
    """Set up this integration using yaml."""
    hacs = get_hacs()
    if DOMAIN not in config:
        return True
    hass.data[DOMAIN] = config
    hacs.hass = hass
    hacs.session = async_create_clientsession(hass)
    hacs.configuration = Configuration.from_dict(
        config[DOMAIN], config[DOMAIN].get("options")
    hacs.configuration.config = config
    hacs.configuration.config_type = "yaml"
    await startup_wrapper_for_yaml()
    hass.async_create_task(
        hass.config_entries.flow.async_init(
            DOMAIN, context={"source": config_entries.SOURCE_IMPORT}, data={}
    return True
async def async_setup_entry(hass, config_entry):
    """Set up this integration using UI."""
    hacs = get_hacs()
    conf = hass.data.get(DOMAIN)
    if config_entry.source == config_entries.SOURCE_IMPORT:
        if conf is None:
                hass.config_entries.async_remove(config_entry.entry_id)
        return False
    hacs.hass = hass
        config_entry.data, config_entry.options
    hacs.configuration.config_type = "flow"
    hacs.configuration.config_entry = config_entry
    config_entry.add_update_listener(reload_hacs)
    startup_result = await hacs_startup()
    if not startup_result:
        hacs.system.disabled = True
        raise ConfigEntryNotReady
    hacs.system.disabled = False
    return startup_result
async def startup_wrapper_for_yaml():
    """Startup wrapper for yaml config."""
    hacs = get_hacs()
        hacs.hass.components.frontend.async_remove_panel(
            hacs.configuration.sidepanel_title.lower()
            .replace(" ", "_")
            .replace("-", "_")
        hacs.logger.info("Could not setup HACS, trying again in 15 min")
        async_call_later(hacs.hass, 900, startup_wrapper_for_yaml())
        return
async def hacs_startup():
    """HACS startup tasks."""
    hacs = get_hacs()
    if not check_requirements():
        return False
    if hacs.configuration.debug:
        try:
            await hacs.hass.services.async_call(
                "logger", "set_level", {"hacs": "debug"}
        except ServiceNotFound:
            hacs.logger.error(
                "Could not set logging level to debug, logger is not enabled"
    lovelace_info = await system_health_info(hacs.hass)
    hacs.logger.debug(f"Configuration type: {hacs.configuration.config_type}")
    hacs.version = VERSION
    hacs.logger.info(STARTUP)
    hacs.system.config_path = hacs.hass.config.path()
    hacs.system.ha_version = HAVERSION
    hacs.system.lovelace_mode = lovelace_info.get("mode", "yaml")
    hacs.github = AIOGitHub(
        hacs.configuration.token, async_create_clientsession(hacs.hass)
    hacs.data = HacsData()
    # Check HACS Constrains
    if not await hacs.hass.async_add_executor_job(check_constans):
        if hacs.configuration.config_type == "flow":
            if hacs.configuration.config_entry is not None:
                await async_remove_entry(hacs.hass, hacs.configuration.config_entry)
        return False
    # Set up frontend
    await setup_frontend()
    #    if not await hacs.hass.async_add_executor_job(internet_connectivity_check):
    #        hacs.logger.critical("No network connectivity")
    #        return False
    # Load HACS
    if not await load_hacs_repository():
        return False
    # Restore from storefiles
    if not await hacs.data.restore():
        hacs_repo = hacs.get_by_name("hacs/integration")
        hacs_repo.pending_restart = True
        return False
    # Add aditional categories
    hacs.common.categories = ELEMENT_TYPES
    if hacs.configuration.appdaemon:
        hacs.common.categories.append("appdaemon")
    if hacs.configuration.python_script:
        hacs.configuration.python_script = False
        if hacs.configuration.config_type == "yaml":
            hacs.logger.warning(
                "Configuration option 'python_script' is deprecated and you should remove it from your configuration, HACS will know if you use 'python_script' in your Home Assistant configuration, this option will be removed in a future release."
    if hacs.configuration.theme:
        hacs.configuration.theme = False
                "Configuration option 'theme' is deprecated and you should remove it from your configuration, HACS will know if you use 'theme' in your Home Assistant configuration, this option will be removed in a future release."
    # Setup startup tasks
        hacs.hass.bus.async_listen_once(EVENT_HOMEASSISTANT_START, hacs.startup_tasks())
    else:
        async_call_later(hacs.hass, 5, hacs.startup_tasks())
    # Show the configuration
    hacs.configuration.print()
    # Set up sensor
    await hacs.hass.async_add_executor_job(add_sensor)
    # Mischief managed!
    return True
async def async_remove_entry(hass, config_entry):
    """Handle removal of an entry."""
    hacs = get_hacs()
    hacs.logger.info("Disabling HACS")
    hacs.logger.info("Removing recuring tasks")
    for task in hacs.recuring_tasks:
        task()
    hacs.logger.info("Removing sensor")
    try:
        await hass.config_entries.async_forward_entry_unload(config_entry, "sensor")
    except ValueError:
        pass
    hacs.logger.info("Removing sidepanel")
    try:
        hass.components.frontend.async_remove_panel("hacs")
    except AttributeError:
        pass
    hacs.logger.info("HACS is now disabled")
async def reload_hacs(hass, config_entry):
    """Reload HACS."""
    await async_remove_entry(hass, config_entry)
    await async_setup_entry(hass, config_entry)
发表于 2020-3-2 20:30:29 | 显示全部楼层
下载hacs包放在custom_components里面
https://github.com/hacs/integration
然后用配置里面的集成HACS
theo
 楼主| 发表于 2020-3-2 22:02:24 | 显示全部楼层
检查配置的时候出错,重启不了,提示没有aiogithubapi这个模块,不知道是不是配置文件没有定义还是怎么的
发表于 2020-3-2 22:31:55 | 显示全部楼层
https://hacs.xyz/docs/configuration/basic#add-your-configuration这里有详细的指导,可以先把配置文件里的hasc去掉,直接用集成里的hasc添加
theo
 楼主| 发表于 2020-3-2 22:43:59 | 显示全部楼层
yonghengdeshang 发表于 2020-3-2 22:31
https://hacs.xyz/docs/configuration/basic#add-your-configuration这里有详细的指导,可以先把配置文件里 ...
这个我有看了,但是集成里没有,甚至在https://www.home-assistant.io/integrations/#search/hacs 这里也没有,是不是我体质问题,node-red也启动不了,一直502: Bad Gateway 捕获.PNG 捕获2.PNG
发表于 2020-3-3 14:28:13 | 显示全部楼层
。。。。。https://hacs.xyz  好好看看教程
发表于 2020-5-11 22:23:06 | 显示全部楼层
配置文件放进去之后检查配置会报错,但是可以直接重启整个hassos,过程会略长,重启好了就有了
GMT+8, 2025-12-30 21:01 , Processed in 0.180568 second(s), 12 queries , MemCached On.
