楼主: hhpack
就没有一个人成功在openwrt里装上hass.io吗?
 楼主| 发表于 2020-3-3 16:58:44 | 显示全部楼层
47823439 发表于 2020-3-3 14:46
我装成功了,你试下!
docker run -d --name hassio_supervisor \
--restart unless-stopped \
我之前是折腾了很久,没有成功,后来没办法装了armbian docker再装openwrt,一套一套的下来折腾得够呛。。但让人意想不到的,我发现这么装起来的OPENWRT竟然比直接装的还要好用,真是奇了怪了。之前想着虚拟机里运行的玩意肯定不好使。。。开心。。
 楼主| 发表于 2020-3-3 17:00:00 | 显示全部楼层
倒。。我看错了,你也是装的ARMBIAN啊。。。
kemp
发表于 2020-3-19 08:42:52 | 显示全部楼层
我装成功了,你试下!
安装 是成功了但 好像不能启动 显示 hassio        false
日志
01 ERROR (SyncWorker_6) [supervisor.docker.interface] Can't install homeassistant/aarch64-homeassistant:landingpage -> 404 Client Error: Not Found ("manifest for homeassistant/aarch64-homeassistant:landingpage not found: manifest unknown: manifest unknown").[0m
stderr: [33m20-03-19 00:38:01 WARNING (MainThread) [supervisor.homeassistant] Fails install landingpage, retry after 30sec[0m
stderr: [32m20-03-19 00:38:31 INFO (SyncWorker_3) [supervisor.docker.interface] Pull image homeassistant/aarch64-homeassistant tag landingpage.[0m
stderr: [31m20-03-19 00:38:41 ERROR (SyncWorker_3) [supervisor.docker.interface] Can't install homeassistant/aarch64-homeassistant:landingpage -> 404 Client Error: Not Found ("manifest for homeassistant/aarch64-homeassistant:landingpage not found: manifest unknown: manifest unknown").[0m
stderr: [33m20-03-19 00:38:41 WARNING (MainThread) [supervisor.homeassistant] Fails install landingpage, retry after 30sec[0m
stderr: [32m20-03-19 00:39:11 INFO (SyncWorker_5) [supervisor.docker.interface] Pull image homeassistant/aarch64-homeassistant tag landingpage.[0m
stderr: [31m20-03-19 00:39:21 ERROR (SyncWorker_5) [supervisor.docker.interface] Can't install homeassistant/aarch64-homeassistant:landingpage -> 404 Client Error: Not Found ("manifest for homeassistant/aarch64-homeassistant:landingpage not found: manifest unknown: manifest unknown").[0m
stderr: [33m20-03-19 00:39:21 WARNING (MainThread) [supervisor.homeassistant] Fails install landingpage, retry after 30sec[0m
stderr: [32m20-03-19 00:39:51 INFO (SyncWorker_8) [supervisor.docker.interface] Pull image homeassistant/aarch64-homeassistant tag landingpage.[0m
stderr: [31m20-03-19 00:39:59 ERROR (SyncWorker_8) [supervisor.docker.interface] Can't install homeassistant/aarch64-homeassistant:landingpage -> 404 Client Error: Not Found ("manifest for homeassistant/aarch64-homeassistant:landingpage not found: manifest unknown: manifest unknown").[0m
stderr: [33m20-03-19 00:39:59 WARNING (MainThread) [supervisor.homeassistant] Fails install landingpage, retry after 30sec[0m
stderr: [32m20-03-19 00:40:29 INFO (SyncWorker_4) [supervisor.docker.interface] Pull image homeassistant/aarch64-homeassistant tag landingpage.[0m
stderr: [31m20-03-19 00:40:36 ERROR (SyncWorker_4) [supervisor.docker.interface] Can't install homeassistant/aarch64-homeassistant:landingpage -> 404 Client Error: Not Found ("manifest for homeassistant/aarch64-homeassistant:landingpage not found: manifest unknown: manifest unknown").[0m
stderr: [33m20-03-19 00:40:36 WARNING (MainThread) [supervisor.homeassistant] Fails install landingpage, retry after 30sec[0m
stderr: [32m20-03-19 00:41:06 INFO (SyncWorker_2) [supervisor.docker.interface] Pull image homeassistant/aarch64-homeassistant tag landingpage.[0m
stderr: [31m20-03-19 00:41:17 ERROR (SyncWorker_2) [supervisor.docker.interface] Can't install homeassistant/aarch64-homeassistant:landingpage -> 404 Client Error: Not Found ("manifest for homeassistant/aarch64-homeassistant:landingpage not found: manifest unknown: manifest unknown").[0m
stderr: [33m20-03-19 00:41:17 WARNING (MainThread) [supervisor.homeassistant] Fails install landingpage, retry after 30sec[0m
stderr: s6-svscanctl: fatal: unable to control /var/run/s6/services: supervisor not listening
发表于 2020-3-19 11:00:17 | 显示全部楼层
Openwrt装hassio教程我去年就发过了……
发表于 2020-5-24 10:21:42 | 显示全部楼层
我装成功了,你试下!
谢谢大佬 已经跑起来了
XFZJ
发表于 2022-3-17 23:58:41 | 显示全部楼层
我装成功了,你试下!
点赞,标记--supervisor安装2
发表于 2022-5-24 10:36:13 | 显示全部楼层
https://zyyme.com/docker-home-assistant-hassio-supervisor.html
看x64的,我成了, openwrt编译了显卡和声卡驱动
GMT+8, 2026-1-19 07:10 , Processed in 0.967058 second(s), 13 queries , MemCached On.
