楼主: tda2030a
[集成接入] eWelink易微联通过局域网API连接HA 无需刷固件Sonoff设备连接HA
mcr 手机认证
发表于 2020-8-7 10:40:46 | 显示全部楼层
感谢分享!
发表于 2020-8-15 01:07:50 | 显示全部楼层
谢谢分享
发表于 2020-8-19 10:24:52 | 显示全部楼层
来学习学习
发表于 2020-9-17 12:01:48 | 显示全部楼层
大佬,我按照你的步骤做的也是报错,报错如下:
2020-09-17 11:55:35 ERROR (SyncWorker_3) [homeassistant.loader] Error parsing manifest.json file at /home/pi/.homeassistant/custom_components/sonoff/manifest.json: Expecting value: line 2 column 1 (char 1)
2020-09-17 11:55:35 ERROR (MainThread) [homeassistant.loader] Error loading custom_components.sonoff. Make sure all dependencies are installed
  File "/usr/local/lib/python3.8/dist-packages/homeassistant/loader.py", line 436, in _load_file
    module = importlib.import_module(path)
  File "/usr/lib/python3.8/importlib/__init__.py", line 127, in import_module
    return _bootstrap._gcd_import(name[level:], package, level)
  File "<frozen importlib._bootstrap>", line 1014, in _gcd_import
  File "<frozen importlib._bootstrap>", line 991, in _find_and_load
  File "<frozen importlib._bootstrap>", line 975, in _find_and_load_unlocked
  File "<frozen importlib._bootstrap>", line 671, in _load_unlocked
  File "<frozen importlib._bootstrap_external>", line 783, in exec_module
  File "<frozen importlib._bootstrap>", line 219, in _call_with_frames_removed
  File "/home/pi/.homeassistant/custom_components/sonoff/__init__.py", line 18, in <module>
    from . import utils
  File "/home/pi/.homeassistant/custom_components/sonoff/utils.py", line 17, in <module>
    from Crypto.Random import get_random_bytes
ImportError: cannot import name 'get_random_bytes' from 'Crypto.Random' (/usr/local/lib/python3.8/dist-packages/Crypto/Random/__init__.py)
2020-09-17 11:55:43 ERROR (MainThread) [homeassistant.loader] Error loading custom_components.sonoff. Make sure all dependencies are installed
    from . import utils
2020-09-17 11:55:43 ERROR (MainThread) [homeassistant.setup] Setup failed for sonoff: Integration not found.
发表于 2020-9-17 18:12:22 | 显示全部楼层
fliesyan 发表于 2020-2-29 14:03
補充1、版本要升級
楼主您好:
  我这边有个智能插座sonoff26的,我在github上下载了最新的插件,配置文件也更改了,然后报了这么个错误
错误如下:
2020-09-17 15:51:40 ERROR (MainThread) [homeassistant.bootstrap] Error setting up integration sonoff - received exception
File "/usr/local/lib/python3.8/dist-packages/homeassistant/setup.py", line 68, in async_setup_component
return await task # type: ignore
File "/usr/local/lib/python3.8/dist-packages/homeassistant/setup.py", line 137, in _async_setup_component
await async_process_deps_reqs(hass, config, integration)
File "/usr/local/lib/python3.8/dist-packages/homeassistant/setup.py", line 322, in async_process_deps_reqs
await requirements.async_get_integration_with_requirements(
File "/usr/local/lib/python3.8/dist-packages/homeassistant/requirements.py", line 77, in async_get_integration_with_requirements
await async_process_requirements(
File "/usr/local/lib/python3.8/dist-packages/homeassistant/requirements.py", line 124, in async_process_requirements
if pkg_util.is_installed(req):
File "/usr/local/lib/python3.8/dist-packages/homeassistant/util/package.py", line 54, in is_installed
return version(req.project_name) in req
File "/usr/lib/python3/dist-packages/pkg_resources/init.py", line 2978, in contains
return self.specifier.contains(item, prereleases=True)
File "/usr/lib/python3/dist-packages/pkg_resources/_vendor/packaging/specifiers.py", line 703, in contains
item = parse(item)
File "/usr/lib/python3/dist-packages/pkg_resources/_vendor/packaging/version.py", line 31, in parse
return Version(version)
File "/usr/lib/python3/dist-packages/pkg_resources/_vendor/packaging/version.py", line 200, in init
match = self._regex.search(version)
TypeError: expected string or bytes-like object
能否帮我看看哪里出了问题吗,下载的最新的插件是针对他那个设备的?我这边需要在代码里更改什么吗?求助!
发表于 2020-9-19 17:45:20 | 显示全部楼层
终于找到易微联的教程了,好好研究研究
cmmv
发表于 2020-10-15 13:31:57 | 显示全部楼层
这个太适合了。。手里好几个易微联呢
发表于 2020-10-23 18:44:32 来自手机 | 显示全部楼层
顶顶 ,之前的不能用了 现在又可以啦
发表于 2020-10-26 13:16:52 来自手机 | 显示全部楼层
好东西学习一下
发表于 2020-11-7 22:28:19 | 显示全部楼层
学习下怎么配置
GMT+8, 2025-12-16 20:05 , Processed in 1.287544 second(s), 11 queries , MemCached On.
