查看: 9728|回复: 5
[技术探讨] 大家的iPhone官方定位有成功的吗
发表于 2020-2-28 22:26:37 | 显示全部楼层 |阅读模式
我看官网描述的iPhone定位设置挺简单的,只需要安装好HA APP,并且配置好apple的定位服务但是我的定位状态一直是未知,HA像是没收到终端APP发来的GPS数据,有谁配置成功的吗,还有其他需要配置的地方吗
Location[color=var(--ifm-link-color)]#Overview
Location updates are sent from your device to Home Assistant in a number of situations:
  • When you enter or exit a [color=var(--ifm-link-color)]zone defined in Home Assistant. For Android ensure the zone based tracking toggle is enabled in App Configuration.
  • When an iBeacon is detected or lost (see [color=var(--ifm-link-color)]below).
  • When the app is opened and it was not already open in the background.
  • Via an automated background fetch.
  • When an update is requested via [color=var(--ifm-link-color)]special notification
  • When a [color=var(--ifm-link-color)]URL Handler link is opened.
  • When the app is called via a [color=var(--ifm-link-color)]X-Callback-URL.
  • When your devices detects a [color=var(--ifm-link-color)]significant location change.
  • Manually when the app is refreshed (swipe down when at the top of a page) or from the shortcut menu opened from 3D touching the app icon.
  • When an update is requested by [color=var(--ifm-link-color)]sending an intent.
You can check the cause of the most recent location update by checking the value of sensor.last_update_trigger
Depending on your set up, location data is sent directly from your phone to your Home Assistant instances or via the Home Assistant Cloud Service. This will depend on the URLs specified in the Connection section of the App Configuration menu. Location data is not sent via any other servers or organisations. Of course, if you decide not grant the Home Assistant Companion App location permission or if you subsequently remove the location permissions (
Settings>Privacy>Location Services or
Settings>Privacy>Permissions), no location data will be sent from your device to Home Assistant. It is important to note that none of the [color=var(--ifm-link-color)]sensors will work if location is disabled. An alternative is to disable the device_tracker.<device_name> entity from the [color=var(--ifm-link-color)]entity registry.
[color=var(--ifm-link-color)]#Getting started
Once you have installed and opened the Home Assistant Companion App for the first time, a new device_tracker. entity will be created. By default the entity will have a name of the form device_tracker.<device_ID> where <device_ID> is the device name you have set (
Settings>General>About or
Settings>About Phone). You can check the entity name within Home Assistant by visiting the Integration section of the Configuration page from the sidebar (swipe right if you're using the
Companion App) then clicking or tapping on the Mobile App integration for your device and scrolling through the list of entities. You can edit the entity's name attribute as you desire if needed.
发表于 2020-2-28 22:36:14 | 显示全部楼层
可以的,第一次连接时,在登录进入界面之前有选择是否允许通知与定位。如果没有可以重置APP。
 楼主| 发表于 2020-2-28 23:02:04 | 显示全部楼层
MX10085 发表于 2020-2-28 22:36
可以的,第一次连接时,在登录进入界面之前有选择是否允许通知与定位。如果没有可以重置APP。 ...
感谢回复,重置APP后果然可以定位了!
发表于 2020-2-28 23:21:17 | 显示全部楼层
还可以通过icloud 就是费电
 楼主| 发表于 2020-2-28 23:35:58 | 显示全部楼层
ghostist 发表于 2020-2-28 23:21
还可以通过icloud 就是费电
我现在能通过HA APP和owntracks来定位,准备对比一下哪个更省电,哪个更准确
发表于 2020-8-21 18:32:54 | 显示全部楼层
comeon_000 发表于 2020-2-28 23:35
我现在能通过HA APP和owntracks来定位,准备对比一下哪个更省电,哪个更准确 ...
owntracks 定位准吗
GMT+8, 2025-12-15 23:59 , Processed in 0.796969 second(s), 8 queries , MemCached On.
