查看: 9062|回复: 2
[已解决] 新人求助!配置文件添加packages:!include_dir_named packages报错
发表于 2017-8-19 15:53:09 | 显示全部楼层 |阅读模式
如题所示,下面是configuration.yaml部分内容
packages加上就会报错,下面是错误提示
Configuration Validation
Validate your configuration if you recently made some changes to your configuration and want to make sure that it is all valid.Configuration invalid.CHECK CONFIG
Testing configuration at /root/.homeassistant2017-08-19 03:44:08 ERROR (Thread-2) [homeassistant.util.yaml] Secret caiyun_forecast_url not defined2017-08-19 03:44:08 ERROR (Thread-2) [homeassistant.util.yaml] Secret caiyun_realtime_url not defined2017-08-19 03:44:09 INFO (MainThread) [homeassistant.setup] Setting up recorder2017-08-19 03:44:09 INFO (MainThread) [homeassistant.setup] Setting up http2017-08-19 03:44:09 INFO (MainThread) [homeassistant.setup] Setup of domain recorder took 0.0 seconds.2017-08-19 03:44:09 INFO (MainThread) [homeassistant.setup] Setup of domain http took 0.0 seconds.2017-08-19 03:44:09 INFO (MainThread) [homeassistant.setup] Setting up history2017-08-19 03:44:09 INFO (MainThread) [homeassistant.setup] Setting up websocket_api2017-08-19 03:44:09 INFO (MainThread) [homeassistant.setup] Setting up api2017-08-19 03:44:09 INFO (MainThread) [homeassistant.setup] Setup of domain history took 0.0 seconds.2017-08-19 03:44:09 INFO (MainThread) [homeassistant.setup] Setup of domain websocket_api took 0.0 seconds.2017-08-19 03:44:09 INFO (MainThread) [homeassistant.setup] Setup of domain api took 0.0 seconds.2017-08-19 03:44:09 INFO (MainThread) [homeassistant.setup] Setting up frontend2017-08-19 03:44:09 INFO (MainThread) [homeassistant.setup] Setup of domain frontend took 0.0 seconds.2017-08-19 03:44:09 INFO (MainThread) [homeassistant.setup] Setting up discovery2017-08-19 03:44:09 ERROR (MainThread) [homeassistant.loader] Unable to find component packages2017-08-19 03:44:09 ERROR (MainThread) [homeassistant.setup] Setup failed for packages: Component not found.2017-08-19 03:44:09 INFO (MainThread) [homeassistant.setup] Setting up group2017-08-19 03:44:09 INFO (MainThread) [homeassistant.setup] Setting up sensor2017-08-19 03:44:09 INFO (MainThread) [homeassistant.setup] Setting up sun2017-08-19 03:44:09 INFO (MainThread) [homeassistant.setup] Setting up updater2017-08-19 03:44:09 INFO (MainThread) [homeassistant.setup] Setup of domain discovery took 0.1 seconds.2017-08-19 03:44:09 INFO (MainThread) [homeassistant.setup] Setup of domain group took 0.1 seconds.2017-08-19 03:44:09 INFO (MainThread) [homeassistant.setup] Setup of domain sensor took 0.0 seconds.2017-08-19 03:44:09 INFO (MainThread) [homeassistant.setup] Setup of domain sun took 0.0 seconds.2017-08-19 03:44:09 INFO (MainThread) [homeassistant.setup] Setup of domain updater took 0.0 seconds.2017-08-19 03:44:09 INFO (MainThread) [homeassistant.setup] Setting up logbook2017-08-19 03:44:09 INFO (MainThread) [homeassistant.setup] Setting up tts2017-08-19 03:44:09 INFO (MainThread) [homeassistant.setup] Setting up config2017-08-19 03:44:09 INFO (MainThread) [homeassistant.setup] Setting up conversation2017-08-19 03:44:09 INFO (MainThread) [homeassistant.setup] Setup of domain logbook took 0.0 seconds.2017-08-19 03:44:09 INFO (MainThread) [homeassistant.setup] Setting up automation2017-08-19 03:44:09 INFO (MainThread) [homeassistant.setup] Setup of domain tts took 0.0 seconds.2017-08-19 03:44:09 INFO (MainThread) [homeassistant.setup] Setup of domain config took 0.0 seconds.2017-08-19 03:44:09 INFO (MainThread) [homeassistant.setup] Setup of domain conversation took 0.0 seconds.2017-08-19 03:44:09 INFO (MainThread) [homeassistant.setup] Setup of domain automation took 0.0 seconds.Failed config  General Errors:     - Component not found: packages    - Setup failed for packages: Component not found.Successful config (partial)
还有就是api_passowrd取消注释也会报错,
添加
System Monitor
# Example configuration.yaml entry
         - platform: systemmonitor
          resources:
              - type: disk_use_percent
              arg: /home
             - type: memory_free
也会报错,
请教各位是怎么一回事?系统是debian
发表于 2017-8-22 15:10:49 | 显示全部楼层
这句应该加到homeassistant:下面,不是跟homeassistant:平级。
 楼主| 发表于 2017-8-26 16:44:02 | 显示全部楼层
原来是这样,谢谢
GMT+8, 2025-12-25 15:39 , Processed in 0.127373 second(s), 13 queries , MemCached On.
