查看: 15095|回复: 14
[技术探讨] 【求助】【已解决】最新版添加homekit:后报错
Mr.G 手机认证
略懂一些皮毛而已!
发表于 2020-2-26 14:11:48 | 显示全部楼层 |阅读模式
2020-02-26 13:12:27 ERROR (MainThread) [homeassistant.core] Error doing job: Future exception was never retrieved
  File "/usr/lib/python3.7/concurrent/futures/thread.py", line 57, in run
  File "/usr/local/lib/python3.7/dist-packages/homeassistant/components/homekit/__init__.py", line 378, in start
    self.add_bridge_accessory(state)
  File "/usr/local/lib/python3.7/dist-packages/homeassistant/components/homekit/__init__.py", line 350, in add_bridge_accessory
    self.bridge.add_accessory(acc)
  File "/home/pi/.homeassistant/deps/lib/python3.7/site-packages/pyhap/accessory.py", line 354, in add_accessory
    raise ValueError("Duplicate AID found when attempting to add accessory")
ValueError: Duplicate AID found when attempting to add accessory
报错这个,通知中不显示homekit的8位code
Home Assistant版本0.105.3
在官方帮助文档中搜到相应错误代码的解决办法,但是不知如何解决
Mr.G 手机认证
略懂一些皮毛而已!
 楼主| 发表于 2020-2-26 16:11:34 | 显示全部楼层
求大神帮忙
发表于 2020-2-26 16:43:34 | 显示全部楼层
最新版的python是有问题的,
2020-02-25 13:20:19 WARNING (MainThread) [homeassistant.components.http] legacy_api_password support has been enabled. If you don't require it, remove the 'api_password' from your http config.
2020-02-25 13:20:20 ERROR (MainThread) [homeassistant.loader] Unable to find component auth_providers
2020-02-25 13:20:20 ERROR (MainThread) [homeassistant.setup] Setup failed for auth_providers: Component not found.
2020-02-25 13:20:27 ERROR (SyncWorker_1) [homeassistant.util.package] Unable to install package HAP-python==2.2.2: Command "/srv/homeassistant/homeassistant_venv/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-install-5rnsd7u6/curve25519-donna/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-record-2ux1yrc6/install-record.txt --single-version-externally-managed --compile --install-headers /srv/homeassistant/homeassistant_venv/include/site/python3.6/curve25519-donna" failed with error code 1 in /tmp/pip-install-5rnsd7u6/curve25519-donna/
2020-02-25 13:20:27 ERROR (MainThread) [homeassistant.requirements] Not initializing homekit because could not install requirement HAP-python==2.2.2
2020-02-25 13:20:27 ERROR (MainThread) [homeassistant.setup] Setup failed for homekit: Could not install all requirements.
如果你也是这样,
重新安装下python吧,
Mr.G 手机认证
略懂一些皮毛而已!
 楼主| 发表于 2020-2-26 17:04:21 | 显示全部楼层
xwencai 发表于 2020-2-26 16:43
最新版的python是有问题的,
2020-02-25 13:20:19 WARNING (MainThread) [homeassistant.components.http]  ...
我是homekit用不了,   跟你的不一样吧? 请问下你是什么问题呢?
发表于 2020-2-26 17:51:41 | 显示全部楼层
文档应该已经说了 你有 entity_id 重复了(自动转换时,抓取导致)
几个方向试试看
- 检查一下 entity_id 看看有没有重复状态
- 利用 Homekit: 排除的方法 排除掉可能的 entity 试试看
- 利用自定名称 把你的 entity 命名一下
Mr.G 手机认证
略懂一些皮毛而已!
 楼主| 发表于 2020-2-26 18:37:49 | 显示全部楼层
几个方向试试看
私聊发给你我QQ了,方便加我QQ帮我看下吗? 我看了下好像没有重复的
发表于 2020-2-26 18:47:06 来自手机 | 显示全部楼层
看不懂,既然你提到没有配对码,我觉得你要不要试试把  .homekit.state文件删了,重新连一遍homekit试试。
Mr.G 手机认证
略懂一些皮毛而已!
 楼主| 发表于 2020-2-26 18:51:04 | 显示全部楼层
wwwww911 发表于 2020-2-26 18:47
看不懂,既然你提到没有配对码,我觉得你要不要试试把  .homekit.state文件删了,重新连一遍homekit试试。 ...
根本没有这个文件啊,
发表于 2020-2-26 22:24:52 | 显示全部楼层
郭子漳 发表于 2020-2-26 18:51
根本没有这个文件啊,
这个是隐藏文件,用samba把homeassistant配置文件夹共享出来,显示全部文件就看到共享文件了
看错误日志是你有ID重复了,建议先就连入一个开关或者用include控制连入的设备一个个加进去测试。
Mr.G 手机认证
略懂一些皮毛而已!
 楼主| 发表于 2020-2-27 01:39:49 | 显示全部楼层
看错误日志 ...
关键是真的没有重复的,真是奇怪
GMT+8, 2025-12-31 05:09 , Processed in 0.216032 second(s), 14 queries , MemCached On.
