The following errors occured when building your dashboard:
- side_temperature: Error in widget definition '%s':
- side_temperature: parser says
- side_temperature: in "", line 2, column 10: entity: {{entity}} ^
- side_temperature: found unhashable key while constructing a mapping
- you_humidity: Error in widget definition '%s':
- you_humidity: parser says
- you_humidity: in "", line 2, column 10: entity: {{entity}} ^
- you_humidity: found unhashable key while constructing a mapping
- lidicn_presence: Error in widget definition '%s':
- lidicn_presence: parser says
- lidicn_presence: in "", line 9, column 14: dev_id: {{device}} ^
- lidicn_presence: found unhashable key while constructing a mapping
- lucy_presence: Error in widget definition '%s':
- lucy_presence: parser says
- lucy_presence: in "", line 9, column 14: dev_id: {{device}} ^
- lucy_presence: found unhashable key while constructing a mapping
- airpurifier: Error in widget definition '%s':
- airpurifier: parser says
- airpurifier: in "", line 2, column 10: entity: {{entity}} ^
- airpurifier: found unhashable key while constructing a mapping
- light_level: Error in widget definition '%s':
- light_level: parser says
- light_level: in "", line 2, column 10: entity: {{entity}} ^
- light_level: found unhashable key while constructing a mapping
- garage: Error in widget definition '%s':
- garage: parser says
- garage: in "", line 2, column 10: entity: {{entity}} ^
- garage: found unhashable key while constructing a mapping
