查看: 7333|回复: 4
[已解决] node-red启动老是失败,求高手指点,附log
发表于 2020-2-22 23:54:53 | 显示全部楼层 |阅读模式
Log
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
 Hass.io Add-on: Node-RED
 Flow-based programming for the Internet of Things
 Add-on version: 6.0.4
 You are running the latest version of this add-on.
 System: HassOS 3.10  (armv7 / raspberrypi3)
 Home Assistant version: 0.105.5
 Supervisor version: 201
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] nginx.sh: executing...
[cont-init.d] nginx.sh: exited 0.
[cont-init.d] node-red.sh: executing...
[23:40:49] INFO: Password is NOT in the Have I Been Pwned database! Nice!
[23:40:56] INFO: Password is NOT in the Have I Been Pwned database! Nice!
patching file nodes/ui_base.html
Hunk #1 succeeded at 1243 (offset 712 lines).
[cont-init.d] node-red.sh: exited 0.
[cont-init.d] user.sh: executing...
fetch http://dl-cdn.alpinelinux.org/alpine/v3.11/main/armv7/APKINDEX.tar.gz
fetch http://dl-cdn.alpinelinux.org/alpine/v3.11/community/armv7/APKINDEX.tar.gz
fetch http://dl-cdn.alpinelinux.org/alpine/edge/main/armv7/APKINDEX.tar.gz
fetch http://dl-cdn.alpinelinux.org/alpine/edge/community/armv7/APKINDEX.tar.gz
fetch http://dl-cdn.alpinelinux.org/alpine/edge/testing/armv7/APKINDEX.tar.gz
v3.11.3-75-gbcab687d4f [http://dl-cdn.alpinelinux.org/alpine/v3.11/main]
v3.11.3-76-ge0d9cb9d6e [http://dl-cdn.alpinelinux.org/alpine/v3.11/community]
v20200122-1475-gf7978c5004 [http://dl-cdn.alpinelinux.org/alpine/edge/main]
v20200122-1479-g593691024c [http://dl-cdn.alpinelinux.org/alpine/edge/community]
v20200122-1447-gb94680c470 [http://dl-cdn.alpinelinux.org/alpine/edge/testing]
OK: 25791 distinct packages available
ERROR: unsatisfiable constraints:
  f (missing):
    required by: world[f]
[23:47:27] FATAL: Failed installing system package f
[cont-init.d] user.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
                Oops! Something went wrong.
 We are so sorry, but something went terribly wrong when
 starting or running this add-on.
 Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
发表于 2020-2-23 11:16:52 | 显示全部楼层
已经放弃了hassio的nr,n1安装1880访问不了。。。好像是nginx arm64 lua的问问题。现在直接n1手动安装,真香
 楼主| 发表于 2020-2-23 14:12:31 | 显示全部楼层
白云纷飞 发表于 2020-2-23 11:16
已经放弃了hassio的nr,n1安装1880访问不了。。。好像是nginx arm64 lua的问问题。现在直接n1手动安装,真 ...
查出来了,是配置不正确的问题,已经可以正常运行
发表于 2020-2-23 16:33:35 | 显示全部楼层
1880端口能正常访问吗?
发表于 2021-2-13 16:48:28 | 显示全部楼层
怎么解决的啊
GMT+8, 2025-12-22 23:13 , Processed in 0.218050 second(s), 5 queries , MemCached On.
