楼主: suwill
[教程系列] 小爱同学->blinker-Node-RED虚拟设备接入homeassistant(已实现)
发表于 2020-3-5 11:17:15 | 显示全部楼层
suwill 发表于 2020-3-4 21:17
想获取到具体的指令,可以使用论坛里大佬写的读取小爱日志,用拦截词那种方式,受制于指定的设备(个人不 ...
等待你的红外研究结果,红外控制的话,就不用绕圈子了
发表于 2020-4-5 23:11:58 | 显示全部楼层
求助 安装节点报错 日志显示
2020-04-05T15:10:33.332Z [err]  ERR! request to https://registry.npmjs.org/node-red-contrib-bigtimer failed, reason: getaddrinfo EAI_AGAIN registry.npmjs.org
2020-04-05T15:10:33.349Z [err]
2020-04-05T15:10:33.349Z [err] npm
2020-04-05T15:10:33.350Z [err]
2020-04-05T15:10:33.350Z [err] ERR! A complete log of this run can be found in:
2020-04-05T15:10:33.350Z [err] npm
2020-04-05T15:10:33.350Z [err] ERR!     /root/.npm/_logs/2020-04-05T15_10_33_336Z-debug.log
2020-04-05T15:10:33.369Z rc=1
但是/root/.npm/目录下并没有_logs/文件夹  求教怎么处理
发表于 2024-9-26 13:53:49 | 显示全部楼层
能本地化不依赖外网吗
发表于 2024-11-24 22:12:09 | 显示全部楼层
搜索得到,但是安装部上,一直转圈圈
发表于 2024-11-24 22:17:18 | 显示全部楼层
日志里显示
2024-11-24T14:08:39.802Z 安装 : node-red-contrib-blinker-mqtt 1.0.6
2024-11-24T14:08:43.605Z npm install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --omit=dev --engine-strict [email protected]
2024-11-24T14:16:27.847Z [err] npm error code ETIMEDOUT
2024-11-24T14:16:27.851Z [err] npm error syscall connect
2024-11-24T14:16:27.854Z [err] npm error errno ETIMEDOUT
2024-11-24T14:16:27.918Z [err] npm error network request to https://registry.npmjs.org/node-red-contrib-blinker-mqtt failed, reason: connect ETIMEDOUT 2606:4700::6810:1822:443
2024-11-24T14:16:27.921Z [err] npm error network This is a problem related to network connectivity.
2024-11-24T14:16:27.921Z [err] npm error network In most cases you are behind a proxy or have bad network settings.
2024-11-24T14:16:27.921Z [err] npm error network If you are behind a proxy, please make sure that the
2024-11-24T14:16:27.921Z [err] npm error network 'proxy' config is set properly.  See: 'npm help config'
2024-11-24T14:16:27.959Z [err]
2024-11-24T14:16:27.961Z [err] npm error A complete log of this run can be found in: /root/.npm/_logs/2024-11-24T14_08_44_796Z-debug-0.log
2024-11-24T14:16:28.132Z rc=1
GMT+8, 2025-12-3 06:00 , Processed in 0.844303 second(s), 9 queries , MemCached On.
