查看: 8266|回复: 4
[已解决] 实体无法增加到HA
发表于 2020-2-20 01:45:17 | 显示全部楼层 |阅读模式
配置文件检查是OK的,重启HA后,开发者工具里的状态栏,实体里找不到新配置的zTC1传感器
我理解这个配置如果引用的东西不对,只要语法正确,都应该在HA中展示出来,最多就是状态不正确
奇怪的是一个配置文件里,以前配置的zM1没问题,看代码貌似也没啥错误,求大神指导~
 # zM1
  - platform: mqtt
    # friendly_name: 温度
    state_topic: 'device/zm1/b0f893226fed/sensor'
    unit_of_measurement: '°C'
    icon: 'mdi:thermometer'
    value_template: '{{ value_json.temperature }}'
  - platform: mqtt
    # friendly_name: 湿度
    unit_of_measurement: '%RH'
    icon: mdi:water-percent
    value_template: '{{ value_json.humidity }}'
  - platform: mqtt
    # friendly_name: PM25
    unit_of_measurement: 'μg/m³'
    icon: mdi:blur
    value_template: '{{ value_json.PM25 }}'
  - platform: mqtt
    # friendly_name: 甲醛
    unit_of_measurement: 'mg/m³'
    icon: mdi:chemical-weapon
    value_template: '{{ value_json.formaldehyde }}'
  # zTC1
  - platform: mqtt
    state_topic: 'device/ztc1/d0bae4635dde/sensor'
    unit_of_measurement: 'W'
    icon: mdi:gauge
    value_template: '{{ value_json.power }}'
  - platform: mqtt
    #unit_of_measurement: '秒'
    icon: mdi:gauge
    #value_template: '{{ value_json.total_time }}'
    value_template: >-
      {% set time = value_json.total_time %}
      {% set minutes = ((time % 3600) / 60) | int %}
      {% set hours = ((time % 86400) / 3600) | int %}
      {% set days = (time / 86400) | int %}
      {%- if time < 60 -%}
        <1分钟
      {%- else -%}
        {%- if days > 0 -%}
            {{ days }}天
        {%- endif -%}
        {%- if hours > 0 -%}
            {{ hours }}小时
        {%- endif -%}
        {%- if minutes > 0 -%}
            {{ minutes }}分钟
        {%- endif -%}
      {%- endif -%}
 楼主| 发表于 2020-2-20 15:52:07 来自手机 | 显示全部楼层
求大神帮忙看看是哪里的问题
 楼主| 发表于 2020-2-20 19:30:20 | 显示全部楼层
顶一下,困扰了一夜
 楼主| 发表于 2020-2-20 23:42:55 | 显示全部楼层
犯了超低级的错误,configration里的include居然没加对
发表于 2020-2-21 12:07:32 | 显示全部楼层
哈哈
GMT+8, 2025-12-24 08:46 , Processed in 0.106656 second(s), 5 queries , MemCached On.
