查看: 10985|回复: 9
[技术探讨] HASSIO安装完毕后进HA界面不能显示插件列表
发表于 2020-2-18 19:31:12 | 显示全部楼层 |阅读模式
默认的商店显示下面的错误
20-02-18 11:21:31 ERROR (MainThread) [hassio.store.git] Can't clone https://github.com/home-assistant/hassio-addons repository: Cmd('git') failed due to: exit code(128)
  cmdline: git clone --depth=1 --recursive --shallow-submodules -v https://github.com/home-assistant/hassio-addons /data/addons/core
  stderr: 'Cloning into '/data/addons/core'...
fatal: unable to access 'https://github.com/home-assistant/hassio-addons/': Failed to connect to github.com port 443: Operation timed out
20-02-18 11:21:31 ERROR (MainThread) [hassio.store] Can't load from repository core
20-02-18 11:21:31 ERROR (MainThread) [hassio.store.git] Can't clone https://github.com/hassio-addons/repository repository: Cmd('git') failed due to: exit code(128)
  cmdline: git clone --depth=1 --recursive --shallow-submodules -v https://github.com/hassio-addons/repository /data/addons/git/a0d7b954
  stderr: 'Cloning into '/data/addons/git/a0d7b954'...
fatal: unable to access 'https://github.com/hassio-addons/repository/': Failed to connect to github.com port 443: Operation timed out
20-02-18 11:21:31 ERROR (MainThread) [hassio.store] Can't load from repository https://github.com/hassio-addons/repository
然后我添加另外一个商店,又显示错误
20-02-18 11:24:55 ERROR (MainThread) [hassio.store.git] Can't clone https://addons.community/ repository: Cmd('git') failed due to: exit code(128)
  cmdline: git clone --depth=1 --recursive --shallow-submodules -v https://addons.community/ /data/addons/git/83ef7d75
  stderr: 'Cloning into '/data/addons/git/83ef7d75'...
fatal: repository 'https://addons.community/' not found
20-02-18 11:24:55 ERROR (MainThread) [hassio.store] Can't load from repository https://addons.community/
20-02-18 11:24:55 INFO (MainThread) [hassio.store] Load add-ons from store: 0 all - 0 new - 0 remove
现在的状态是DASHBOARD是空白的,然后ADD-ON STORE什么都没有。
我的环境是debian 10,安装https://bbs.hassbian.com/forum.php?mod=viewthread&tid=8507这个帖子的方法安装的HA,进去以后就是这个问题,请问一下如何解决呢?
 楼主| 发表于 2020-2-18 19:32:12 | 显示全部楼层
一般插件商店有哪些国内能用的地址呢?
发表于 2020-2-18 19:43:41 | 显示全部楼层
111
111
我的好用
 楼主| 发表于 2020-2-18 19:46:17 | 显示全部楼层
谢谢,第二个https://addons.community/我访问起来没问题,但是添加源就是主帖的第二个错误代码
 楼主| 发表于 2020-2-18 19:47:58 | 显示全部楼层
我的NODE-RED都研究完了,现在就是mqtt插件装不进去,也不知道怎么配置,这个插件市场又上不了,折腾了三四天了,还是部署环境上面,唉。。
发表于 2020-2-18 19:57:55 | 显示全部楼层
zxlch 发表于 2020-2-18 19:47
我的NODE-RED都研究完了,现在就是mqtt插件装不进去,也不知道怎么配置,这个插件市场又上不了,折腾了三四 ...
正好有时间  仔细爬楼看帖子吧
 楼主| 发表于 2020-2-18 19:59:25 | 显示全部楼层
yylwhy 发表于 2020-2-18 19:57
正好有时间  仔细爬楼看帖子吧
大家都用的一键安装,啥毛病没有,我各种安装方法都试了,还是这个问题
发表于 2020-2-19 11:14:14 | 显示全部楼层
zxlch 发表于 2020-2-18 19:59
大家都用的一键安装,啥毛病没有,我各种安装方法都试了,还是这个问题 ...
这个和一键脚本没关系,官方默认的 addons 代码是写死在 hassio初始化的时候,hassio 初始化的时候会自动向 github pull 官方的 addons 库,最近墙太高了,导致你的hassio pull 官方的 addons 库超时,所以hassio 就跳过没再继续pull。
 楼主| 发表于 2020-2-19 11:18:23 | 显示全部楼层
neroxps 发表于 2020-2-19 11:14
这个和一键脚本没关系,官方默认的 addons 代码是写死在 hassio初始化的时候,hassio 初始化的时候会自动 ...
谢谢版主,确实是这样,我用电信4G的网络就没问题了。电脑连4G网卡拖了一晚上才把插件拖下来,谢谢!
发表于 2020-2-19 16:30:47 | 显示全部楼层
墙太高了 慢慢来吧
GMT+8, 2025-12-31 15:28 , Processed in 0.416434 second(s), 11 queries , MemCached On.
