查看: 4877|回复: 4
[求助] HA一段时间出现无法访问
发表于 2020-2-17 12:04:55 | 显示全部楼层 |阅读模式
一键脚本安装HASSIO,ha总是一段时候后就无法访问,提示一下故障,重启后就正常
20-02-17 03:57:08 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].20-02-17 03:57:13 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize20-02-17 03:57:13 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered20-02-17 03:57:13 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].20-02-17 03:57:18 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize20-02-17 03:57:18 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered20-02-17 03:57:18 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].20-02-17 03:57:23 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize20-02-17 03:57:23 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered20-02-17 03:57:23 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].20-02-17 03:57:28 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize20-02-17 03:57:28 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered20-02-17 03:57:28 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].20-02-17 03:57:33 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize20-02-17 03:57:33 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered20-02-17 03:57:33 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].20-02-17 03:57:38 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize20-02-17 03:57:38 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered20-02-17 03:57:38 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].20-02-17 03:57:43 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize20-02-17 03:57:43 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered20-02-17 03:57:43 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].20-02-17 03:57:48 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize20-02-17 03:57:48 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered20-02-17 03:57:48 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].20-02-17 03:57:53 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize20-02-17 03:57:53 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered20-02-17 03:57:53 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].20-02-17 03:57:59 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize20-02-17 03:57:59 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered20-02-17 03:57:59 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].20-02-17 03:58:04 INFO (MainThread) [hassio.api.proxy] Home Assistant WebSocket API request initialize20-02-17 03:58:04 INFO (MainThread) [hassio.api.proxy] WebSocket access from a0d7b954_nodered20-02-17 03:58:04 ERROR (MainThread) [hassio.api.proxy] Client error on WebSocket API Cannot connect to host 172.30.32.1:8123 ssl:False [Connection refused].
发表于 2020-2-17 14:35:28 | 显示全部楼层
间隔多久出一次,像是HA服务器状态不正常
发表于 2020-2-17 15:17:06 | 显示全部楼层
树莓派吗? 用网线试试,别用Wi-Fi
 楼主| 发表于 2020-2-17 15:27:49 | 显示全部楼层
oriccheng 发表于 2020-2-17 15:17
树莓派吗? 用网线试试,别用Wi-Fi
N1,网线,用的一键脚本安装HASSIO
 楼主| 发表于 2020-2-17 15:28:55 | 显示全部楼层
时间不固定,有时候一两个小时,七八个小时也有
GMT+8, 2025-12-23 16:19 , Processed in 0.212819 second(s), 10 queries , MemCached On.
