查看: 2597|回复: 1
[已解决] 安装HA出一堆错误,,求大神看看。。。。。。。。。。
发表于 2020-2-15 02:22:25 | 显示全部楼层 |阅读模式
(已解决,组件没安装,先apt-get安装一堆依赖组件再安装HA,HA不会自己安装)安装的0.92.2,因为高版本的斐讯S7插件不工作,只能虚拟环境安装低版本。Ubuntu Bionic with Armbian Linux 5.1.0-aml-s905+python3.68,出错一堆啊,,,大神救命啊。
下面是完整安装输出信息:
(homeassistant_venv) root@aml:/srv/homeassistant# pip3 install homeassistant==0.92.2
Collecting homeassistant==0.92.2
  Downloading homeassistant-0.92.2-py3-none-any.whl (4.6 MB)
     |################################| 4.6 MB 248 kB/s
Collecting ruamel.yaml==0.15.91
  Downloading ruamel.yaml-0.15.91.tar.gz (309 kB)
     |################################| 309 kB 293 kB/s
Requirement already satisfied: certifi>=2018.04.16 in ./homeassistant_venv/lib/python3.6/site-packages (from homeassistant==0.92.2) (2019.11.28)
Collecting cryptography==2.6.1
  Downloading cryptography-2.6.1.tar.gz (491 kB)
     |################################| 491 kB 2.3 MB/s
  Installing build dependencies ... error
  ERROR: Command errored out with exit status 1:
   command: /srv/homeassistant/homeassistant_venv/bin/python3 /srv/homeassistant/homeassistant_venv/lib/python3.6/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-apsiwe30/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- 'setuptools>=18.5' wheel 'cffi>=1.8,!=1.11.3; python_implementation != '"'"'PyPy'"'"''
       cwd: None
  Complete output (75 lines):
  Collecting setuptools>=18.5
    Downloading setuptools-45.2.0-py3-none-any.whl (584 kB)
  Collecting wheel
    Downloading wheel-0.34.2-py2.py3-none-any.whl (26 kB)
  Collecting cffi!=1.11.3,>=1.8
    Downloading cffi-1.14.0.tar.gz (463 kB)
  Collecting pycparser
    Downloading pycparser-2.19.tar.gz (158 kB)
  Installing collected packages: setuptools, wheel, pycparser, cffi
      Running setup.py install for pycparser: started
      Running setup.py install for pycparser: finished with status 'done'
      Running setup.py install for cffi: started
      Running setup.py install for cffi: finished with status 'error'
       command: /srv/homeassistant/homeassistant_venv/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-rc35rff8/cffi/setup.py'"'"'; __file__='"'"'/tmp/pip-install-rc35rff8/cffi/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-0f6znqel/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-apsiwe30/overlay --compile --install-headers /srv/homeassistant/homeassistant_venv/include/site/python3.6/cffi
           cwd: /tmp/pip-install-rc35rff8/cffi/
      Complete output (56 lines):
      Package libffi was not found in the pkg-config search path.
      Perhaps you should add the directory containing `libffi.pc'
      to the PKG_CONFIG_PATH environment variable
      No package 'libffi' found
      running install
      running build
      running build_py
      creating build
      creating build/lib.linux-aarch64-3.6
      creating build/lib.linux-aarch64-3.6/cffi
      copying cffi/recompiler.py -> build/lib.linux-aarch64-3.6/cffi
      copying cffi/verifier.py -> build/lib.linux-aarch64-3.6/cffi
      copying cffi/cffi_opcode.py -> build/lib.linux-aarch64-3.6/cffi
      copying cffi/setuptools_ext.py -> build/lib.linux-aarch64-3.6/cffi
      copying cffi/__init__.py -> build/lib.linux-aarch64-3.6/cffi
      copying cffi/lock.py -> build/lib.linux-aarch64-3.6/cffi
      copying cffi/api.py -> build/lib.linux-aarch64-3.6/cffi
      copying cffi/vengine_gen.py -> build/lib.linux-aarch64-3.6/cffi
      copying cffi/pkgconfig.py -> build/lib.linux-aarch64-3.6/cffi
      copying cffi/ffiplatform.py -> build/lib.linux-aarch64-3.6/cffi
      copying cffi/cparser.py -> build/lib.linux-aarch64-3.6/cffi
      copying cffi/backend_ctypes.py -> build/lib.linux-aarch64-3.6/cffi
      copying cffi/error.py -> build/lib.linux-aarch64-3.6/cffi
      copying cffi/commontypes.py -> build/lib.linux-aarch64-3.6/cffi
      copying cffi/model.py -> build/lib.linux-aarch64-3.6/cffi
      copying cffi/vengine_cpy.py -> build/lib.linux-aarch64-3.6/cffi
      copying cffi/_cffi_include.h -> build/lib.linux-aarch64-3.6/cffi
      copying cffi/parse_c_type.h -> build/lib.linux-aarch64-3.6/cffi
      copying cffi/_embedding.h -> build/lib.linux-aarch64-3.6/cffi
      copying cffi/_cffi_errors.h -> build/lib.linux-aarch64-3.6/cffi
      running build_ext
      building '_cffi_backend' extension
      creating build/temp.linux-aarch64-3.6
      creating build/temp.linux-aarch64-3.6/c
      aarch64-linux-gnu-gcc -pthread -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -DUSE__THREAD -DHAVE_SYNC_SYNCHRONIZE -I/usr/include/ffi -I/usr/include/libffi -I/srv/homeassistant/homeassistant_venv/include -I/usr/include/python3.6m -c c/_cffi_backend.c -o build/temp.linux-aarch64-3.6/c/_cffi_backend.o
      c/_cffi_backend.c:15:10: fatal error: ffi.h: No such file or directory
       #include <ffi.h>
      compilation terminated.
      error: command 'aarch64-linux-gnu-gcc' failed with exit status 1
  ERROR: Command errored out with exit status 1: /srv/homeassistant/homeassistant_venv/bin/python3 -u -c 'import sys, setuptools, tokenize; sys.argv[0] = '"'"'/tmp/pip-install-rc35rff8/cffi/setup.py'"'"'; __file__='"'"'/tmp/pip-install-rc35rff8/cffi/setup.py'"'"';f=getattr(tokenize, '"'"'open'"'"', open)(__file__);code=f.read().replace('"'"'\r\n'"'"', '"'"'\n'"'"');f.close();exec(compile(code, __file__, '"'"'exec'"'"'))' install --record /tmp/pip-record-0f6znqel/install-record.txt --single-version-externally-managed --prefix /tmp/pip-build-env-apsiwe30/overlay --compile --install-headers /srv/homeassistant/homeassistant_venv/include/site/python3.6/cffi Check the logs for full command output.
ERROR: Command errored out with exit status 1: /srv/homeassistant/homeassistant_venv/bin/python3 /srv/homeassistant/homeassistant_venv/lib/python3.6/site-packages/pip install --ignore-installed --no-user --prefix /tmp/pip-build-env-apsiwe30/overlay --no-warn-script-location --no-binary :none: --only-binary :none: -i https://pypi.org/simple -- 'setuptools>=18.5' wheel 'cffi>=1.8,!=1.11.3; python_implementation != '"'"'PyPy'"'"'' Check the logs for full
发表于 2020-2-15 08:47:26 | 显示全部楼层
同求,求大神
GMT+8, 2025-12-23 18:19 , Processed in 0.269669 second(s), 9 queries , MemCached On.
