查看: 4784|回复: 3
[技术探讨] 【求助】homeassistant0.88.1 一两天就死机,请大神帮忙看下
Mr.G 手机认证
略懂一些皮毛而已!
发表于 2020-2-12 14:10:30 | 显示全部楼层 |阅读模式
错误日志已经截图了,不知道死机跟这些错误有没有关系。
Mr.G 手机认证
略懂一些皮毛而已!
 楼主| 发表于 2020-2-12 14:30:40 | 显示全部楼层
2020-02-12 14:29:10 WARNING (MainThread) [homeassistant.loader] You are using a custom component for sonoff which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-02-12 14:29:11 WARNING (MainThread) [homeassistant.loader] You are using a custom component for tunnel2local which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-02-12 14:29:11 WARNING (MainThread) [homeassistant.loader] You are using a custom component for introduction_hachina which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-02-12 14:29:11 WARNING (MainThread) [homeassistant.components.http] legacy_api_password support has been enabled. If you don't require it, remove the 'api_password' from your http config.
2020-02-12 14:29:13 WARNING (MainThread) [homeassistant.loader] You are using a custom component for smartir.climate which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-02-12 14:29:17 WARNING (MainThread) [homeassistant.loader] You are using a custom component for ha_cloud_music.tts which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-02-12 14:29:17 WARNING (MainThread) [homeassistant.loader] You are using a custom component for ha_cloud_music.binary_sensor which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-02-12 14:29:17 WARNING (MainThread) [homeassistant.loader] You are using a custom component for switch.phicomm_dc1 which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-02-12 14:29:17 WARNING (MainThread) [homeassistant.loader] Integrations need to be in their own folder. Change switch/phicomm_dc1.py to phicomm_dc1/switch.py. This will stop working soon.
2020-02-12 14:29:17 WARNING (MainThread) [homeassistant.loader] You are using a custom component for hf_weather.weather which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-02-12 14:29:18 WARNING (MainThread) [homeassistant.loader] You are using a custom component for sonoff.sensor which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-02-12 14:29:18 WARNING (MainThread) [homeassistant.loader] Integrations need to be in their own folder. Change switch/phicomm_dc1.py to phicomm_dc1/switch.py. This will stop working soon.
2020-02-12 14:29:18 WARNING (Thread-7) [custom_components.switch.phicomm_dc1] PhicommDC1Switch server started on port 8000
2020-02-12 14:29:18 WARNING (MainThread) [homeassistant.loader] You are using a custom component for sonoff.switch which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2020-02-12 14:29:19 ERROR (MainThread) [homeassistant.core] Error doing job: Exception in callback EventBus.async_listen_once.<locals>.onetime_listener(<Event homeassistant_start[L]>) at /usr/local/lib/python3.5/dist-packages/homeassistant/core.py:614
  File "/usr/lib/python3.5/asyncio/events.py", line 126, in _run
    self._callback(*self._args)
  File "/usr/local/lib/python3.5/dist-packages/homeassistant/core.py", line 626, in onetime_listener
    self._hass.async_run_job(listener, event)
  File "/usr/local/lib/python3.5/dist-packages/homeassistant/core.py", line 333, in async_run_job
    target(*args)
  File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/person/__init__.py", line 342, in person_start_hass
    self.person_updated()
  File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/person/__init__.py", line 363, in person_updated
    self._update_state()
  File "/usr/local/lib/python3.5/dist-packages/homeassistant/components/person/__init__.py", line 374, in _update_state
    for entity_id in self._config.get(CONF_DEVICE_TRACKERS, []):
TypeError: 'NoneType' object is not iterable
2020-02-12 14:29:26 WARNING (MainThread) [homeassistant.loader] Integrations need to be in their own folder. Change switch/phicomm_dc1.py to phicomm_dc1/switch.py. This will stop working soon.
完整的报错信息在这里
发表于 2020-2-12 15:40:19 | 显示全部楼层
升级啊 都105了
发表于 2020-2-14 11:29:30 | 显示全部楼层
升级h吧 换个版本试试
GMT+8, 2025-12-31 17:28 , Processed in 0.337971 second(s), 9 queries , MemCached On.
