查看: 9670|回复: 2
home assistnt bridge添加不成功
发表于 2020-2-10 20:36:15 | 显示全部楼层 |阅读模式
最近重新安装HA,环境是debian+docker+hass.io 0.105.2。其他的没什么问题,就是iphone上面的家庭添加home assistnt bridge不成功。删除.homekit文件重新添加多次都不成功。但是ha上面也没报错,不知道哪位大神知道什么原因。 每一次添加ha上面homekit的Pin码都会消失,好像ha认为有添加成功,但是手机却显示不成功。
 楼主| 发表于 2020-2-10 21:35:41 | 显示全部楼层
加载日志显示:
2020-02-10 21:29:39 DEBUG (SyncWorker_5) [homeassistant.components.homekit.type_switches] switch.mosquito: Set current state to False
2020-02-10 21:29:39 DEBUG (SyncWorker_5) [pyhap.characteristic] set_value: On to False
2020-02-10 21:31:13 INFO (Thread-5) [pyhap.hap_server] Got connection with ('192.168.0.210', 49576).
2020-02-10 21:31:13 DEBUG (Thread-8) [pyhap.hap_server] Request POST from address '('192.168.0.210', 49576)' for path '/pair-setup'.
2020-02-10 21:31:13 DEBUG (Thread-8) [pyhap.hap_server] Pairing [1/5]
2020-02-10 21:31:13 INFO (Thread-8) [pyhap.hap_server] 192.168.0.210 - "POST /pair-setup HTTP/1.1" 200 -
2020-02-10 21:31:18 DEBUG (Thread-8) [pyhap.hap_server] Request POST from address '('192.168.0.210', 49576)' for path '/pair-setup'.
2020-02-10 21:31:18 DEBUG (Thread-8) [pyhap.hap_server] Pairing [2/5]
2020-02-10 21:31:18 INFO (Thread-8) [pyhap.hap_server] 192.168.0.210 - "POST /pair-setup HTTP/1.1" 200 -
2020-02-10 21:31:18 DEBUG (Thread-8) [pyhap.hap_server] Pairing [3/5]
2020-02-10 21:31:18 DEBUG (Thread-8) [pyhap.hap_server] Pairing [4/5]
2020-02-10 21:31:18 DEBUG (Thread-8) [pyhap.hap_server] Pairing [5/5]
2020-02-10 21:31:18 INFO (Thread-8) [pyhap.accessory_driver] Paired with f8df71a5-f07a-4ac8-80a8-4e9198427fa6.
2020-02-10 21:31:19 DEBUG (MainThread) [homeassistant.components.homekit_controller.config_flow] Discovered device Home Assistant Bridge (Home Assistant Bridge - 9E:E9:FB:4F:E0:68)
2020-02-10 21:31:19 DEBUG (MainThread) [homeassistant.components.homekit_controller.config_flow] HomeKit device 9E:E9:FB:4F:E0:68 ignored as already paired
2020-02-10 21:31:20 INFO (Thread-8) [pyhap.hap_server] 192.168.0.210 - "POST /pair-setup HTTP/1.1" 200 -
2020-02-10 21:31:20 DEBUG (Thread-8) [pyhap.hap_server] Cleaning connection to ('192.168.0.210', 49576)
哪位大神知道是什么原因。求教~~~
发表于 2020-2-18 17:32:43 | 显示全部楼层
1.docker 网络改用桥接。2.检查hap监听端口,正常监听是192.168.x.x:51827 非0.0.0.0:51827
GMT+8, 2025-12-31 15:31 , Processed in 0.326884 second(s), 11 queries , MemCached On.
