查看: 5965|回复: 2
[已解决] 超级新手刚安装好就报invalid config错误
发表于 2020-2-3 00:10:53 | 显示全部楼层 |阅读模式
通知里提示如下:
Invalid config
The following integrations and platforms could not be set up:
  • introduction
Please check your config.
配置文件内容如下,还啥都没干,看不出introduction有啥错误,请教大牛这是什么问题,这个introduction有啥用,可以注释掉吗
homeassistant:
  # Name of the location where Home Assistant is running
  # Location required to calculate the time the sun rises and sets
  latitude: 0
  longitude: 0
# Impacts weather/sunrise data (altitude above sea level in meters)
  elevation: 0
  # metric for Metric, imperial for Imperial
  unit_system: metric
  # Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
  time_zone: UTC
  # Customization file
  customize: !include customize.yaml
# Show links to resources in log and frontend
introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
mobile_app:
发表于 2020-2-3 10:43:10 | 显示全部楼层
确实有点诡异。。不过introduction注释掉也没啥关系,不影响。
 楼主| 发表于 2020-2-3 12:03:33 | 显示全部楼层
感谢大神解答,先注释掉了
GMT+8, 2025-12-23 16:48 , Processed in 0.046743 second(s), 5 queries , MemCached On.
