楼主: wen_jxpx
[插件集成] 云米热水器插件
turt
发表于 2020-3-30 23:53:01 | 显示全部楼层
wen_jxpx 发表于 2020-3-25 16:07
云米商城的账号密码
米家的账号吗?
发表于 2020-4-1 15:00:45 | 显示全部楼层
大佬,我是云米燃气热水器,能用吗?
 楼主| 发表于 2020-4-7 14:48:46 | 显示全部楼层
zjmhlxp 发表于 2020-4-1 15:00
大佬,我是云米燃气热水器,能用吗?
应该接口不一样,但controller类应该是通用的。
发表于 2020-4-19 22:35:21 | 显示全部楼层
其实可以用本地IP方式控制,只需要token就行
wktm 手机认证
发表于 2020-6-9 22:05:45 | 显示全部楼层
在哪里能找到本地IP控制的呀,
发表于 2020-9-12 17:07:11 | 显示全部楼层
其实可以用意念控制,什么都不需要。
发表于 2020-10-24 23:29:03 | 显示全部楼层
我的S1 抓包成功后不报错 但在HA里面啥夜没显示
 楼主| 发表于 2020-11-11 16:22:08 | 显示全部楼层
先直接curl测试能正常控制后,再构造代码更方便点。
发表于 2020-11-24 00:09:18 来自手机 | 显示全部楼层
client_id: 是几位数字
发表于 2020-11-30 16:11:07 来自手机 | 显示全部楼层
Logger: homeassistant.components.water_heater Source: custom_components/yunmi_water_heater/water_heater.py:173 Integration: Water Heater (documentation, issues) First occurred: 2020年11月29日 下午7:49:47 (1 occurrences) Last logged: 2020年11月29日 下午7:49:47  Error while setting up yunmi_water_heater platform for water_heater Traceback (most recent call last):   File "/config/custom_components/yunmi_water_heater/water_heater.py", line 243, in yunmi_get_access_token     self._access_token_exp_time = int(res_list['result']['expiresIn']) KeyError: 'result'  During handling of the above exception, another exception occurred:  Traceback (most recent call last):   File "/config/custom_components/yunmi_water_heater/water_heater.py", line 222, in yunmi_login     tk_arr = self.yunmi_get_access_token(self._refresh_token, self._client_id)   File "/config/custom_components/yunmi_water_heater/water_heater.py", line 246, in yunmi_get_access_token     _LOGGER.error('get access token failed:'+e.__context__) TypeError: can only concatenate str (not "NoneType") to str  During handling of the above exception, another exception occurred:  Traceback (most recent call last):   File "/config/custom_components/yunmi_water_heater/water_heater.py", line 169, in __init__     self.yunmi_login()   File "/config/custom_components/yunmi_water_heater/water_heater.py", line 231, in yunmi_login     _LOGGER.error('login failed:'+e.__context__) TypeError: can only concatenate str (not "KeyError") to str  During handling of the above exception, another exception occurred:  Traceback (most recent call last):   File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 193, in _async_setup_platform     await asyncio.shield(task)   File "/config/custom_components/yunmi_water_heater/water_heater.py", line 128, in async_setup_platform     yunmi_wh = YunmiWaterHeater(hass, name, phone_number, password, client_id)   File "/config/custom_components/yunmi_water_heater/water_heater.py", line 411, in __init__     self._controller = YunmiWaterHeaterController(hass, phone_number, password, client_id)   File "/config/custom_components/yunmi_water_heater/water_heater.py", line 173, in __init__     _LOGGER.error("update fail"+e.__context__) TypeError: can only concatenate str (not "TypeError") to str
GMT+8, 2026-1-20 01:19 , Processed in 0.567216 second(s), 9 queries , MemCached On.
