查看: 5795|回复: 0
[已解决] homebridge 正常运行N天后报错,求救
发表于 2017-8-16 21:38:26 | 显示全部楼层 |阅读模式
日志如下:
[2017-8-16 21:35:25] [HomeAssistant] Initializing HomeAssistant platform...
[2017-8-16 21:35:25] [HomeAssistant] Fetching HomeAssistant devices.
[2017-8-16 21:35:25] [Broadlink RM] Initializing BroadlinkRM platform...
/usr/local/lib/node_modules/homebridge-broadlink-rm/node_modules/node-persist/src/local-storage.js:666
            throw Error('[PARSE-ERROR] ' + file + ' does not look like a valid storage file!');
Error: [PARSE-ERROR] /var/homebridge/plugin-persist/homebridge-broadlink-rm/7643b58dcdfc6982bc80f9041651be7f does not look like a valid storage file!
    at LocalStorage.parseFileSync (/usr/local/lib/node_modules/homebridge-broadlink-rm/node_modules/node-persist/src/local-storage.js:666:19)
    at LocalStorage.parseStorageDirSync (/usr/local/lib/node_modules/homebridge-broadlink-rm/node_modules/node-persist/src/local-storage.js:615:26)
    at LocalStorage.initSync (/usr/local/lib/node_modules/homebridge-broadlink-rm/node_modules/node-persist/src/local-storage.js:142:14)
    at Object.nodePersist.initSync (/usr/local/lib/node_modules/homebridge-broadlink-rm/node_modules/node-persist/src/node-persist.js:37:32)
    at Object.init (/usr/local/lib/node_modules/homebridge-broadlink-rm/node_modules/homebridge-platform-helper/helpers/persistentState.js:10:15)
    at BroadlinkRMPlatform.HomebridgePlatform (/usr/local/lib/node_modules/homebridge-broadlink-rm/node_modules/homebridge-platform-helper/platform.js:14:21)
    at BroadlinkRMPlatform (/usr/local/lib/node_modules/homebridge-broadlink-rm/index.js:11:1)
    at Server._loadPlatforms (/usr/local/lib/node_modules/homebridge/lib/server.js:294:32)
    at Server.run (/usr/local/lib/node_modules/homebridge/lib/server.js:80:36)
    at module.exports (/usr/local/lib/node_modules/homebridge/lib/cli.js:40:10)
8月 16 21:41:20 raspberrypi systemd[1]: Unit homebridge.service entered failed state.
8月 16 21:41:30 raspberrypi systemd[1]: homebridge.service holdoff time over, scheduling restart.
8月 16 21:41:30 raspberrypi systemd[1]: Stopping Node.js HomeKit Server...
8月 16 21:41:30 raspberrypi systemd[1]: Starting Node.js HomeKit Server...
8月 16 21:41:30 raspberrypi systemd[1]: Started Node.js HomeKit Server.
8月 16 21:41:31 raspberrypi homebridge[2797]: *** WARNING *** The program 'node' uses the Apple Bonjou                             r compatibility layer of Avahi.
8月 16 21:41:31 raspberrypi node[2797]: *** WARNING *** The program 'node' uses the Apple Bonjour compatibility layer of Avahi.
8月 16 21:41:31 raspberrypi node[2797]: *** WARNING *** Please fix your application to use the native  API of Avahi!
8月 16 21:41:31 raspberrypi node[2797]: *** WARNING *** For more information see <http://0pointer.de/avahi-compat?s=libdns_sd&e=node>
8月 16 21:41:31 raspberrypi node[2797]: *** WARNING *** The program 'node' called 'DNSServiceRegister(          )' which is not supported (or only supported partially) in the Apple Bonjour compatibility layer of Av
感觉是博联插件出了问题;
然后更新博联插件 无解
试了坛内的方法   拷贝文件  无解
DNSServiceRegister ?
大神求救!!
GMT+8, 2025-12-25 15:39 , Processed in 0.161253 second(s), 7 queries , MemCached On.
