查看: 9259|回复: 2
[求助] 哪位大佬有小米电视的红外遥控码
发表于 2020-1-13 20:19:18 | 显示全部楼层 |阅读模式
在做自动化,小米55寸电视的遥控器是蓝牙版的,没办法学习红外码,哪位大佬有小米电视的红外遥控码能共享下
发表于 2020-1-14 13:57:31 | 显示全部楼层
小米遥控器为自己的红外码库,只能给raw码,大概测试了一下,每单组红外码为12bits(24个uin16_t),所以以下每个键给两组72bits的数据,自己可以再测试(code可能会有问题,请测试后再使用,最好使用rawdata)
电源:
Code      : 0xF44662C3 (72 Bits)
uint16_t rawData[144] = {1018, 590,  600, 586,  600, 1458,  600, 1464,  598, 588,  598, 1464,  626, 560,  598, 1466,  596, 590,  602, 1456,  598, 1466,  600, 10670,  1024, 586,  598, 586,  602, 1458,  598, 1464,  600, 584,  598, 1466,  598, 586,  600, 1464,  626, 560,  620, 1436,  626, 1440,  622, 10646,  1050, 560,  626, 558,  628, 1432,  626, 1438,  626, 558,  628, 1436,  624, 562,  626, 1438,  624, 560,  626, 1434,  626, 1438,  624, 10640,  1046, 562,  626, 560,  622, 1436,  626, 1436,  624, 564,  624, 1438,  630, 556,  626, 1438,  624, 562,  626, 1432,  624, 1440,  628, 10642,  1046, 564,  626, 560,  626, 1432,  626, 1438,  628, 558,  620, 1442,  624, 562,  626, 1436,  626, 560,  628, 1432,  622, 1442,  628, 10640,  1048, 562,  626, 560,  622, 1436,  628, 1438,  622, 562,  622, 1442,  626, 558,  624, 1440,  622, 562,  626, 1434,  622, 1440,  628, 10640};
uint16_t rawData[144] = {990, 620,  564, 622,  560, 1496,  560, 1502,  562, 624,  562, 1496,  562, 648,  536, 1506,  562, 622,  558, 1498,  566, 1496,  562, 10696,  990, 624,  560, 626,  558, 1500,  562, 1500,  558, 628,  562, 1498,  564, 622,  560, 1502,  558, 626,  562, 1496,  562, 1502,  558, 10698,  992, 620,  558, 628,  558, 1500,  560, 1502,  562, 622,  562, 1502,  558, 650,  534, 1504,  558, 628,  562, 1494,  564, 1498,  558, 10694,  994, 622,  562, 624,  562, 1492,  566, 1498,  564, 620,  560, 1502,  566, 620,  562, 1500,  560, 624,  562, 1500,  556, 1506,  558, 10702,  984, 624,  560, 624,  558, 1498,  566, 1522,  540, 622,  562, 1500,  558, 594,  594, 1502,  564, 646,  536, 1496,  562, 1504,  560, 10698,  984, 624,  562, 624,  562, 1520,  542, 1496,  564, 622,  562, 1498,  566, 646,  534, 1502,  566, 620,  564, 1494,  560, 1502,  564, 10698};
上:
Code      : 0x89361C7 (72 Bits)
uint16_t rawData[144] = {1016, 590,  592, 1172,  594, 596,  590, 884,  594, 1170,  596, 594,  594, 594,  590, 886,  590, 884,  594, 1166,  590, 1474,  588, 12432,  1020, 588,  588, 1176,  592, 596,  588, 886,  594, 1172,  590, 600,  590, 596,  596, 878,  594, 882,  594, 1166,  596, 1468,  592, 12430,  1018, 588,  590, 1174,  588, 600,  588, 886,  588, 1176,  594, 596,  592, 594,  590, 884,  594, 880,  592, 1168,  590, 1472,  592, 12430,  1014, 592,  594, 1170,  588, 600,  588, 886,  594, 1170,  590, 600,  592, 596,  588, 886,  590, 884,  592, 1166,  592, 1472,  594, 12426,  1014, 592,  590, 1174,  590, 598,  594, 880,  590, 1172,  590, 600,  594, 594,  592, 884,  588, 886,  590, 1168,  594, 1470,  592, 12426,  1018, 588,  594, 1172,  592, 596,  590, 884,  594, 1170,  592, 596,  594, 594,  592, 882,  590, 884,  594, 1164,  590, 1474,  590, 12426};
uint16_t rawData[144] = {1016, 592,  588, 1174,  592, 596,  592, 914,  564, 1170,  590, 598,  592, 596,  594, 884,  590, 884,  590, 1170,  590, 1472,  594, 12428,  1014, 590,  590, 1176,  594, 594,  592, 882,  592, 1172,  592, 598,  594, 596,  590, 884,  590, 884,  590, 1170,  592, 1472,  588, 12430,  1018, 590,  594, 1172,  594, 594,  592, 882,  594, 1200,  564, 596,  592, 594,  588, 886,  594, 880,  588, 1170,  594, 1470,  590, 12460,  986, 592,  588, 1176,  592, 596,  592, 884,  594, 1170,  588, 602,  594, 594,  588, 886,  588, 888,  594, 1164,  590, 1472,  594, 12424,  1018, 590,  594, 1170,  588, 598,  592, 884,  592, 1174,  594, 624,  558, 600,  592, 882,  590, 884,  594, 1166,  590, 1472,  596, 12454,  982, 594,  594, 1170,  592, 594,  592, 884,  592, 1170,  592, 598,  588, 598,  594, 882,  590, 884,  592, 1168,  590, 1504,  564, 12454};
下:
Code      : 0x7CA085DF (72 Bits)
uint16_t rawData[144] = {984, 622,  562, 1202,  558, 598,  594, 914,  562, 1222,  538, 598,  590, 630,  562, 912,  558, 1202,  564, 1202,  558, 630,  562, 13048,  986, 586,  596, 1202,  562, 594,  594, 912,  564, 1202,  562, 592,  596, 650,  534, 936,  538, 1204,  562, 1204,  556, 632,  562, 13046,  988, 620,  556, 1192,  574, 626,  558, 882,  592, 1206,  560, 598,  590, 596,  592, 916,  560, 1200,  562, 1202,  560, 598,  596, 13044,  988, 618,  568, 1168,  594, 626,  562, 914,  562, 1204,  560, 632,  558, 626,  560, 914,  556, 1204,  566, 1202,  562, 648,  542, 13044,  986, 588,  594, 1204,  558, 654,  534, 882,  592, 1204,  558, 632,  562, 624,  566, 912,  558, 1170,  596, 1200,  564, 626,  562, 13014,  1018, 588,  592, 1204,  562, 626,  560, 912,  562, 1200,  560, 632,  560, 592,  596, 878,  592, 1204,  564, 1200,  560, 630,  558, 13014};
uint16_t rawData[144] = {986, 590,  592, 1200,  566, 594,  592, 908,  564, 1172,  594, 596,  592, 596,  588, 884,  592, 1202,  556, 1206,  562, 628,  564, 13046,  984, 592,  594, 1172,  592, 624,  560, 884,  594, 1226,  538, 598,  592, 594,  590, 886,  588, 1202,  560, 1228,  540, 596,  590, 13048,  990, 618,  560, 1176,  592, 596,  594, 910,  566, 1200,  558, 602,  592, 624,  562, 934,  542, 1198,  560, 1176,  588, 632,  562, 13044,  988, 590,  590, 1174,  594, 626,  560, 884,  594, 1200,  564, 596,  588, 654,  540, 910,  562, 1170,  594, 1200,  558, 628,  562, 13020,  1014, 622,  562, 1202,  562, 626,  560, 884,  590, 1204,  564, 610,  576, 598,  594, 880,  588, 1202,  560, 1174,  590, 600,  590, 13046,  984, 622,  564, 1172,  590, 628,  558, 938,  540, 1202,  564, 596,  594, 646,  542, 910,  564, 1168,  590, 1174,  592, 628,  558, 13046};
左:
Code      : 0xD85E2E17 (72 Bits)
uint16_t rawData[144] = {984, 622,  560, 1204,  562, 626,  564, 910,  562, 1202,  564, 626,  562, 626,  560, 1198,  560, 1500,  558, 916,  560, 918,  564, 12458,  984, 620,  562, 1202,  564, 626,  560, 912,  564, 1202,  566, 624,  562, 624,  566, 1194,  564, 1498,  560, 916,  564, 914,  558, 12462,  982, 624,  566, 1198,  560, 628,  560, 914,  564, 1200,  564, 624,  566, 622,  566, 1194,  566, 1496,  562, 912,  564, 912,  564, 12456,  984, 622,  560, 1204,  566, 622,  566, 908,  566, 1200,  564, 624,  566, 620,  564, 1196,  562, 1498,  564, 912,  566, 910,  562, 12458,  982, 622,  564, 1202,  562, 624,  566, 908,  562, 1202,  566, 624,  564, 624,  566, 1194,  562, 1498,  564, 910,  560, 918,  564, 12456,  988, 616,  562, 1204,  560, 628,  564, 908,  562, 1202,  562, 628,  562, 624,  566, 1194,  560, 1500,  564, 910,  562, 916,  560, 12456};
uint16_t rawData[144] = {982, 622,  564, 1200,  558, 630,  558, 916,  560, 1206,  558, 630,  564, 624,  562, 1198,  558, 1502,  560, 914,  558, 918,  564, 12458,  984, 620,  558, 1206,  560, 628,  566, 908,  562, 1204,  560, 628,  562, 626,  562, 1198,  564, 1498,  562, 914,  564, 912,  560, 12460,  984, 622,  564, 1200,  564, 624,  568, 906,  566, 1200,  560, 628,  562, 626,  566, 1194,  568, 1494,  566, 908,  562, 916,  562, 12460,  984, 620,  562, 1204,  564, 622,  564, 910,  564, 1200,  562, 628,  564, 622,  568, 1194,  562, 1498,  568, 908,  566, 912,  566, 12454,  988, 618,  568, 1198,  562, 626,  564, 908,  568, 1198,  566, 622,  568, 620,  568, 1192,  564, 1498,  566, 910,  568, 910,  564, 12456,  988, 616,  568, 1198,  568, 620,  568, 906,  564, 1200,  562, 628,  562, 626,  564, 1194,  566, 1496,  560, 914,  562, 914,  566, 12456};
右:
Code      : 0xC95991DF (72 Bits)
uint16_t rawData[144] = {986, 620,  566, 1200,  562, 624,  560, 916,  560, 1202,  566, 624,  566, 620,  558, 1502,  562, 630,  564, 624,  562, 1198,  562, 13042,  990, 620,  558, 1206,  566, 622,  564, 910,  562, 1226,  542, 648,  536, 624,  562, 1502,  564, 626,  564, 646,  540, 1202,  562, 13042,  990, 618,  562, 1202,  560, 630,  558, 914,  566, 1198,  562, 628,  562, 622,  564, 1498,  566, 624,  560, 628,  564, 1202,  564, 13038,  986, 624,  558, 1204,  562, 650,  540, 908,  560, 1204,  564, 650,  538, 648,  534, 1502,  566, 626,  564, 622,  564, 1200,  562, 13044,  988, 618,  560, 1204,  560, 628,  562, 912,  562, 1202,  560, 630,  560, 624,  562, 1502,  562, 628,  562, 624,  566, 1200,  562, 13010,  1020, 618,  562, 1204,  560, 650,  534, 938,  536, 1204,  562, 628,  564, 622,  564, 1498,  564, 626,  558, 630,  558, 1202,  562, 13010};
uint16_t rawData[144] = {990, 620,  562, 1202,  564, 624,  562, 912,  562, 1202,  562, 596,  590, 624,  564, 1498,  562, 598,  592, 626,  560, 1202,  564, 13040,  986, 620,  564, 1222,  536, 598,  592, 884,  590, 1204,  564, 628,  564, 622,  562, 1468,  592, 652,  540, 624,  558, 1174,  594, 13038,  988, 648,  538, 1202,  564, 592,  592, 914,  558, 1204,  562, 630,  562, 622,  560, 1504,  564, 594,  596, 624,  560, 1202,  562, 13044,  986, 622,  562, 1222,  544, 646,  538, 914,  558, 1204,  562, 596,  592, 648,  538, 1500,  560, 630,  558, 630,  562, 1202,  564, 13042,  988, 618,  564, 1170,  594, 626,  562, 910,  558, 1204,  558, 632,  562, 624,  562, 1502,  564, 626,  562, 598,  586, 1204,  562, 13038,  992, 586,  594, 1202,  562, 626,  558, 914,  562, 1202,  562, 628,  560, 624,  562, 1500,  560, 630,  558, 630,  556, 1206,  564, 13038};
确定:
Code      : 0xB6BC7F93 (72 Bits)
uint16_t rawData[144] = {988, 590,  592, 1172,  592, 628,  562, 910,  558, 1176,  590, 600,  586, 624,  564, 1500,  566, 912,  562, 622,  566, 1470,  590, 12452,  990, 590,  592, 1202,  560, 598,  592, 882,  590, 1204,  562, 598,  586, 628,  560, 1470,  594, 912,  560, 626,  558, 1506,  564, 12448,  984, 620,  562, 1204,  560, 630,  558, 914,  560, 1174,  592, 598,  590, 594,  588, 1502,  564, 914,  560, 624,  562, 1498,  562, 12450,  990, 616,  566, 1224,  540, 624,  564, 910,  560, 1174,  592, 596,  590, 594,  592, 1468,  592, 916,  562, 622,  560, 1502,  560, 12454,  984, 592,  594, 1200,  560, 628,  560, 912,  562, 1226,  538, 630,  560, 616,  572, 1496,  560, 916,  562, 624,  560, 1472,  592, 12444,  992, 590,  592, 1200,  560, 628,  564, 908,  564, 1170,  590, 600,  592, 622,  558, 1472,  592, 914,  564, 620,  564, 1498,  560, 12444};
uint16_t rawData[144] = {982, 624,  560, 1204,  558, 630,  560, 916,  562, 1202,  564, 626,  560, 624,  560, 1500,  562, 916,  564, 620,  560, 1502,  586, 12430,  982, 622,  562, 1202,  562, 626,  566, 908,  562, 1202,  560, 630,  564, 622,  566, 1494,  566, 912,  564, 620,  566, 1500,  562, 12452,  990, 616,  562, 1204,  564, 624,  566, 908,  564, 1200,  562, 630,  562, 622,  566, 1496,  568, 910,  562, 622,  566, 1472,  594, 12448,  986, 620,  568, 1196,  566, 622,  568, 906,  630, 1134,  568, 620,  562, 624,  564, 1498,  566, 910,  564, 620,  566, 1498,  568, 12448,  990, 616,  568, 1196,  562, 626,  564, 912,  564, 1200,  564, 628,  568, 616,  566, 1496,  570, 908,  564, 622,  566, 1498,  564, 12452,  988, 618,  564, 1200,  568, 622,  562, 912,  568, 1196,  564, 626,  570, 616,  566, 1494,  564, 914,  568, 618,  566, 1496,  568, 12452};
HOME:
Code      : 0x8E7EC92B (72 Bits)
uint16_t rawData[144] = {988, 618,  566, 1198,  566, 622,  562, 912,  562, 1202,  562, 628,  562, 626,  566, 1200,  562, 624,  566, 908,  562, 1204,  566, 13046,  984, 622,  568, 1198,  568, 620,  568, 906,  564, 1200,  564, 626,  564, 624,  566, 1200,  566, 620,  566, 908,  568, 1196,  564, 13048,  990, 616,  568, 1196,  568, 620,  562, 912,  564, 1200,  562, 628,  564, 622,  562, 1202,  562, 626,  562, 912,  564, 1200,  562, 13048,  988, 618,  566, 1198,  562, 626,  564, 910,  562, 1204,  568, 622,  568, 620,  568, 1196,  564, 622,  566, 910,  566, 1198,  564, 13048,  990, 616,  564, 1200,  568, 620,  568, 908,  566, 1200,  570, 620,  568, 620,  566, 1198,  564, 624,  568, 906,  568, 1196,  562, 13050,  992, 614,  568, 1196,  564, 624,  562, 912,  564, 1202,  568, 622,  566, 622,  564, 1200,  568, 620,  570, 904,  570, 1194,  564, 13050};
uint16_t rawData[144] = {986, 618,  562, 1202,  562, 626,  566, 908,  560, 1206,  562, 628,  564, 622,  562, 1202,  560, 626,  560, 938,  540, 1200,  562, 13048,  990, 616,  562, 1202,  564, 624,  562, 912,  566, 1198,  568, 622,  566, 620,  564, 1200,  566, 622,  564, 910,  566, 1200,  566, 13040,  982, 622,  564, 1202,  564, 622,  566, 908,  564, 1200,  560, 628,  566, 620,  562, 1202,  566, 622,  560, 914,  562, 1204,  564, 13044,  990, 616,  566, 1198,  564, 624,  560, 914,  562, 1202,  562, 628,  564, 622,  568, 1196,  562, 626,  568, 906,  564, 1200,  568, 13042,  984, 622,  560, 1204,  566, 624,  564, 910,  564, 1200,  568, 622,  562, 626,  562, 1202,  566, 622,  562, 912,  562, 1202,  564, 13046,  984, 620,  566, 1200,  566, 620,  562, 912,  568, 1198,  564, 626,  562, 624,  568, 1198,  566, 622,  564, 910,  566, 1198,  562, 13046};
返回:
uint16_t rawData[144] = {982, 622,  562, 1202,  562, 624,  560, 914,  560, 1204,  562, 628,  562, 628,  558, 912,  566, 1496,  564, 1198,  562, 914,  566, 12456,  984, 622,  568, 1196,  566, 620,  566, 908,  562, 1202,  566, 624,  564, 624,  566, 906,  568, 1494,  562, 1200,  566, 912,  560, 12464,  986, 618,  566, 1198,  568, 620,  564, 910,  566, 1198,  564, 624,  568, 622,  560, 910,  566, 1496,  564, 1198,  568, 910,  568, 12454,  986, 620,  566, 1198,  568, 620,  564, 910,  564, 1200,  568, 622,  568, 622,  564, 906,  618, 1442,  562, 1202,  564, 914,  562, 12460,  984, 620,  562, 1202,  564, 624,  568, 906,  564, 1200,  562, 628,  560, 626,  568, 904,  568, 1492,  564, 1200,  562, 914,  564, 12458,  990, 616,  564, 1200,  562, 626,  568, 908,  562, 1202,  562, 628,  562, 624,  564, 934,  540, 1496,  564, 1198,  568, 910,  568, 12458};
uint16_t rawData[144] = {980, 624,  564, 1200,  564, 624,  562, 912,  560, 1206,  562, 628,  562, 626,  562, 910,  562, 1496,  562, 1202,  558, 918,  558, 12464,  986, 618,  564, 1200,  566, 620,  560, 914,  560, 1204,  566, 624,  562, 626,  566, 906,  564, 1494,  562, 1200,  564, 912,  566, 12458,  988, 618,  560, 1206,  566, 622,  566, 908,  566, 1200,  564, 624,  564, 622,  562, 912,  560, 1498,  562, 1202,  566, 910,  562, 12458,  988, 616,  564, 1200,  564, 622,  566, 908,  562, 1202,  564, 626,  564, 624,  566, 904,  568, 1492,  566, 1196,  566, 912,  564, 12458,  988, 618,  566, 1198,  564, 624,  566, 908,  566, 1198,  560, 628,  562, 626,  564, 908,  564, 1496,  560, 1202,  566, 910,  564, 12456,  990, 614,  568, 1196,  568, 620,  566, 908,  564, 1200,  566, 624,  562, 624,  564, 908,  562, 1498,  562, 1200,  566, 912,  568, 12456};
菜单:
Code      : 0x7FFD2197 (72 Bits)
uint16_t rawData[144] = {984, 620,  562, 1204,  564, 624,  566, 908,  564, 1200,  564, 626,  566, 622,  562, 916,  562, 624,  558, 1202,  564, 1200,  562, 13050,  986, 620,  566, 1198,  560, 626,  560, 914,  562, 1202,  566, 624,  560, 626,  564, 912,  566, 620,  566, 1194,  564, 1200,  562, 13050,  982, 622,  566, 1200,  564, 624,  560, 914,  566, 1200,  564, 624,  562, 626,  562, 916,  566, 620,  564, 1198,  566, 1198,  562, 13048,  990, 616,  564, 1200,  564, 624,  562, 912,  568, 1198,  562, 628,  566, 622,  564, 914,  562, 624,  566, 1196,  566, 1198,  566, 13044,  992, 614,  564, 1202,  562, 624,  566, 908,  566, 1200,  566, 624,  564, 624,  560, 916,  566, 620,  562, 1200,  568, 1200,  558, 13048,  986, 620,  560, 1204,  568, 620,  564, 910,  568, 1198,  564, 626,  564, 624,  562, 916,  566, 620,  564, 1198,  568, 1198,  564, 13048};
uint16_t rawData[144] = {988, 618,  562, 1202,  562, 626,  560, 914,  560, 1206,  562, 626,  566, 622,  562, 914,  560, 628,  562, 1200,  566, 1198,  562, 13048,  988, 618,  566, 1198,  564, 624,  622, 852,  560, 1204,  560, 630,  562, 626,  562, 916,  560, 626,  562, 1202,  560, 1204,  562, 13050,  988, 618,  566, 1198,  564, 624,  564, 912,  566, 1198,  562, 628,  562, 626,  566, 910,  562, 626,  564, 1198,  560, 1204,  566, 13046,  988, 618,  564, 1202,  560, 628,  564, 910,  562, 1202,  560, 630,  564, 622,  568, 910,  566, 620,  562, 1202,  566, 1198,  564, 13046,  1014, 592,  562, 1202,  564, 624,  562, 914,  566, 1198,  564, 624,  566, 622,  566, 912,  566, 620,  564, 1198,  566, 1200,  562, 13048,  986, 618,  562, 1204,  566, 620,  562, 912,  562, 1202,  564, 626,  564, 622,  562, 914,  560, 626,  562, 1200,  564, 1198,  566, 13048};
音量加:
Code      : 0x9B691CE8 (72 Bits)
uint16_t rawData[144] = {986, 618,  562, 1204,  562, 626,  564, 910,  564, 1200,  564, 624,  564, 622,  566, 1494,  564, 1200,  562, 626,  562, 628,  562, 13048,  982, 622,  564, 1202,  562, 626,  566, 908,  560, 1202,  568, 622,  564, 620,  568, 1494,  566, 1198,  564, 624,  568, 622,  566, 13042,  992, 612,  568, 1198,  562, 626,  564, 910,  570, 1196,  562, 626,  564, 622,  566, 1494,  566, 1196,  568, 622,  564, 626,  562, 13046,  986, 620,  562, 1202,  568, 620,  568, 906,  566, 1198,  568, 622,  568, 616,  564, 1496,  562, 1202,  562, 628,  566, 622,  568, 13040,  984, 620,  564, 1200,  570, 618,  568, 906,  566, 1198,  562, 628,  568, 616,  568, 1492,  564, 1172,  594, 624,  568, 622,  562, 13046,  992, 614,  568, 1196,  568, 618,  564, 910,  564, 1200,  566, 624,  564, 620,  568, 1492,  568, 1196,  562, 628,  564, 626,  566, 13046};
uint16_t rawData[144] = {986, 620,  562, 1202,  566, 622,  568, 908,  566, 1198,  564, 626,  564, 622,  560, 1498,  562, 1202,  560, 628,  564, 624,  562, 13046,  988, 618,  564, 1200,  562, 626,  566, 908,  566, 1198,  566, 624,  566, 620,  566, 1494,  560, 1204,  564, 626,  566, 622,  568, 13042,  984, 620,  568, 1196,  562, 624,  566, 910,  566, 1198,  568, 622,  568, 618,  564, 1496,  566, 1198,  568, 622,  562, 628,  566, 13044,  990, 614,  562, 1202,  566, 622,  564, 910,  562, 1202,  568, 622,  566, 620,  564, 1496,  564, 1200,  568, 622,  564, 624,  566, 13042,  986, 620,  568, 1196,  562, 626,  566, 908,  566, 1198,  564, 626,  562, 622,  562, 1498,  568, 1196,  568, 622,  568, 622,  562, 13044,  988, 618,  566, 1196,  564, 622,  566, 910,  562, 1202,  566, 624,  568, 616,  562, 1498,  562, 1202,  564, 626,  568, 622,  566, 13044};
音量减:
Code      : 0x6CBE40D7 (72 Bits)
uint16_t rawData[144] = {988, 616,  566, 1198,  566, 622,  560, 914,  564, 1200,  566, 624,  564, 618,  566, 1494,  560, 1502,  564, 624,  562, 916,  562, 12460,  986, 620,  564, 1200,  564, 624,  562, 912,  562, 1204,  564, 626,  566, 620,  564, 1494,  566, 1496,  566, 622,  566, 910,  562, 12460,  982, 622,  564, 1200,  564, 626,  560, 912,  562, 1202,  560, 630,  562, 622,  560, 1498,  566, 1496,  564, 624,  564, 912,  564, 12456,  990, 616,  564, 1198,  568, 620,  564, 910,  564, 1200,  564, 626,  566, 618,  566, 1492,  564, 1498,  566, 622,  566, 910,  568, 12456,  990, 614,  568, 1196,  566, 624,  562, 910,  568, 1198,  566, 624,  564, 620,  566, 1492,  566, 1496,  562, 624,  562, 914,  562, 12456,  992, 614,  560, 1202,  564, 624,  566, 908,  562, 1202,  564, 626,  566, 618,  566, 1492,  564, 1498,  568, 620,  566, 910,  568, 12456};
uint16_t rawData[144] = {982, 622,  564, 1202,  566, 622,  562, 912,  566, 1198,  562, 626,  560, 624,  560, 1498,  560, 1502,  566, 620,  562, 914,  564, 12458,  986, 618,  560, 1204,  566, 622,  564, 910,  562, 1204,  566, 624,  566, 618,  562, 1496,  566, 1496,  566, 622,  566, 912,  560, 12462,  988, 618,  566, 1198,  566, 622,  562, 912,  560, 1206,  562, 626,  564, 622,  564, 1494,  564, 1500,  562, 624,  568, 910,  562, 12460,  984, 622,  562, 1202,  564, 624,  564, 910,  564, 1200,  562, 626,  566, 618,  566, 1492,  564, 1500,  564, 624,  564, 912,  560, 12462,  986, 620,  562, 1202,  562, 626,  564, 910,  564, 1202,  566, 622,  566, 620,  562, 1496,  564, 1498,  566, 622,  562, 914,  566, 12456,  986, 620,  562, 1202,  566, 620,  564, 910,  564, 1200,  560, 630,  562, 622,  564, 1494,  560, 1504,  566, 622,  564, 914,  560, 12456};
 楼主| 发表于 2020-1-14 21:35:26 | 显示全部楼层
tcwj2008 发表于 2020-1-14 13:57
小米遥控器为自己的红外码库,只能给raw码,大概测试了一下,每单组红外码为12bits(24个uin16_t),所以以下 ...
谢谢了,我测试下,刚开始搞ha,感觉千头万绪
GMT+8, 2026-2-5 12:51 , Processed in 0.071137 second(s), 13 queries , MemCached On.
