查看: 4776|回复: 3
[求助] HASSIO下安装node-red无法打开
发表于 2020-1-6 00:53:08 | 显示全部楼层 |阅读模式
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] nginx.sh: executing...
[00:48:55] FATAL:
[00:48:55] FATAL: SSL has been enabled using the 'ssl' option,
[00:48:55] FATAL: this requires a SSL certificate file which is
[00:48:55] FATAL: configured using the 'certfile' option in the
[00:48:55] FATAL: add-on configuration.
[00:48:55] FATAL:
[00:48:55] FATAL: Unfortunately, the file specified in the
[00:48:55] FATAL: 'certfile' option does not exists.
[00:48:55] FATAL:
[00:48:55] FATAL: Please ensure the certificate file exists and
[00:48:55] FATAL: is placed in the Hass.io '/ssl/' directory.
[00:48:55] FATAL:
[00:48:55] FATAL: In case you don't have SSL yet, consider getting
[00:48:55] FATAL: a SSL certificate or setting the 'ssl' option
[00:48:55] FATAL: to 'false' in case you are not planning on using
[00:48:55] FATAL: SSL with this add-on.
[00:48:55] FATAL:
[00:48:55] FATAL: Check the add-on manual for more information.
[00:48:55] FATAL:
[cont-init.d] nginx.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] 99-message.sh: executing...
                Oops! Something went wrong.
 We are so sorry, but something went terribly wrong when
 starting or running this add-on.
 Be sure to check the log above, line by line, for hints.
[cont-finish.d] 99-message.sh: exited 0.
[cont-finish.d] done.
[s6-finish] waiting for services.
[s6-finish] sending all processes the TERM signal.
发表于 2020-1-6 10:53:00 | 显示全部楼层
在配置中把ssl关掉。
Bisn
发表于 2020-1-6 10:53:08 | 显示全部楼层
日志说的很清楚
setting the 'ssl' option to 'false'
 楼主| 发表于 2020-1-6 16:04:56 | 显示全部楼层
囧 发表于 2020-1-6 10:53
在配置中把ssl关掉。
谢谢囧大,眼瞎了没看见
GMT+8, 2025-12-23 18:17 , Processed in 0.060323 second(s), 10 queries , MemCached On.
