查看: 7736|回复: 5
[求助] 群晖中的hass.io安装VLC找不到声音输入输出
发表于 2020-1-2 22:06:03 | 显示全部楼层 |阅读模式
主板是j3455
 楼主| 发表于 2020-1-2 22:08:31 | 显示全部楼层
[00007fb5f2b3d180] dbus interface error: Failed to connect to the D-Bus session daemon: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
[00007fb5f2b3d180] main interface error: no suitable interface module
[00007fb5f1f08b40] main libvlc error: interface "dbus,none" initialization failed
[00007fb5f2b3d340] [telnet] lua interface: Listening on host "telnet://:4212".
[00007fb5f2b4d500] main interface error: no suitable interface module
[00007fb5f1f08b40] main libvlc error: interface "globalhotkeys,none" initialization failed
[00007fb5f2b110c0] main playlist: playlist is empty
[00007fb5f2b4d500] [http] lua interface: Lua HTTP interface
[00007fa4c7841180] dbus interface error: Failed to connect to the D-Bus session daemon: Unable to autolaunch a dbus-daemon without a $DISPLAY for X11
[00007fa4c7841180] main interface error: no suitable interface module
[00007fa4c5afdb40] main libvlc error: interface "dbus,none" initialization failed
[00007fa4c7841340] [telnet] lua interface: Listening on host "telnet://:4212".
[00007fa4c78514c0] main interface error: no suitable interface module
[00007fa4c5afdb40] main libvlc error: interface "globalhotkeys,none" initialization failed
[00007fa4c78150c0] main playlist: playlist is empty
[00007fa4c78514c0] [http] lua interface: Lua HTTP interface
发表于 2020-1-2 23:30:23 | 显示全部楼层
官方文档说了hass.io不支持VLCVLC currently not supported with Hass.io
According to the forum topic “How to add VLC into my Hassio”, it is not possible to install packages like VLC on Hass.io.
帖子里说,可以用vlc_telnet
插件源里添加https://github.com/rodripf/hassio-local-vlc
安装了就可以用vlc_telnet了,群晖的你可以试下
 楼主| 发表于 2020-1-2 23:56:13 | 显示全部楼层
我就是安装的这个呀。但是一直说找不到驱动
20-01-02 15:26:38 INFO (MainThread) [hassio.misc.hardware] No audio devices found
20-01-02 15:26:40 INFO (MainThread) [hassio.misc.hardware] No audio devices found
20-01-02 15:26:40 INFO (SyncWorker_13) [hassio.docker.interface] Clean addon_53caca22_mopidy application
20-01-02 15:26:43 INFO (SyncWorker_13) [hassio.misc.hardware] No audio devices found
20-01-02 15:26:52 ERROR (SyncWorker_13) [hassio.docker] Can't start addon_53caca22_mopidy: 500 Server Error: Internal Server Error ("linux runtime spec devices: error gathering device information while adding custom device "/dev/snd": no such file or directory")
发表于 2020-1-3 08:31:04 | 显示全部楼层
怎么玩,做什么用的呀?ha里播放媒体?
论坛风云人物
发表于 2020-1-3 11:12:50 | 显示全部楼层
试一下Mopidy,参数配置中选择你的声卡,例:
Audio Output
USB-Audio - USB Sound Device: 0
GMT+8, 2025-12-23 18:19 , Processed in 0.053785 second(s), 13 queries , MemCached On.
