楼主: jiluxinqing
[新奇玩法] 全新的语音小助手插件发布【2020-1-2更新】
发表于 2020-3-9 17:35:50 | 显示全部楼层
顶顶顶顶
发表于 2020-3-9 22:55:02 | 显示全部楼层
学习了,这样是不是就不要小爱,天猫了。能搞成本地语音控制就更好。就不要联网安全了。
发表于 2020-3-11 12:40:30 | 显示全部楼层
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa
发表于 2020-3-11 13:58:32 | 显示全部楼层
报错,无法加载,ha0.106.5
Error during setup of component ha_voice
  File "/Library/Frameworks/Python.framework/Versions/3.8/lib/python3.8/site-packages/homeassistant/setup.py", line 173, in _async_setup_component
    result = await hass.async_add_executor_job(
  File "/Library/Frameworks/Python.framework/Versions/3.8/lib/python3.8/concurrent/futures/thread.py", line 57, in run
  File "/Users/macbookair/.homeassistant/custom_components/ha_voice/__init__.py", line 34, in setup
    hass.data[DOMAIN] = AipSpeech(APP_ID, API_KEY, SECRET_KEY)
  File "/Users/macbookair/.homeassistant/deps/lib/python/site-packages/aip/base.py", line 42, in __init__
    self._appId = appId.strip()
AttributeError: 'int' object has no attribute 'strip'
发表于 2020-3-11 14:09:53 | 显示全部楼层
牛逼哄哄,楼主好野
 楼主| 发表于 2020-3-11 14:41:07 | 显示全部楼层
yonghengdeshang 发表于 2020-3-11 13:58
报错,无法加载,ha0.106.5
appId 要用单引号包起来
http://github.com/shaonianzhentan
发表于 2020-3-11 14:51:45 | 显示全部楼层
可以有代替小爱了?
发表于 2020-3-11 19:08:54 | 显示全部楼层
jiluxinqing 发表于 2020-3-11 14:41
appId 要用单引号包起来
谢谢,用!secret导致忘了加引号了
发表于 2020-3-11 19:40:46 | 显示全部楼层
发表于 2020-3-11 20:19:20 来自手机 | 显示全部楼层
大佬,什么情况下才支持localhost,我的点击后是开启新页面录音?
GMT+8, 2026-1-13 11:47 , Processed in 1.504029 second(s), 11 queries , MemCached On.
