查看: 8584|回复: 8
[求助] 求助~N1安装的N大HASSIO 安装一键脚本
发表于 2019-12-25 14:49:44 | 显示全部楼层 |阅读模式
    是这样的:
N1刷好了ARMBIAN 5.88 user-built Ubuntu,
然后跑了N大的HASSIO 安装一键脚本。
顺利地进入ha的界面,也能添加配件。
但就是内置的hk没法连接。也有出现homekit的code,
手机输入后,就一直处于转圈的状态。
日志报错如下:
2019-12-25 14:30:08 ERROR (SyncWorker_3) [homeassistant.components.ios.notify] The notify.ios platform was loaded but no devices exist! Please check the documentation at https://home-assistant.io/ecosystem/ios/notifications/ for more information
2019-12-25 14:30:10 ERROR (SyncWorker_19) [asyncio] Future exception was never retrieved
future: <Future finished exception=NonUniqueNameException()>
  File "/usr/local/lib/python3.7/concurrent/futures/thread.py", line 57, in run
  File "/usr/local/lib/python3.7/site-packages/pyhap/accessory_driver.py", line 279, in _do_start
    self.advertiser.register_service(self.mdns_service_info)
  File "/usr/local/lib/python3.7/site-packages/zeroconf.py", line 1921, in register_service
    self.check_service(info, allow_name_change)
  File "/usr/local/lib/python3.7/site-packages/zeroconf.py", line 2062, in check_service
    raise NonUniqueNameException
zeroconf.NonUniqueNameException
请大大解解惑~~~
 楼主| 发表于 2019-12-25 14:51:17 | 显示全部楼层
补充1:
日志详细信息( ERROR )
Wed Dec 25 2019 14:30:10 GMT+0800 (中国标准时间)
 楼主| 发表于 2019-12-25 14:53:17 | 显示全部楼层
补充2:
日志详细信息( ERROR )
Wed Dec 25 2019 14:30:08 GMT+0800 (中国标准时间)
 楼主| 发表于 2019-12-25 20:38:32 | 显示全部楼层
大神抽空看下。
发表于 2019-12-26 09:27:38 | 显示全部楼层
你在configuration.yaml里面加homekit: 了么?
 楼主| 发表于 2019-12-26 15:03:28 | 显示全部楼层
当然添加了
 楼主| 发表于 2019-12-27 16:51:36 | 显示全部楼层
我顶
 楼主| 发表于 2019-12-30 10:09:58 | 显示全部楼层
再来试试 求大神指导
发表于 2020-2-16 14:27:24 | 显示全部楼层
一样的问题,估计homebridge哪个代码版本不兼容,我是我家云Chainedbox 5.4.2 。单独装homeassistant也是报一样的错
GMT+8, 2025-12-23 16:21 , Processed in 0.744646 second(s), 10 queries , MemCached On.
