查看: 15628|回复: 11
[技术探讨] 小米网关局域网通信协议探讨
发表于 2019-12-19 11:32:23 | 显示全部楼层 |阅读模式
按照AIOT开发平台上面的说明文档:[url=按照AIOT开发平台上面的说明文档:http://docs.opencloud.aqara.com/development/gateway-LAN-communication/
读设备
使用“read”命令以单播方式发送给网关的UDP 9898端口。用户可以用主动读取各设备的属性状态,网关返回该设备的全部属性信息。
例如:
读取墙壁开关的状态:
   "cmd":"read",
   "sid":"xxxxxxxx"   //墙壁开关did
网关以单播方式回复,格式如下:
   "cmd":"read_rsp",
   "model":"ctrl_neutral2",
   "sid":"xxxxxxxx",
   "params":[{"channel_0":"on"},{"channel_1":"off"}]
但是问题来了,为何我回复的内容中只有battery_voltage,其他的设备属性值都没有啊!有人遇到过么?
2019-12-19 03:13:04 INFO (SyncWorker_14) [custom_components.refresh_water_leak_sensor.sensor] Update the state...
2019-12-19 03:13:15 DEBUG (SyncWorker_15) [custom_components.refresh_water_leak_sensor.sensor] _send_cmd >> b'{ "cmd":"read","sid":"158d0004117248"}'
2019-12-19 03:13:15 DEBUG (SyncWorker_15) [custom_components.refresh_water_leak_sensor.sensor] _send_cmd resp << {'cmd': 'read_rsp', 'model': 'ctrl_86plug.aq1', 'sid': '158d0004117248', 'params': [{'battery_voltage': 3600}]}
2019-12-19 03:13:15 DEBUG (SyncWorker_15) [custom_components.refresh_water_leak_sensor.sensor] read_ack << {'cmd': 'read_rsp', 'model': 'ctrl_86plug.aq1', 'sid': '158d0004117248', 'params': [{'battery_voltage': 3600}]}
2019-12-19 03:13:15 INFO (SyncWorker_15) [custom_components.refresh_water_leak_sensor.sensor] A______________01: {'cmd': 'read_rsp', 'model': 'ctrl_86plug.aq1', 'sid': '158d0004117248', 'params': [{'battery_voltage': 3600}]}
2019-12-19 03:13:15 INFO (SyncWorker_15) [custom_components.refresh_water_leak_sensor.sensor] Update the state...
2019-12-19 03:13:15 DEBUG (SyncWorker_7) [custom_components.refresh_water_leak_sensor.sensor] _send_cmd >> b'{ "cmd":"read","sid":"158d00040567c2"}'
2019-12-19 03:13:15 DEBUG (SyncWorker_7) [custom_components.refresh_water_leak_sensor.sensor] _send_cmd resp << {'cmd': 'read_rsp', 'model': 'sensor_wleak.aq1', 'sid': '158d00040567c2', 'params': [{'battery_voltage': 3085}]}
2019-12-19 03:13:15 DEBUG (SyncWorker_7) [custom_components.refresh_water_leak_sensor.sensor] read_ack << {'cmd': 'read_rsp', 'model': 'sensor_wleak.aq1', 'sid': '158d00040567c2', 'params': [{'battery_voltage': 3085}]}
2019-12-19 03:13:15 INFO (SyncWorker_7) [custom_components.refresh_water_leak_sensor.sensor] A______________01: {'cmd': 'read_rsp', 'model': 'sensor_wleak.aq1', 'sid': '158d00040567c2', 'params': [{'battery_voltage': 3085}]}
官方说明文档中params应该还会有详细的信息的啊,搞得我获得的数据比心跳上报的数据还少了
纯新手,非科班,求赐教!!!!跪求!!!脱光了跪求!!!脱光了埋雪里跪求!!!
发表于 2019-12-19 12:04:08 | 显示全部楼层
建议放弃小米网关吧,已经开始封闭局域网协议了。还是用zigbee2mqtt吧,纯纯纯的局域网通讯
发表于 2019-12-19 12:41:27 | 显示全部楼层
我看它上面有 "report" 指令,你可以试试 "report" 指令啊
 楼主| 发表于 2019-12-19 13:00:07 | 显示全部楼层
"report" 指令是网关向你发送消息的时候用的指令额~~~
 楼主| 发表于 2019-12-19 13:01:08 | 显示全部楼层
Roger 发表于 2019-12-19 12:04
建议放弃小米网关吧,已经开始封闭局域网协议了。还是用zigbee2mqtt吧,纯纯纯的局域网通讯 ...
主要是已经有一堆的小米网关设备了,而且自制的zigbee网关主要是没壳子,不好看额~
发表于 2019-12-19 15:09:21 | 显示全部楼层
我看了下PyXiaomiGateway的库,貌似并没有什么特别的操作呀,是不是网关真的封闭了?
库的github:https://github.com/Danielhiverse ... gateway/__init__.py
发表于 2019-12-19 16:19:55 | 显示全部楼层
我又试了一下,read是可以读取设备信息的
比如
{"cmd":"read_ack","model":"plug","sid":"158d0001138888","short_id":45060,"data":"{"voltage":3600,"status":"off","inuse":"0","power_consumed":"241323","load_power":"0.00"}"}
你那个没读出来可能是网关并不能通过read读设备的其他信息,可能是通过report或者心跳来主动发送信息的吧。或者,你的是1代网关??
或者你的子设备贴牌是不是quara的?不是小米的?
我这里plug,sensor_ht,ctrl_neutral2, magnet,curtain都是可以正常读出来的
发表于 2019-12-20 21:23:15 | 显示全部楼层
我家网关灯用hass控制不了(hass显示开,实际并没开) 是不是就是这玩意闹的?
发表于 2019-12-20 21:43:24 | 显示全部楼层
老网关还是可以的,网关下的设备小爱操作方便,不用折腾。
zigbee2mqtt和老网关可以互补。
亮度温湿度这类不要求实时的,其实新网关通过HK接进去也可以。
目前就是看粗粮会不会停产老网关了,要真停产了,估计买两个存着- -!
 楼主| 发表于 2019-12-21 14:37:36 | 显示全部楼层
比如
{"cmd":"read_ack","model":"plug","sid":"158d0001138888", ...
我用的空调伴侣2升级版做的网关,read空调伴侣的开关、功率等数据是有的,但是子设备的数据都报的电池信息
GMT+8, 2025-12-31 23:34 , Processed in 0.583183 second(s), 7 queries , MemCached On.
